Rear-End Alignment????
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kleenax, Oct 2, 2020.
  1. Oct 2, 2020 at 3:54 PM
    Kleenax
    Kleenax [OP] Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    Is there any way to "align" the rear-end? I have never heard of it if there is!
    I had new tires put on and wanted a front end alignment, but they said I needed an inner tie-rod end (wanted to charge me $150 for the part which was $30 on RockAuto), and they also said that my REAR-END was out of alignment! WTF? Never will go to Belle Tire (Michigan) again!
    Figured there wasn't any way to change alignment in the rear. Mount the springs in their perches, put the axle on the shackles, and tighten?
  2. Oct 2, 2020 at 4:30 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    It’s a static rear axle, I don’t think it can be adjusted.
  3. Oct 2, 2020 at 4:40 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    You got about 1° of thrust in the rear axle and that's due to necessary assembly tolerances, so effectively; no.
    Just rotate your tires, if your rears are getting abnormal wear then you've probably got a bent axle or you're too heavy on the skinny there one tire fire.
  4. Oct 3, 2020 at 1:55 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Yes they can be adjusted and aligned it is a very expensive process and time consuming .
    In simple terms shims and moving things around
    So much easier on link suspensions
    Maybe pushing 4 wheel alignment was the up sell for the week just who told you might have been clueless .
    I was asked all ready if I wanted my transmission flushed and filter changed I said no it was just checked when the new clutch was installed
    JudoJohn and Kleenax[OP] like this.
  5. Oct 3, 2020 at 2:43 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    its entirely possible that a rear end gets knocked out off alignment with the frame or front end
    that the axles are not true in either plane
    thru modifications or accident ( getting air )
    the shop U were in might NOT be Ur best bet
    2 real good men with a tape measure can check.....................
    there are cheap lasers at lowes/Home Depot set up correct in a dark garage
    can tell U all U need to know
    they wont fix it.......... U may not know how to fix it
    they will show where U are out !!
    Kleenax[QUOTED][OP] likes this.
  6. Oct 3, 2020 at 7:00 AM
    Glamisman
    Glamisman Well-Known Member
    they are probably talking about thrust angle. The rear axle is suspended by leaf springs that pivot at the front and as the spring compress's the effective length of the spring gets longer, thats why the rear of the spring is suspended from a movable shackle, it moves in a large arc. If there is a weak spring or there is bind and the axle doesnt sit level then the thrust angle is off. The shop is just trying to do the best job they can. If your truck doesnt wander and it holds its lane position going down the road I wouldnt worry about it. I am sure you have seen a truck going down the road where the rear axle "looks funny" where it isnt aligned with the front of the truck... for some reason I see this on older Dodge trucks more than anything else.
    96BlueTacos and Kleenax[OP] like this.
  7. Oct 3, 2020 at 7:12 AM
    Kleenax
    Ray
    Michigan
    Yea, I have seen a lot of older (Dodge) trucks that "dog-track" down the road. When the manager came out to give me the prognosis of the alignment machine reading, he told me that I needed the inner tie-rod end, and said, "and I don't know WHAT'S going on with that rear-end of yours"! When I asked him what he meant, that was when he told me my rear was out of alignment, and they didn't know what to do with it. And I still haven't replaced the inner tie-rod ends (60,000 miles ago), and don't notice any unusual wear on the tires at all, or any handling problems.
  8. Oct 3, 2020 at 7:56 AM
    Glamisman
    I will mention it and now that I have mentioned it you will notice it... you will feel the inner rod ends when your front tires hit a small road imperfection at a slow, almost walking speed.
  9. Oct 3, 2020 at 1:02 PM
    ROAD DOG
    FEW
    torque + HP overtime will result in the truck being tweaked
    that by no means OK or alright
    that rear axle could have been banged against most anything ' wheelin '
    boulder
    tree stump
    etc
    u cant align the front if the back is out
    crabbin down the road aint good
    it can be fixed !!!!!
  10. Oct 3, 2020 at 7:50 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    When I swapped in an elocker axle and went to get an alignment (front end), they had to do it 3 times before they realized that the rear axle was not centered perfectly. This was due to the way that I had bolted everything together. If I had a lift it would have been simple, but when you're dragging things around underneath the truck, the rear axle won't be perfectly square. Yes it does align itself with the leaf spring pins and axle perch holes, but there is some play there. The shop techs loosened the u-bolts on the lift and were able to get it centered.
    gilligoon likes this.
