Rear load leveling shocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by mmm49660, May 15, 2021.
  1. May 15, 2021 at 5:48 PM
    mmm49660
    mmm49660 [OP] New Member
    1998 Toyota Tacoma Prerunner 2WD 2.7L V4
    I'm looking for some rear shocks for my dad's 98 Tacoma Prerunner 2.7l extended cab. He does a lot of heavy hauling with his 4 cylinder truck so it sags/ bottoms out.
    I can't seem to find anything anywhere that will fit his Taco. Just looking to find some rear load leveling shocks for him, the ones with the springs. Any help is very much appreciated.
  2. May 15, 2021 at 5:58 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Shocks only dampen a vehicle's ride
    The leaf pack is what supports a vehicle's weight
    You may want to look into air bags, unless he's hauling often, then you could just get a new leaf pack with the ability to carry a heavier payload
    mmm49660[QUOTED][OP] likes this.
  3. May 15, 2021 at 6:03 PM
    Bishop84
    Bishop84 Well-Known Member
    Those are gone with the Dodo, I havent seen load leveling shocks in 15 years.
    Firestone Airbags are the best option now.
  4. May 15, 2021 at 6:06 PM
    mmm49660
    He's trying to keep it low cost. If it isn't too much then he'll possibly consider it.
    My boss has a 99 Taco and installed some Monroe 58567 shocks and when he hauls heavy loads he says it doesn't sag.
    My dad wants to try some spring loaded shocks first. Thanks for the advice.
  5. May 15, 2021 at 6:44 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    For $100 I’d give them a try.
    Second I would do air bags, but that’s about a $300 investment.
    After that I would do new springs.
    mmm49660[OP] likes this.
  6. May 16, 2021 at 10:28 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I put some Gabriel's on my Tacoma back when I used it in a similar way to your father.
    Pumping up the rear with air shocks – ADVENTURETACO
    The only two brands that still manufacture air shocks - that I know of - are Monroe and Gabriel. They don't make any specifically for our trucks, but if you figure out the compressed and extended lengths of thatever your dad has on there now, you can find something in a similar range with the appropriate bushings on each end and install those. Worked well for me for many years.
    Essentially, these are the specs you want, from Gabriel's web site:
    The other option - as @Bishop84 mentioned - are Firestone airbags. Something along the lines of:
    https://amzn.to/3flfZWe - airbag kit
    https://amzn.to/2RV9dOM - airbag cradle
    If I were to do it again, I'd go with the air bags rather than air shocks.
  7. May 16, 2021 at 11:35 AM
    mmm49660
    Thanks for the very informative response turbodb. I can't seem to find anything along the lines of what my dad wants. I'll definitely show him both of these options. I'm thinking air bags might be best. I hope he agrees.
