Rear Limited Slip Diff Fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by talisker, Oct 3, 2013.
  1. Oct 3, 2013 at 8:51 AM
    talisker
    talisker [OP] Well-Known Member
    Scott
    Vermont
    06 TRD Off Road SR-5 W/1 Ton wood pellets
    Firestone Ride Rite airbags
    I'm miles from the nearest Toyota dealer. I just got my truck. It's got 100k and judging by the cabin air filter and engine air cleaner, I need to go through and change all the fluids now. The manual specifies straight 90 weight in limited slip diff. with an API GL-5 rating. This is the only fluid recommended in the owners manual and it is impossible to find.
    What's everyone using out there that won't mess up the limited slip?
  2. Oct 3, 2013 at 8:55 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Ur info says TRD off road....
    That's not limited slip, so u don't need any additives.
  3. Oct 3, 2013 at 8:57 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    75/90 should be fine
  4. Oct 3, 2013 at 9:19 AM
    Digger2
    Digger2 Well-Known Member
    Ontario, Canada
    '08 Double Cab TRD
    ARB Deluxe bumper, Full OME HD lift kit with Dakars. Frame welded Crew Fab DOM rock rails,Custom full skid plates, tow points,Cab mount chop, 265/70R17 Duratracs, weather tech mats.Coming soon Camburg BJ UCA's, Warn ??? winch
    So what kind of diff is it?? Mine is a ' 08 TRD with limited slip when I changed my diff fluid I had to put in LSD fluid in. OP if u have a lsd sticker on your pot u need lsd diff additive unless u run synthetic oil then most of it has the friction modifiers in it. I've heard tacoma didn't like synthetic fluid in the rear diff as they would still chatter. I used regular 75/90 with the LSD additive works fine.
  5. Oct 3, 2013 at 9:25 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, TRD Off Roads don't have a mechanical limited slip rear differential. The Owner's Manuals have changed year to year but the differentials have not. That being said, 75W-90 or 80W-90 will work just fine for your rear differential (I have a 2007 and it says 75W-90 for the front and x-fer case and 80W-90 for the rear).
  6. Oct 3, 2013 at 9:40 AM
    talisker
    Scott
    Vermont
    Hmm... I was under the impression that it was limited slip. Geez, I hope it is. I'll have to look into this.
    It's a TRD Off Road SR-5.
  7. Oct 3, 2013 at 9:42 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    look for the sticker if you really dont trust their info.
  8. Oct 3, 2013 at 10:49 AM
    talisker
    Scott
    Vermont
    I think Justus is right. There is no LSD tag on the rear diff, just AO. From what I've found it looks like its a locker. After researching how those operate, I'm even more confused than I was before. It looks like the best place to know for sure is to look at the buttons I have on the dash. Duh....
    Like I said earlier, I just got it. Obviously I don't know squat about it yet. I'll have to see what I have for toggles on the dash. It sounds like it has a pretty cool system and more variability than I'm used to with my old Ford Supercrew.
  9. Oct 3, 2013 at 10:55 AM
    Pugga
    Massachusetts
    TRD Off Road = No limited slip. The mechanical limited slip differential was only on the TRD Sport up through 2008. The locker acts like an open differential until you flip the switch on the dash (locker will only engage in 4Lo unless you redo your wiring).
  10. Oct 3, 2013 at 11:00 AM
    talisker
    Scott
    Vermont
    Yes, thanks Pugga. It does seem a little strange that it's only available in 4lo. People actually rewire them? I don't know if I dare to do that. It would be easy to forget it's on and not shut it off.
  11. Oct 3, 2013 at 11:29 AM
    Jomama
    Jomama Active Member
    Anchorage, AK
    2008 Dbl Cab/LB 4x4 SR5
    Mechanical LSD are in Non-TRD SR5's through 2008 too, I have one.
  12. Oct 3, 2013 at 11:36 AM
    Pugga
    Massachusetts
    Not all of them. It was an option on some SR5 models but, either way, it was never an option on the Off Road.
  13. Oct 3, 2013 at 2:28 PM
    Digger2
    Ontario, Canada
    '08 Double Cab TRD
    Hmm interesting I thought the electronic locker was only available after '09 in the configuration u talked of pugga. I thought all pre '09 trd's had mechanical rear lsd and the electric locker was a feature in start of '09. Well u learn something new everyday. Thanks.
  14. Oct 3, 2013 at 2:31 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    No sir, TRD Off Road (all years, from 1998-current) have the e-locker (except on the 98-04 tacomas that have a 4cyl and TRD package)
    Trd sport (tacomas) From 05-08 have a limited slip, 09+ trucks use the brakes to simulate a LSD.
    SR5 on some tacomas (unsure of the year range) can come with LSD's.
  15. Oct 3, 2013 at 2:36 PM
    Pugga
    Massachusetts
    95 Taco pretty much nailed it.
    2005 thru 2008 TRD Sports have a mechanical LSD which requires an additive when you change the diff fluid.
    2009+ TRDs have A-LSD which uses the brakes to simulate limited slip but they are just open differentials (no additive necessary)
    2005+ TRD Off Roads have the E-locker (no additive necessary, functions as an open differential until locked)
    2005 - 2008 mechanical LSD was an option for SR5, but not standard
    2009+ SR5 have open differentials
  16. Oct 3, 2013 at 4:20 PM
    Digger2
    Ontario, Canada
    '08 Double Cab TRD
    Cool thanks fellas. I appreciate the extra info, that's why I come on here to learn new tips, tricks, and general info from our members. Thanks again!
  17. Oct 3, 2013 at 5:14 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
  18. Oct 3, 2013 at 5:56 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I assume by "TRD" u are referring to the TRD SPORT......... which if u do have then ur right by putting modifiers in.
    OP has an offroad, therefore he doesnt need any modifiers
  19. Oct 3, 2013 at 6:11 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
  20. Oct 3, 2013 at 7:14 PM
    pgtr
    pgtr Well-Known Member
    2014 DCSB SR5 PreRunner
    I believe newer SR5s have A-LSD. In either case API GL5 75W90 or 80W90 would work.
