Rear drum brakes - why?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crusher, Dec 1, 2011.
  1. Dec 1, 2011 at 1:53 PM
    Crusher
    Crusher [OP] How deep do you think that is?
    Greater YYJ
    06 DCLB TRD nekkid
    Debadged, Blacked out grille emblem, Alum headache rack & bed rails, OME 886 springs, OME Nitro's all around, Dakars, ARB Deluxe bull bar with Warn VR8000, leather front seats
    So why can you buy an FJ or 4Runner and get rear disc brakes, but we get drums on the Taco? Same drivetrain, right?
    Anyone converted their Taco to rear disc?
    Aftermarket parts or oem swap from FJ or 4R?
  2. Dec 1, 2011 at 1:56 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    drums don't get packed with mud and last longer.
    PasoSteve and Steadfast like this.
  3. Dec 1, 2011 at 2:00 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    Drums work just fine in the back you shouldn't worry. It's way more important to have discs in the front. The only downside to drums is that they can loose braking ability when submerged in water. So unless you're in 3ft or more of water going downstream and need to stop instantly, you'll be fine.
  4. Dec 1, 2011 at 2:01 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
  5. Dec 1, 2011 at 2:02 PM
    cooktaco
    cooktaco Well-Known Member
    Northern California
    11 Dbl. cab TRD 4x4
    Weahertecs, Bed met, Snugtop, Avid sliders, TSB Springs, Bilstein 5100's @1.75,
    Wondered the same thing myself. Our 02 Duramax pickup had rear discs and the brakes were still good at 125k. My son's 99 pre-runner seems to have way better brakes than my 11 TRD off road does. Love the truck overall, but not real impressed with the braking ability.
  6. Dec 1, 2011 at 2:03 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    my shoes/drums are original at 175k. About half worn last time I checked a few months ago.
  7. Dec 1, 2011 at 2:04 PM
    Aw9d
    Aw9d That one guy
    I was thinking the same thing, just for the fact that I hate working on drum breaks..
    and I agree with the 2011 not breaking as good as the older ones.. mine seems to break smooth, then just grab out of no where. Only have 1500 miles on it and never had to break hard or fast once. Had the dealer check it out, they say its normal.
  8. Dec 1, 2011 at 2:04 PM
    mjp2
    NJ
    My pedal on my manual brakes gets twitchy when the subject comes up.
  9. Dec 1, 2011 at 2:14 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Drums suck ass to work on.
    I've heard that e-brakes cost a lot more to set up on discs so they cheap out and give us drums.
    bobcat68 likes this.
  10. Dec 1, 2011 at 2:14 PM
    Crusher
    Greater YYJ
    06 DCLB TRD nekkid
    Thanks for the links, MJP. Admittedly I did not do due diligence looking for this info on the site.
    My whole point was why can you get them on the FJ and 4R but i guess its the unloaded bed factor, although couldn't a proportioning valve solve the problem? My old '83 SB had a primitive prop. valve in the rear, albeit with drum brakes.
    I only wanted to switch because I find disc setups to be much simpler to maintain and replace.
    I did the conversion on my 76 FJ40 and did have to dick around a bit with the system to make it workable (installed prop. valve and cranked it all the way down). Also had to run a newer master cyl, but it bolted right up so no problems there. The truck stopped a LOT better though, could haul it down from 75mph real quick, even with 32's and wagon steelies.
  11. Dec 1, 2011 at 2:20 PM
    mjp2
    NJ
    That they are! :)
    Best bang for the buck in terms of braking improvements on these trucks:
    . Call up Edwin at RaceShopper.com and order some SP Performance slotted rotors and Hawk pads
    . Order braided steel brake lines from All Pro or Wheelers
    . Install and thoroughly bleed the system
    . Keep the rear drums adjusted properly
    You should be able to knock about 20 feet off your 60-0 distance and get rid of the spongy pedal feel.
  12. Dec 1, 2011 at 2:32 PM
    Crusher
    Greater YYJ
    06 DCLB TRD nekkid
    thanks for the info mjp! brakes have been an issue for me, I hunt so mountain pass driving with loaded bed/trailer is a relatively common occurence for me. original front brakes chattered like hell when descending long hills (i assume this is off-gassing) with the original units, which i think were ceramic, so when i replaced them i bought raybestos premium "ceramic" pads and they seem to suck. my wheels get all brake-dusty now and never did with the original pads. also i have to press harder to stop. maybe my rears arent tight enough, im not sure where to adjust them to, i set them so they drag a little (spinning wheel manually when on jackstands), but should they be tighter?
  13. Dec 1, 2011 at 2:42 PM
    mjp2
    NJ
    I always set them so they drag just slightly, so I think you've got it set up properly. After getting them to drag slightly, step on the brake pedal to re-seat everything and see if they need more adjusting after that. Repeat a couple times and you should be set for the rears.
  14. Dec 1, 2011 at 2:50 PM
    mjp2
    NJ
    Their site sucks and is never updated. That's why I say call. :)
  15. Dec 1, 2011 at 5:57 PM
    2011tacotrd
    2011tacotrd Well-Known Member
    Northern California
    2011 TRD offroad double cab
    Pioneer indash navigation unit, Illuminated 4x4 switch, HID heads and fogs. Black leatherette GT seat covers. toytec Ultimate lift. Now its time to mod exterior.
    Rear drums ugh... The hassle to work on this ancient design is enough to piss the pope off. Now maybe the mud issue is relevant but all else is poppycock.
  16. Dec 1, 2011 at 6:01 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    subscribed... after 5+ years I still hate my brakes and (one day) will actually need to replace the OEM ones...
  17. Dec 2, 2011 at 8:35 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I can understand if you're trailering, then the discs would be nice, but otherwise I don't get the big deal with drums. If they're proportioned correctly they work well, and being self-adjusting they darn near last forever.
    When you think about it, big rigs have drums on every axle, so they can't be totally useless.
  18. Dec 2, 2011 at 10:07 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    drums are annoying to work on. I always wondered why they still use drums.
  19. Dec 2, 2011 at 2:35 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Drums are self energizing uses the weight shift to help apply them good rear brakes for a loaded truck. I never replaced the rear brakes on my 97 in 248K miles fixed the parking brake pivot inside the drum several times though. I still don't get the complaints about the newer Taco brakes, mine are out standing stops me my camper and the truck just fine ABS works as it should stops as well as the old one did only better.
  20. Dec 2, 2011 at 3:00 PM
    Aw9d
    Aw9d That one guy
    That's my thought as well. I don't need the extra stopping power, I don't care how they look, I just really hate working on drum breaks. Every car I've ever owned I replaced the drums to disc as soon as I could.
