Rear Differential Disassembly....
Discussion in '3rd Gen. Tacomas (2016-2023)' started by UnDomesticMotors, Feb 15, 2024.
  1. Feb 15, 2024 at 5:30 AM
    UnDomesticMotors
    UnDomesticMotors [OP] Member
    Hey guys,
    I need help with my differential. I've been trying to take it apart (needs new bearings), and I can't. The back plate is not bolted on, so how do I remove it to get to the inner ends of the axles, and the carrier in general? upload_2024-2-15_8-29-42.jpg (The big "circle" in the center of this differential).
    Thanks,
    Dom
    UPDATE:
    I have the bolts for the carrier case all undone, the brake lines are freed, parking brake lines are undone from the car, and the drums are disassembled. The 4 bolt flange behind the front of the drum is unbolted. Everything that seems would prevent the axle from sliding out is out. The axle still won't budge out.
    I am almost certain that diff bearings are what failed, but I'll only really know for sure once the thing's open.
    Also, I have the whole thing out of my car
    Any tips?
  2. Feb 15, 2024 at 6:05 AM
    545 Well-Known Member
    2015 Access Cab
    Read up on what a third member is
    PTSDTherapy likes this.
  3. Feb 15, 2024 at 6:09 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Look on the other side.
    MR E30 likes this.
  4. Feb 15, 2024 at 6:10 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    https://www.tacomaworld.com/threads...d-installation-of-e-locker-3rd-member.193828/
  5. Feb 15, 2024 at 6:22 AM
    CementHead18
    CementHead18 Well-Known Member
    Jim
    SC
    2018 CementTRD Sport 4x4 DCSB
    Hence my reasoning for only buying new...
    DesertRatliff likes this.
  6. Feb 15, 2024 at 6:30 AM
    UnDomesticMotors
    So you just yank on the ends of the axles??
  7. Feb 15, 2024 at 6:40 AM
    BLtheP
    Plano, TX
    There is nothing to yank…axle shafts need to come out far enough to clear the diff. Oncee shafts are removed, you undo the 10 nuts on the diff and remove it.
    There are things to remove or free up before the shafts can come out. Brake lines either need to be unthreaded or all of the clamps undone so the lines can stretch. Parking brake cables need to be freed from the leaf springs. ABS cables need to be disconnected. Then the 4 retainer nuts that hold the shaft/wheel bearing to the housing.
    What bearing are you trying to replace? If wheel bearings then you don’t need to touch the diff at all. If diff bearings (pinion and carrier), you need to do the process above. For diff bearings you will need some knowledge of differential setup. For axle wheel bearings you need a press and a special Toyota axle puller to pull off the old bearings.
    Respectfully, so far the questions lead me to believe you might be a bit in over your head.
  8. Feb 15, 2024 at 6:40 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Some of the bearings need a press and other tools to remove and install FYI.
    not a dig, but since you’re attempting to enter the diff on the wrong side, I figured you may not be familiar with the other whole process.
    Jakerou and BLtheP like this.
  9. Feb 15, 2024 at 6:57 AM
    UnDomesticMotors
    Any tips?
  10. Feb 15, 2024 at 6:59 AM
    BLtheP
    Plano, TX
    Mine came right out when I did my regear. Maybe use an axle puller slide hammer kit. Should be able to rent from parts store, in the US anyways. I'm not sure where you are.
    But yes, once the 4 nuts are removed, there is nothing holding the shafts in.
    If you are working on the differential bearings, you'll probably want a clamshell puller.
  11. Feb 15, 2024 at 8:04 AM
    eurowner
    eurowner Duke Sky
    Scoty
    You should edit your first post and add your above reply. Then we know what you have done.
  12. Feb 15, 2024 at 8:21 AM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    I wonder, did you try pulling the axles before loosening the differential bolts? If the diff is hanging off the housing it may be putting enough pressure on the axles to prevent them from coming out.
    PTSDTherapy and jlemmond like this.
  13. Feb 15, 2024 at 8:23 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    This.
    fathomblue[QUOTED] likes this.
  14. Feb 15, 2024 at 8:44 AM
    UnDomesticMotors
    I'll try that, it only slides out about 1/2 inch though.
  15. Feb 15, 2024 at 9:00 AM
    BLtheP
    Plano, TX
    That could be enough to bind the shaft. I didn’t realize you were trying to pull the diff before the axle shafts were freed.
  16. Feb 15, 2024 at 10:34 AM
    UnDomesticMotors
    Yeah after looking at diagrams the axles probably kept the diff locked on. XD
  17. Feb 15, 2024 at 7:29 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Picture is worth a lot more than words on this one. Post up some pics of what you have done so far.
  18. Feb 16, 2024 at 5:10 AM
    jwarr
    jwarr Well-Known Member
    Can you also tell us some more about the original symptoms and what lead you down the path to disassembling your rear axle assy? Internal differential bearings almost never go bad... What year truck and how many miles?
    Chew likes this.
  19. Feb 19, 2024 at 6:41 AM
    UnDomesticMotors
    While on the highway, the car suddenly felt "heavier" (it deaccelerated really easily when I let off the gas, like it was being weighed down). Also, the rear end had a terrible whine/shriek and vibration. Overall a horrible driving experience.
    I was able to open up the carrier btw, thanks guys. Now I need a new pinion bearing.
  20. Feb 19, 2024 at 6:48 AM
    UnDomesticMotors
    Thanks for the advice :amen:. Rented one and it did the trick! Now to press out the pinion shaft...
    BabyBilly likes this.
