Rear drum brakes?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Attitudeboy2, Dec 22, 2019.
  1. Dec 22, 2019 at 6:54 PM
    Attitudeboy2
    Attitudeboy2 [OP] New Member
    Jeff
    Hello all from the west coast. After owning a brand new 1989 SR5 Toyota truck ( yes I’m that old) I’m considering getting a 2021 Tacoma next year. After specing out the one I want and going over the build specs I’ve noticed that for some reason Toyota still runs the archaic drum brakes on the backend. I will be towing about a 5000 lb trailer with it and was wondering if anyone knows first of all why? And if anyone knows of any issues with them? And if there is an aftermarket upgrade?
    Thanks for reading and hopefully your comments.
    TXpro4X4, Torspd and davidstacoma like this.
  2. Dec 22, 2019 at 6:58 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    No issues whatsoever, you will be fine with drum brakes out back.
  3. Dec 22, 2019 at 7:07 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    Because Toyota is cheap as fuck when it comes to R&D on Tacomas. They're too busy giving Rachel all the creature comforts in the RAV4 including rear discs
  4. Dec 22, 2019 at 7:11 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    On my 3rd Tacoma, one from each gen. I've always had plenty of breaking power. Only problem i have had is needing to replace the front rotors on each from "spirted" driving.
    I'm pretty sure the stopping distance of the Tacoma is equal or better than the competitors with disc rear brakes and the e brake works better.
    TacoManOne, tonered, Gritto and 3 others like this.
  5. Dec 22, 2019 at 7:14 PM
    mike s
    mike s Well-Known Member
    South Carolina
    2019 TRD OR
    The simple answer is rocks, they are more likely to get jammed up in rear disc brakes. So for off-road or gravel road driving, drum are better on the rear.
  6. Dec 22, 2019 at 7:15 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    It works so why change it?
  7. Dec 22, 2019 at 7:16 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Because they work, why change it.
  8. Dec 22, 2019 at 7:17 PM
    nat103
    nat103 Well-Known Member
    KY
    2017 DCSB OR
    Mike Sweers is that you
    :popcorn:
    Tainted, CJREX, black coffee and 13 others like this.
  9. Dec 22, 2019 at 7:19 PM
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
    Rear drum brakes help maximize profit for Toyota. Period.
  10. Dec 22, 2019 at 7:19 PM
    nat103
    KY
    2017 DCSB OR
    Pics of ‘89?
    TXpro4X4 and Chew like this.
  11. Dec 22, 2019 at 7:21 PM
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    It won't be an issue. I'd rather a proven setup with minimal cost, maintenance and quirks over a swing at a new system and them cheaping out because of the platform just to have it go wrong like GM on the silverados. The gmt800 had discs for a short time, they ate pads and loved to seize so they went back to drums. My 2006 had drums with zero issues. My buddy's 2000 had 3 rear calipers put on it. Ymmv.
    I had no qualms about drums ordering my Tacoma. They will not be the weak point on your truck unless you let yourself hyper focus on it and create a problem that's not there. (Like 99% of the people on this forum.)
    Relevant: 18-wheelers run drums for the same reasons- cheap, easy, reliable, sufficient. Some new rigs are going to disc on the front but it's a slow adoption due to the reasons above. Someone in that industry is welcome to correct me.
  12. Dec 22, 2019 at 7:22 PM
    gotoman1969
    Yep, must of been those rear drum brakes that put Toyota over the top.
  13. Dec 22, 2019 at 7:22 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Drum brakes are fine in the rear of a pickup. No reason to upgrade.
  14. Dec 22, 2019 at 7:23 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Easier to install tire chains on drums, too.
  15. Dec 22, 2019 at 7:23 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    So many experts to choose from. :laughing:
    My 07 frontier has discs. They're fine. So are the drums on my taco. I dunno why Toyota goes with drums, but they seem to be happy with their choice.
  16. Dec 22, 2019 at 7:29 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Party pooper.
  17. Dec 22, 2019 at 7:30 PM
    Sch0227
    Sch0227 Well-Known Member
    Steven
    Dallas, TX
    2017 TRD Parts bin
    Sharks with lasers
    If you find yourself needing a little more braking power you can upgrade the fronts to the Toyota 4Runner Disc/ Caliper. Its inexpensive and helps out.
  18. Dec 22, 2019 at 7:31 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Same reason base model Tacomas don’t have intermittent wipers...
    Torspd, davidstacoma and Junkhead like this.
  19. Dec 22, 2019 at 7:31 PM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    Don’t fix what’s not broke.
  20. Dec 22, 2019 at 7:32 PM
    FritoBandito
    Texas
    Ha ha! I drive a Tacoma, my drum brakes work just fine, but Toyota uses them to maximize profitability. This isn’t controversial and there’s nothing wrong with a corporation trying to maximize profit.
    Gritto, koditten and Junkhead[QUOTED] like this.
