Rear disc brake conversion on 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deathpunch8210, May 9, 2020.
  1. May 9, 2020 at 8:08 AM
    deathpunch8210
    deathpunch8210 [OP] Well-Known Member
    Josh
    Bakersville,NC
    08 tacoma crew cab
    3in. Rough country leveling kit. Aftermarket headlight & taillights
    If you do a rear disc conversion on my 08 dcsb,will I have to change the master cylinder? Thank for the advise
  2. May 9, 2020 at 8:59 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I bet the rears already lock up before the front, discs ain't going to help you any
  3. May 9, 2020 at 9:17 AM
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    Why? The brakes are good the way they are.
    otherphone likes this.
  4. May 9, 2020 at 9:24 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Pickup beds are too light to need disc brakes. Even with the bed loaded they only have 30% stopping power
    Kolter45, b_r_o and Steadfast like this.
  5. May 9, 2020 at 9:41 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    They do help. Tremendously.
    You don't have to. It is however recommended. As the cylinder we have is for drums. I take it you are thinking about the kit from www.tundraracing.com ?
    I have done the rear disk swap on two trucks. One still has the OEM master, and the other upgraded to the Sequoia (?) one.
    Evenflow, Lucario Runner and Biscuits like this.
  6. May 9, 2020 at 12:59 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Don't waste your money on rear disc brakes.
    Jetfixr and Mully like this.
  7. May 9, 2020 at 5:32 PM
    nd4spdbh
    SoCal
    For you yes, a guy that races his taco... yes. But for 99% of the people who drive em around unloaded, nope. And if you are smart even towing a mid sized trailer, it has brakes as well.
    Flori-duh Taco likes this.
  8. May 9, 2020 at 7:35 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It's all about the need.
    OP, there is a thread, or two(my buzz is making it hard to remember), of people whom all discuss having done the upgrade. If you are so inclined, check it out.
    All ranges of modified Tacos. Some with extra cheese, and some without. Or maybe I'm just drunk. Either way, happy Saturday evening! :taco:
  9. May 10, 2020 at 4:25 AM
    DG92071
    DG92071 Well-Known Member
    You'll get a lot better brakes by leaving the drum brakes on and swapping the MC and booster to Tundra/Sequoia.
    Kolter45 likes this.
  10. May 10, 2020 at 4:34 AM
    soggyBottom
    soggyBottom Well-Known Member
    I don't i know if it's required. All the kits I've seen all want you to switch to a Sequoia MC. One thing to note is that the parking break on the disc breaks won't be as strong as the drum.
  11. May 10, 2020 at 7:56 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Would you also need to swap the proportioning valve? I can't imagine the OEM one, which is valved for rear drums, would work properly.
  12. May 10, 2020 at 9:36 AM
    DG92071
    The Tacoma proportioning valve is inside the ABS system.
    With Tacoma ABS monitoring wheel speeds if a wheel locks up it automatically applies the ABS system which is actually an advantage when it comes to brake component swaps IMO.
    I installed a Tundra MC and dual diaphragm booster (Tacomas have single diaphragm boosters). There is a lot of information on the web about the advantages of a dual diaphragm booster. The Tacoma is disc/drum, the Tundra is disc/disc. I haven't experienced any problems whatsoever, including proportioning of the front and rear brakes. The ABS works exactly as before. The brakes on my truck are amazing with a lot less pedal pressure required and it stops quicker. I also swapped the front brakes for larger stock 4Runner brakes. The rear drums are stock and the shoes are the originals.
    I can't even imagine the brakes if I had rear disc brakes. My trucks brakes are amazing. Rear disc brakes are cool in the bragging rights department, IMO. I tow heavy boats sometimes and I've never needed better brakes and most of the heavy boats I've towed their trailer's brakes didn't work at all.
  13. May 10, 2020 at 10:44 AM
    billygoat
    billygoat Well-Known Member
    American Southwest
    08 TRD Offroad 4x4
    6” Fabtech Lift, 35’s, lots o’ goodies
    I
  14. May 10, 2020 at 12:43 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    If going to pick up sos kit since its recommended may as well. I did . Hope to install this week
    zippsub9 likes this.
  15. May 10, 2020 at 12:45 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Have to disagree there. My dd taco brakes way better and more consistently with rear disks and an upgraded master.
  16. May 10, 2020 at 1:58 PM
    nd4spdbh
    SoCal
    old style vacuum booster is the problem there.
  17. May 10, 2020 at 2:29 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Contemplating swapping drums on my bike. :anonymous:
  18. May 10, 2020 at 4:14 PM
    nd4spdbh
    SoCal
    Hahahaha. Spokes too?
  19. May 10, 2020 at 4:15 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Feel free to do it. But you don’t need it.
  20. May 10, 2020 at 4:20 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Not true, rear disc conversion adds quite a bit more braking power to the rear end.
