Rear disc brakes?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by s.wilson, May 20, 2020.
  1. May 20, 2020 at 12:30 PM
    s.wilson
    s.wilson [OP] Less talk, more tech
    Morgan Hill CA
    1988 4Runner 3RZ, 2019 Tacoma TRD Off-Road
    TLCA Member #5261
    I've been surfing around this forum a lot, but haven't seen anything on rear disc brakes. Brake performance is my biggest complaint with my new to me Tacoma. I can't believe they're still using rear drums on these trucks!
    When I built my '88 4Runner I used the 5th gen 4Runner rear brakes... disc with drum parking brake. Front Range Off Road makes a kit to bolt them onto the older 8" rear axle housing and have a full-float setup too. I have far better brake control on my old 4Runner than this new Tacoma.
    How similar are the rear axles between the current 4Runner and Tacoma? If the main difference is just the suspension, I'd be very tempted to swap one in. It'd be a quick project to cut off the old suspension and weld on some leaf spring perches.
  2. May 20, 2020 at 12:32 PM
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    Your rear brakes do barely any of the work. Have you tried upgraded pads and rotors up front? I'd be stunned if you could find a front braking setup that wouldn't outbrake any normal tire. Shit, OEM can do it (lock up ABS).
    People have this weird idea that bigger rotors and calipers get you more braking. They don't (well, marginally). They get you more thermal capacity for repeated braking. Pads (and rotor material composition) are what get you bite. On my 2003 WRX it took Michelin Pilot Super Sports, an ultra-high performance summer tire, to get tires that my OEM calipers with Hawk HPS pads and DBA slotted rotors couldn't outbrake, and that was only on smooth, freshly paved tarmac.
    cosmicfires, Auzea, Tocamo and 10 others like this.
  3. May 20, 2020 at 12:33 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  4. May 20, 2020 at 12:35 PM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
  5. May 20, 2020 at 12:38 PM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    This^
    Our trucks are very light in the rear, so adding "better" disc brakes in the rear wouldn't really help any. Also like my guy above said, most of the braking comes from the front. Consider upgrading the fronts before you look at rears.
  6. May 20, 2020 at 12:38 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    :rofl::rofl::rofl:
  7. May 20, 2020 at 12:41 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    I am curious, how has your brake system let you down "re: my biggest complaint"? Were you towing? Other than the fact that they are rear drums, my brakes work great.
    AKGSD, Kevin Jones, DanoTay and 2 others like this.
  8. May 20, 2020 at 12:45 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Upgraded fronts as well as disc rears with the stoptech kit from SOSPerformance. This truck stops on a dime now. Rear conversion is expensive, it’s definitely not the “brake per dollar” return as the fronts. But With my large tires I wanted as much brake as I can get, plus I gotta match.
    cjags, Smalltaco44, JasonCz and 18 others like this.
  9. May 20, 2020 at 12:46 PM
    s.wilson
    Morgan Hill CA
    TLCA Member #5261
    Pad or rotor upgrades aren't going to help... I'm definitely not talking stopping distance. Pedal feel and smoothness are my biggest complaints.
  10. May 20, 2020 at 12:49 PM
    VirusCage
    VirusCage Well in the secondary immune response
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 1995 Landcruiser 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Upgraded MC and proportional valve will help with that
    zippsub9 and CrippledHo like this.
  11. May 20, 2020 at 12:51 PM
    Ez2Tan
    Ez2Tan Well-Known Member
    2017 Quicksand Tacoma OR
    Are you on 4 pot or 6 pot up front?
  12. May 20, 2020 at 12:54 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Drums brakes are more efficient than disc brakes is one of the reasons as to why Toyota still uses them.
  13. May 20, 2020 at 12:55 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Drum brakes are self energizing and up until they overheat could potentially brake better than rotors. They don't cool off nearly as quick as rotors do so repeated braking will make them fade faster.
  14. May 20, 2020 at 12:56 PM
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    I did the upgrade about 4ishidk years ago on my '16 when they first came out with the rear disc conversion. The "feel" was improved marginally, and what do you mean by smoothness? I can't say for certain as it's been so long, but the stock setup wasn't bad. Been going strong since I got em
  15. May 20, 2020 at 1:26 PM
    MESO
    State of Jefferson
    6POT front, 4POT rear
  16. May 20, 2020 at 2:15 PM
    s.wilson
    Morgan Hill CA
    TLCA Member #5261
    No complaints about higher speed braking. Slower speeds, 30 or less, I find them very inconsistent. With a consistent pedal application, I don't feel like I get a consistent result from the brakes. Sometimes they're smooth and what I expect, other times they're very grabby. So far I'm blaming the drums.
    I'm a very laid back driver in my pickups. Not a speeder, not hard on my brakes. So heat in the brakes is unlikely to be a factor.
    Thanks for the links, I'll check 'em out. That one for the $2000+ brake kit blows my mind. Gotta be a cheaper solution.
  17. May 20, 2020 at 2:19 PM
    CrippledHo
    Eric
    2016 DCSB Diet Coke
    Fair enough
  18. May 20, 2020 at 2:35 PM
    ryan760
    ryan760 Well-Known Member
    OP haven't you heard? Drums are in again. 4th gen will have 4 wheel drums.
    moondog1, JPDS2020, BalutTaco and 2 others like this.
  19. May 20, 2020 at 2:43 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    After my 2007 ranger with drums in the back, i was very pleased with braking performance of the taco. You had to mash the brake pedal on the ranger to stop quickly, was scary at times.
    The brakes on my taco always felt smooth and consistent, hopefully they last. The only thing i would tow is a 16 ft aluminum boat so all good. No complaints over here. Just my .02
    DanoTay and ryan760 like this.
  20. May 20, 2020 at 3:00 PM
    vecdran
    Jeremy
    Kirkland, WA
    Do you have stock OR suspension? When I test drove one I hated how the front end dove and made me press the brake pedal harder than I wanted. Half the reason I got the PRO.
    Junkhead likes this.
