Rear differential fluid level.. how much?!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dank24, Apr 15, 2018.
  1. Apr 15, 2018 at 5:11 PM
    Dank24
    Dank24 [OP] Well-Known Member
    3rd gen OF
    In the manual it has several levels noted. I am not sure which one is mine...
    I have a 2017 off road auto 4x4
  2. Apr 15, 2018 at 5:20 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    about 1/4" below the fill plug.
    side note: currently using Lucas 85w140, non-synthetic.
  3. Apr 15, 2018 at 5:28 PM
    steele-taco
    steele-taco Well-Known Member
    james
    Jersey shore
    17 TRD OR DCSB white
    Do any of the * say with locker? That would be it.
  4. Apr 15, 2018 at 5:33 PM
    OregontoBajaCA
    OregontoBajaCA Well-Known Member
    2017DCLBOR
    It’s 4.2 quarts for the 2017 Off Road Auto 4X4
    eddyizm and Dank24[OP] like this.
  5. Apr 15, 2018 at 5:38 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
  6. Apr 15, 2018 at 5:56 PM
    Dank24
    3rd gen OF
    I was too looking at mobile 1, but it says LS 75-90 for mobile one. And the manual calls for LT 76-85 or equivalent . Does the limit slip on the module 1 matter?
    I was gonna go with a amsoil, but it’s a fortune
  7. Apr 15, 2018 at 6:10 PM
    2016Tacoman
    J
    Read this
    http://www.lastgreatroadtrip.com/wp-content/uploads/2010/11/gear-oil-comparison.pdf
    My dealer does not stock recommended Toyota fluid, but sells and uses the Amsoil.
    After you read that article you'll know why.
    Summary on page 19.
    Lucas is last :eek: , royal purple is down there also.
    With LSD I believe you need synthetic.
    My dealer sells lucas for $15. Not allowed to mark up.
    1bad2k and Vbpiper like this.
  8. Apr 15, 2018 at 6:17 PM
    Dank24
    3rd gen OF
    After looking at that, I should just source the amsoil tomorrow.
    1bad2k likes this.
  9. Apr 15, 2018 at 6:18 PM
    2016Tacoman
    J
    :thumbsup::thumbsup::thumbsup:
    Check your dealer.
  10. Apr 15, 2018 at 6:41 PM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    4qts 75w90
    eddyizm and fökai671 like this.
  11. Apr 15, 2018 at 7:41 PM
    2016Tacoman
    J
    Amsoil is $15 for me at dealer. What is Mobil 1 ?
    For a 35-40K+ truck a few extra $ is minimal considering this isn't changed frequently.
    Tacowin1013, Dank24[OP] and Vbpiper like this.
  12. Apr 15, 2018 at 8:04 PM
    2016Tacoman
    J
    The viscosity after shear test is what concerns me on Mobil 1.
    "the slightly higher than average price of AMSOIL Severe Gear would
    be offset by the cost savings achieved through reduced maintenance, longer lasting differentials and extended lubricant life."
  13. Apr 15, 2018 at 8:25 PM
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    Just changed mine out two days ago. 3rd Gen TRD OR auto gets the 4.2 quarts.
    Dank24[OP] likes this.
  14. Apr 16, 2018 at 3:46 AM
    Dank24
    3rd gen OF
    Just found an individual dealer right down the road from me... not too bad since I live in the sticks haha. $17/quart
  15. Apr 16, 2018 at 3:49 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    dont you just fill it up till it spills out the fill hole? if truck is level.........then let it settle, and check / top off.
  16. Apr 16, 2018 at 4:30 AM
    Clearwater Bill
    Billy
    Largo Florida
    1) That is an 11 year old 'study'. Even if those results are accurate for the time of the testing, are you suggesting the lubricant industry has stood still for the last decade?
    2) Did you note that the 'winner' of the study is the firm that produced the study? That alone should create pause.
    3) The fancy signature sheets at the end? Linked in shows David Leitten is the ‎Laboratory Director - ‎Amsoil Inc. Again, a reason for pause. Notary work isn't impressive. It only means they validate the ID of the person signing. Not the content of the document.
    If you want to use lab work to support your choices, at least use work from an independent lab.
    Amsoil certainly isn't bad. But no boutique elixer is needed for these diffs. Proper wt., GL rating, clean and full. OTC gear lube from a quality manuf. is just fine.
    If you feel good paying that kind of money though, please proceed.
    Pretty much. Level F/R and L/R. Same procedure for the last 50 or 60 years.
    Simple solution is to buy 7 qts of the proper fluid (they all use the same type, and you are doing the front at the same time, right?). Do the front first, then fill the rear slowly as @JimboAnz mentions above. The worst that happens is you have some left over for the next change.
    Or just return unopened bottles if you wish.
    TACO TX, Orangecrush, tonered and 3 others like this.
  17. Apr 16, 2018 at 4:58 AM
    2016Tacoman
    J
    And your independent recent study, paper, showing such detailed research ? Link please.
    Maybe it doesn't exist for a reason.
  18. Apr 16, 2018 at 5:19 AM
    Clearwater Bill
    Billy
    Largo Florida
    I think you're right about not existing for a reason. Because independent labs don't write advertisements disguised as white papers.
    However, if you send a sample from your vehicle in for testing, they will tell you the health of both your lube of choice and the differential it was running in, as well as a recommended change interval.
    MrCball, tonered and Vbpiper like this.
  19. Apr 16, 2018 at 5:32 AM
    2016Tacoman
    J
    Sending a sample in could be too late after a few 10K miles.
    Look at the labs for Taco now, don't have a baseline yet according to this guy https://www.tacomaworld.com/threads...-6mt-fluid-change.481719/page-4#post-14749797
    Post no. 62
    I'm not testing oils in my truck, I'll go with true lab results.
    I can't find anything that discredits that paper after 10 years. Nothing.
  20. Apr 16, 2018 at 7:38 AM
    Cold_Toad
    Cold_Toad Well-Known Member
    The only way for you to get true lab results is to send in your oil for testing to a lab, you can't use someone else's lab results and determine from that that the oil you are using is good.
    Clearwater Bill and Vbpiper like this.
