Rear drum leak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOY4JMEBOOZE, Aug 11, 2015.
  1. Aug 11, 2015 at 2:06 PM
    TOY4JMEBOOZE
    TOY4JMEBOOZE [OP] Well-Known Member
    Winchester, CA
    2018 Chevy Tahoe
    Help. I noticed my brake light came on yesterday, then turned off. Today it turned on again. I checked the brake fluid and it was pretty low. I filled it and brake lines light gone. But I did notice grease build up on the rear passenger drum. The drivers side looks dry. Could it be differential fluid leak or a brake line leak? And how to fix? And do you think the dealer will fix this? It's 2012 sport.
  2. Aug 11, 2015 at 2:08 PM
    TOY4JMEBOOZE
    Winchester, CA
    2018 Chevy Tahoe
  3. Aug 11, 2015 at 3:34 PM
    Wasatch
    Wasatch Well-Known Member
    I was wrong, edited to not confuse others with the same problem.
  4. Aug 11, 2015 at 3:54 PM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    If you are still under 3year 36k warranty or if you have optional extended warranty yes dealer will fix under terms of warranty if not its got to be fixed as it will render brakes on that wheel useless.
  5. Aug 11, 2015 at 4:08 PM
    TOY4JMEBOOZE
    Winchester, CA
    2018 Chevy Tahoe
    I did see a brake light warning and my brake fluid was low. Refilled and the brake light went away
  6. Aug 11, 2015 at 8:07 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Brake warning light coupled with the fluid running out of the drum area and low fluid all points to a leak either the line going to the wheel cylinder or the wheel cylinder itself.
    As others said pull the wheel and drum off and have a look. Fluid inside the drum would be the wheel cylinder leaking. If the fluid is just on the outside area of the drum back plate it is probably the hard line going to the wheel cylinder.
  7. Aug 11, 2015 at 8:10 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Brake cylinder.
    Decrease replace and repaint.
  8. Aug 12, 2015 at 10:10 AM
    TOY4JMEBOOZE
    Winchester, CA
    2018 Chevy Tahoe
    So I checked the brake bleeder bolt and it had some play and the little rubber cap was missing. Found it this morning in my driveway. I tightened it and put the cap on. Will have a buddy of mine (toyota tech)check it out.
  9. Aug 12, 2015 at 10:46 AM
    Wasatch
    Aha! Then my suspicion was wrong. Sorry!
  10. Aug 12, 2015 at 11:38 AM
    TOY4JMEBOOZE
    Winchester, CA
    2018 Chevy Tahoe
    No worries. Had me worried if it was an axle seal. Made me check the breather. Iooks good.
