Rear drums, swap w/ 4runner?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Booster, Jan 24, 2017.
  1. Jan 24, 2017 at 10:01 AM
    Booster
    Booster [OP] Well-Known Member
    1999 TRD 4Runner
    Bilstien Shocks 2.5 Inch Lift TRD supercharger TRD Exhaust Transmission Cooler K&N Intake Aftermarket headers Performance Parts Progressive Springs
    Is it possible to swap the rear axle and brakes of the tacoma with the 4Runner to get rear disks. Has anyone done any other kind of modification to convert the rear drums to disks?
    Been having a lot of drum problems on my drums, plus they love to overheat. Looking forward to hearing your stories
  2. Jan 24, 2017 at 10:05 AM
    Firebird
    Firebird Notorious Member
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    "Every thing will swap over with exception of the rear axle. The diff housing might switch over if you have a 4 banger but if you have a v6, the carrier is too big. If you have a e-locker, the 4runner (if it doesn't already have it) can easily be retro fitted for it."
    May be better off doing something
  3. Jan 24, 2017 at 10:06 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Had rear drums on my 3rd gen 4Runner. Retired it after twelve years and 170,000 miles. Never had any issues with them.
    What particular "drum problems" are you having?
    paranoid56 likes this.
  4. Jan 24, 2017 at 10:08 AM
    Dom Mazzetti
    Dom Mazzetti Well-Known Member
    Dom
    I don't understand this forums hate of drum brakes.....
  5. Jan 24, 2017 at 10:18 AM
    Booster
    1999 TRD 4Runner
    I live in a hot, mountainous area. My breaks constsntly overheat because all the work is getting pushed to the front disks. I think 4 rotors are a must at least where i live. It isn't out of hate, it's just a neccecity
  6. Jan 24, 2017 at 10:23 AM
    gpb
    Atlanta
    Not to challenge you but out of genuine curiosity... Sounds like the issue is your front brakes are getting too hot? How would rear disc brakes (not breaks) reduce the physics of load-transfer to the front axle and thus the front brakes contributing to 70% or more of braking? Last I knew that wasn't related in any way to the nature of the rear brakes.
    Also, is engine compression braking on long downhill stretches to reduce brake heating not a thing where you are? Even in the hilly (not mountainous) northeast where I grew up it was typically considered best practice. Has that changed?
    GPsevinSixx, Hobbs, Hank Heel and 2 others like this.
  7. Jan 24, 2017 at 10:46 AM
    Booster
    1999 TRD 4Runner
    My buddy did a rear disk job on his old 4Runner, and it in fact worked. The issue, even with engine breaking, is that the traffic is stop and go. Meaning up to 55, down to 20 because of the nature of the road. There isn't any way to manipulate engine breaking to do that.
    The deal is my front rotors overheat because the rear brakes don't assist them enough. Pushing that much breaking to the front 2 disks will create a lot more heat than having the rear 2 take some of the load off.
    I'm not challenging the design or dissing the truck, it's just that other cars have moved to 4 disks, and i was hoping to figure out a way to move too.
  8. Jan 24, 2017 at 10:57 AM
    gpb
    Atlanta
    Still doesn't make sense. Properly functioning rear drums should provide more than sufficient braking power. If I were in your shoes I'd be looking at verifying everything is functioning properly first. Bad adjuster, stuck pistons, glazed shoes, etc.
    Have a look at the braking distance tests, GMC Canyon is 4 wheel disc I believe: http://news.pickuptrucks.com/2016/08/2016-midsize-pickup-challenge-acceleration-and-braking.html
    Anyway, best of luck. I haven't seen any references to anyone else doing that sort of mod on one of these but it doesn't mean it hasn't happened.
  9. Jan 24, 2017 at 11:12 AM
    Booster
    1999 TRD 4Runner
    My mechanic took a look at them. They're functioning just as they should. They just don't provide as much as a rotor. Let's not compare the tacoma to the gmc. I mean, it's a gmc :bananadance:
    Masshole_And_His_Taco likes this.
  10. Jan 24, 2017 at 11:15 AM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    First, on most vehicles, front brakes do like 90% of the stopping work. Second, front brakes do even MORE work when going downhill (your mountainous area). Third, don't ride the brakes, and they won't overheat.
    A rear disc conversion will net you zero benefit.
  11. Jan 24, 2017 at 11:17 AM
    Dom Mazzetti
    Dom
    not to challenge you at all....but if it's in stop and go traffic to where you cant engine brake I really don't see the brakes overheating
    gpb likes this.
  12. Jan 24, 2017 at 11:17 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    I looked at that when I replaced my rear drums and shoes, mainly for ease of service. Problem is, it eliminates the emergency brake. Need that to pass inspection in MA. Also nice for hills with a trailer so I'm not putting that kind of stress on the parking pawl.
  13. Jan 24, 2017 at 11:18 AM
    Vancouver, BC
    Drum brakes give you more stopping power than discs. There is a much larger contact surface area with drum brakes. Their downfall is that they overheat easier - that's all.
    Broccoli and gpb like this.
  14. Jan 24, 2017 at 11:19 AM
    Vancouver, BC
    Another issue is that kit provides single-piston callipers. No point wasting money on that.
    Firebird likes this.
  15. Jan 24, 2017 at 11:21 AM
    js312
    Joe
    New England
    Yeah, I have nothing against the drums other than how much of a pain they are to service. My pads still looked new, but I replaced them because the OEM ones were squeaking.
    0210[QUOTED] likes this.
  16. Jan 24, 2017 at 11:24 AM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    Does '99 T4R have lspv?
  17. Jan 24, 2017 at 11:35 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Typically drum brakes work just fine and are designed and built to function and work perfect when used within the weight/load limits of the truck. Practically every big rig semi has drum brakes on the weight barring axles and trailers. I live in a very mountainous area and travel up and down a long 6%+ grade highway pulling and being pushed by a trailer. Never had any issues with brakes overheating or stopping. And I don't have trailer brakes. Like others, I suspect there is something wrong even if a mechanic says differently. Go to a brake specialist. If you are still dead-set on installing disk in the rear then make sure you put in a brake proportioning valve made for rear disk. Once again I would consult a true brake specialist.
    I've replaced my drum brakes at 100K miles because I didn't want to do it in the winter. 1.5 hours on the first side and 15 minutes on the second. It's not that hard and will probably be the only time I do it before getting a new truck. Good luck.
    gpb likes this.
  18. Jan 24, 2017 at 11:44 AM
    T$$
    T$$ Well-Known Member
    2017 TRD OR MT
    You should probably address the issue of your engine breaking before working on the brakes.
  19. Jan 24, 2017 at 11:47 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    No where is it both hot and mountainous.
  20. Jan 24, 2017 at 11:48 AM
    0210
    Vancouver, BC
    In my pants!
    (I'll show myself out.)
