Rear Leaf Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jliberatore92, Apr 12, 2014.
  1. Apr 12, 2014 at 12:57 PM
    jliberatore92
    jliberatore92 [OP] Well-Known Member
    Troy, MI
    06 Tacoma TRD Off-road
    5100s with OME 885 coils. OME Dakar leaf and OME nitrocharger sport shocks., 265/75/R16 Duratracs
    06 TRD Access Cab, Stock Suspension.
    I just got the truck with 133k on it. I'm pretty new to truck suspension (had a wrx before the taco).
    I'm thinking I will need new leafs soon. I also would like to lift the truck a little bit in the future (2-3").
    My main question is instead of getting OEM leafs, could I get some leafs with a little bit of lift? And eventually down the road get Bilstein 5100s for the front.
    For example, if I get Bilsteins later on, how much lift would I want out of the rear leafs to have the truck be level with the 5100s?
    Also, I would rather not have to get new upper or lower control arms. I have heard you don't need them if you stay under 3" of lift.
    Thanks,
  2. Apr 12, 2014 at 1:51 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Yes, you can get different leaf packs for the rear. I'll leave the details for someone else that knows about it better.
    On the front it seems to be between 2.5"-3" of lift when new UCAs are needed. Some people need new UCAs at 2.5" and some don't. Its hit and miss.
  3. Apr 12, 2014 at 2:01 PM
    StealthTaco
    StealthTaco www.ecgfabrication.com
    Alec
    NC
    05 Black Tacoma TRD Sport 6-speed
    Dakar and All Pro standard leaf packs give just under 3 inches
    All Pro expedition gives about 4 inches
  4. Apr 12, 2014 at 2:04 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Dakars are good from what I've heard. Decently priced too. That's what I'm goin with
  5. Apr 12, 2014 at 3:09 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Note that the dakars are very stiff, might check out the wheelers HD pack.
  6. Apr 12, 2014 at 3:12 PM
    smmarine
    Melbourne FL
    And that dakars are on a nationwide backorder for a month or 2. At least that's what I was told
  7. Apr 13, 2014 at 8:21 PM
    jliberatore92
    Troy, MI
    My main concern is this: will doing rear leafs that lift my truck give it ridiculous rake until I do the front lift?
    And how much lift do I need on the rear to have bilstein 5100s up front? And have a leveled, ~2.5" lift.
  8. Apr 13, 2014 at 8:27 PM
    nd4spdbh
    SoCal
    from saggy old original springs to dakars expect about 4-4.5in of lift. Especially if your current leaf pack is the 2+1.
  9. Apr 13, 2014 at 8:29 PM
    OZ-T
    OZ-T Half of you are clearly below average
    Peter North
    British Columbia
    Dakars average about 2 3/4" over US stock height
    There is a hub to fender measurement thread somewhere started by some guy
  10. Apr 13, 2014 at 8:31 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  11. Apr 13, 2014 at 8:34 PM
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
    I had one overload pulled and it gave me about 2" of rear lift. Yes they are stiff. You can also pull the 3rd spring to get less lift and soften up the ride.
