Rear Diff Fluid Question
Discussion in 'Performance and Tuning' started by surfsupl, Dec 23, 2013.
  1. Dec 23, 2013 at 11:08 PM
    surfsupl
    surfsupl [OP] Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    I have about 120k on my truck.(2005 A/C PreRunner V6 2WD) The rear diff fluid has been changed b4. Is their a high mileage diff fluid? If so what do you recommend? Plus how many quarts needed.
  2. Dec 23, 2013 at 11:27 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
  3. Dec 24, 2013 at 9:56 PM
    surfsupl
    Gregg
    WestCoast
    Thanks to the only guy who answered :cool:
  4. Dec 25, 2013 at 2:37 PM
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    Amsoil severe gear 75w90;) I think you need right around 3 qts. I always buy 4 just in case. And remove the top fill plug first before attempting to remove the drain plug!
  5. Dec 25, 2013 at 2:44 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Says the guy who's probably put his drive train thru more abuse than any other Tacoma on earth.
    Go Werty or go home. :cheers:
  6. Dec 25, 2013 at 2:45 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    80/140 regular lucus oil is what I have been running for over a year now. Strange how I Havnt broke a diff running that oil but when I was running synthetic stock weight I went through 4 ring and pinion sets. ECGS also recommends the 80/140 weight, its why I chose to go with it.
  7. Dec 25, 2013 at 2:46 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    75w90 Mobil-1, Amsoil, or Redline.
    75w140 if you do a lot of towing in the summer and don't hit the ski resorts in winter.
  8. Dec 25, 2013 at 2:46 PM
    Brodie
    Brodie Gear Jammer
    Colorado
    2013 TRD Magnetic Gray Double Cab
    Red Line 75w90
  9. Dec 25, 2013 at 2:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Low range exerts for torque to the axel than hi range. More torque load, and you need a heavier fluid to protect the gears.
