rear facing truck bed seatting
Discussion in '1st Gen. Tacomas (1995-2004)' started by Aww Boo, Jun 3, 2012.
  1. Jun 3, 2012 at 12:28 PM
    Aww Boo
    Aww Boo [OP] Well-Known Member
    Jayson Lee
    Petaluma,CA
    98 tacoma 4x4 manual, 2.7L, (300k club)
    Front and rear trail gear armor Trail gear rock ripper headers skidrow skid plate K&n air intake Headach rack Anzo headlight at 8k Bilstein 5160 rear JBA uca
    hey guys i was thinking of putting seats in the bed of the trucK (with seatsbelts), ive seen the bedryders but those are $80 any other ideas that i could go with.
  2. Jun 3, 2012 at 12:37 PM
    Madjik_Man
    Colorado Front Range
    Maybe some out of an old Subaru Brat?
  3. Jun 3, 2012 at 12:39 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    all i know is im about to get a big ass bean bag chair or two to throw back there when im chillin at the beach or tailgating and whatnot.
  4. Jun 3, 2012 at 12:41 PM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Great idea. Always liked them.
  5. Jun 3, 2012 at 7:27 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    i seen a couple desert trucks with bucket seats in the bed, rear facing...
    coolest one had racing seats with 5 point harnesses...
  6. Aug 13, 2012 at 6:42 PM
    stumpjumper509
    stumpjumper509 Well-Known Member
    spamuel
    50nasty
    02 dcab overland
    donahoe ext front tc arms arb with warn demello crusher slider/rear safari snorkel trd supercharged with mods cvt shasta air comp with tank battery charger dakars with rr hoes
    im planning to do the same thing.. and yea bed ryder seats at 800 bucks a set is dumb. i found poly bucket racing seats for 70 bucks each. they accept 4 point harnesses, and im sure it wouldnt be that hard to weld up a frame
  7. Aug 13, 2012 at 6:47 PM
    Ecnerwal
    Ecnerwal Well-Known Member
    NW Mass
    '02 4x4 2.7 A/T Ext Cab
    gradually replacing the bumper with hairy bondo ;-)
    X2 - should be common as dirt, just find the right junkyard. DOT legal, seatbelts and all.
  8. Aug 13, 2012 at 7:18 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I've seen someone that bolted a couple fishing boat captains seats in there. Or get a bench from a big excursion van. You want something that mounts to a flat floor.
  9. Aug 14, 2012 at 11:54 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Hmm. this is familiar. Just finished the project a few weeks ago. I pikced up some junkyard seats from a Suzuki Reno to use because they were the correct width (and cheap). Once I got them home I realized they were better than the stock seats so I pulled the stock seats out and cut off the brackets. The Suzuki seats had the same track width so I just welded the factory feet onto the Suzuki rails and in they went.
    That left me with the stock seats to use in the bed. I built a seat frame from 1.5" square tubing and the seat rails are welded to the frame. It's bolted through the floor with large backing plates under the bed. I'm using lap belt for now, but will be changing them to 4-pt harnesses at some point. I did this for my two older boys ages 11 and 10 since I have 3 year old twins as well. The twins sit in the back seats, and the boys sit in the bed.
    With the topper on it's pretty tight for an adult. Legroom is fine but headroom is scarce for adults. The stock seats are pretty low profile and I did everything I could to keep them low but there's still not a ton of headroom. If you don't have a top, then it's not a concern.
    For safety I will also be building a rollcage. The way I've got the seat frame built i can turn it around and have it forward facing as well.
    Suzuki seats in the cab of the truck
    seat frame and stock seats welded to frame. you can see the tabs with captured nuts where I bolted through the floor.
    cheap seat covers but finished project
  10. Aug 14, 2012 at 11:57 AM
    Box Rocket
    Adam
    Syracuse, Utah
    all of the kids loaded up for fun
  11. Aug 14, 2012 at 12:24 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    That's bad ass
  12. Aug 14, 2012 at 7:17 PM
    had2020
    had2020 Member
    Heath
    az
    2001 sr5 reg cab 4x2
    nice and stock
    too cool man! :D
  13. Aug 15, 2012 at 6:53 AM
    BamaToy1997
    Bill
    Navarre, FL
    While I think that your idea is sound, I only say this: Since you have children in car seats, I would be cautious about how well the frame is mounted to the vehicle (are the bolt locations in a reinforced part of the bed, or through a single thickness of sheet metal) I noticed you said you used oversized washers, but even a large washer will not prevent tearing of sheetmetal. I am glad to also read you will be doing a roll cage. I hope VERY VERY soon, as if you were even in a small accident, injuries are easy in a bed. Other than that, you have an AWESOME looking setup, and it looks like you did a good job. Those welds look pretty good from here.
  14. Aug 15, 2012 at 9:14 AM
    Box Rocket
    Adam
    Syracuse, Utah
    I appeciate your concern. I'll assure you that as a father safety is priority #1 as far as my kids are concerned. If I didn't believe the setup was safe I wouldn't be using it. And in case it wasn't clear there are not child seats being used in the bed seats. My boys that ride back there are long out of child seats. That's the whole reason that we did it so the child seats could be in the cab.
    Currently the bed mounting is using more than oversized washers. There are large backing plates under the bed. The bed would tear off the body mounts before the seats separated from the bed. That being said, I plan to build a subframe to go beneath the bed as part of the seat mounting that will be integrated into the rollcage. At that point, those back seats will be safer than sitting in the cab without a rollcage.
  15. Aug 15, 2012 at 9:20 AM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    thats bamf! over kill IMO but when there's kids involved, do what you think is necessary. my dad used to just throw us in the bed of his old '87 ford with the old school aluminum camper ever time we went to the desert, i loved it.
  16. Aug 15, 2012 at 1:35 PM
    BamaToy1997
    Bill
    Navarre, FL
    Glad to hear you are going the route of overkill. There is no such thing as too safe when your kids are involved, that is for sure! Good luck and lets see pics of the roll cage when you get done!
  17. Aug 15, 2012 at 1:41 PM
    1stacoma
    1stacoma Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    Same here I cant tell you how many times I rode in the bed of the truck with an aluminum top. No seats and defiantly no seat belts. I'm in my mid 30's so that was probably early 80's I guess that was a different time. There wasn't even a seat belt law back then.
