Rear Drum Brake Pads Uneven Wear
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaEli, Mar 16, 2020.
  1. Mar 16, 2020 at 1:19 PM
    TacomaEli
    TacomaEli [OP] Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    My dad’s rear brake pads have a weird wear pattern. The right pad on the right rear drum is worn way down on the bottom half. Wondering what could cause this. 5015058E-5C77-4A58-AAFD-1D47FC034086.jpg
  2. Mar 16, 2020 at 1:53 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    I recently replaced my brake shoes and had a similar wear pattern. From what I read it is normal for the leading edge of the shoe to wear faster than the trailing edge.
    GQ7227 likes this.
  3. Mar 16, 2020 at 2:34 PM
    02hilux
    Planet: EARTH
  4. Mar 16, 2020 at 4:56 PM
    TacomaEli
    Eli
    Roanoke, Virginia
    Thanks, I was just wondering because the other side looked completely fine, front and rear pad, and on this side it’s just the front pad that’s worn and the rear is fine.
  5. Mar 17, 2020 at 12:42 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Seems somewhat odd to me that the bottom of the front shoe is worn a lot more than the top. But whada I know... :burp:
  6. Mar 17, 2020 at 12:49 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Normal wear for drum brakes.
    jammer likes this.
  7. Mar 17, 2020 at 1:31 PM
    TacomaEli
    Eli
    Roanoke, Virginia
    That’s what I thought too.
  8. Mar 17, 2020 at 3:01 PM
    wourkrsd
    wourkrsd Well-Known Member
    Komifornia
    2000 SR5/TRD 3.4 4x4 5 Spd. Ext Cab
    I did rears about a year ago and do recall mine looking all funky-like too.
  9. Mar 17, 2020 at 3:05 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    If the other side looked fine it might be because that side wasn't adjusted properly.
    CrustyTaco likes this.
  10. Mar 17, 2020 at 4:10 PM
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    Does your dad regularly use the E brake? The early Tacoma's rely on the use of the e brake to adjust for shoe pad wear.
    You can tell by the dog leg arm that has the 'R' stamped on it. This arm contacts both the adjuster ratchet wheel and the vertical e brake lever.
    The later Tacoma's adjust wear by just the use of the brakes.
    GQ7227, SR-71A and wourkrsd like this.
  11. Mar 17, 2020 at 4:14 PM
    TacomaEli
    Eli
    Roanoke, Virginia
    He uses the e brake anytime he parks.
    GQ7227 likes this.
  12. Mar 17, 2020 at 4:33 PM
    btu44
    Long Beach area, Ca
    That's good to do...:)
  13. Mar 17, 2020 at 4:54 PM
    wourkrsd
    Komifornia
    Learn something new everyday on TW
    GQ7227 likes this.
  14. Mar 18, 2020 at 7:42 AM
    old grouch
    old grouch Well-Known Member
    Stan
    Colorado Springs, CO
    95 4x4 V6 Extra Cab
    E-Locker SS Skid 2" Lift
    Could you define "early" and "later" please? Thanks, Stan
  15. Mar 18, 2020 at 7:54 AM
    Timmah!
    Timmah! Well-Known Member
    TIM
  16. Mar 18, 2020 at 8:10 AM
    Timmah!
    TIM
    And Yeah, that wear is absolutely normal. The front shoe on the lower half takes the brunt of wear.
    jammer likes this.
  17. Mar 18, 2020 at 3:44 PM
    btu44
    Long Beach area, Ca
    I don't know the year of the change and is the reason I was vague...sorry. But what I have figured out is a rear brake system that has the e brake cable above the leaf spring is an 'early' system. It looks to be the same as my old 89 Toyota PU.
    My 2004 has the e brake cable routed below the leaf and the bellcrank is horizontal. I call that a 'later'.
    Here's a diagram of a 2003 Tacoma. Notice the Automatic Adjusting Arm only attaches to the Rear Shoe.
  18. Mar 19, 2020 at 7:23 AM
    old grouch
    Stan
    95 4x4 V6 Extra Cab
    Thanks.
    btu44 likes this.
