Rear Diff Fluid Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hennessy3300, Jan 31, 2024.
  1. Jan 31, 2024 at 11:34 AM
    hennessy3300
    hennessy3300 [OP] Well-Known Member
    I am about to change the fluid in my transfer case, front and rear diffs. My truck is a 2005 Sr5 4x4. Do I need to add LSD fluid with the gear oil in diffs? I think my truck has an open diff.
    HondaGM likes this.
  2. Jan 31, 2024 at 11:41 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The LSD trucks had an LSD sticker in the rear of the differential.
    The chances yours is still there is little to none. But it could be?
    If in doubt, add the LSD additive. It will not hurt anything.
    HondaGM likes this.
  3. Jan 31, 2024 at 11:43 AM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. Flowmaster Super 50 Series with stock resonator. J&L catch can. Speedys Equipment resonator.
    Many full synthetic diff fluids come with it already in it:notsure:
    HondaGM, Stemmy and SR-71A like this.
  4. Jan 31, 2024 at 11:47 AM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I put the Lucas in both of my Tacomas...
  5. Jan 31, 2024 at 11:49 AM
    TnShooter
    Deogee
    STOCK
    The 2005-2008 manual had 80w-90 as the recommended fluid.
    Most 80w-90 is standard oil with no additives. You can find it in synthetic, but it not as common as 75w-90.
    I'd just pour 75w-90 in a 3.
    HondaGM likes this.
  6. Jan 31, 2024 at 5:29 PM
    TacoTuesday1
    NC
    LSD diff oil is for LSD diffs.
  7. Jan 31, 2024 at 5:38 PM
    TnShooter
    Deogee
    STOCK
    Suppose a man were to use a gear oil with LSD additive in it, in his open diff.
    What's it going to hurt?
    winkel likes this.
  8. Jan 31, 2024 at 5:47 PM
    ToyotaMan2015
    ToyotaMan2015 Well-Known Member
    Nathan
    Somerset KY
    2015 Silver Tacoma Limited
    32in Tire
    i used redline 75w85 for mine, it had the lsd additive. full synthetic. most synthetic gear oils have it in it. wont hurt a thing if you put it in a open diff. mine is open, and my oil had the additive in it, so, i can attest to that. probably put over 5k on it since i serviced them. no trouble at all.
  9. Jan 31, 2024 at 6:15 PM
    TacoTuesday1
    NC
    probably nothing. In an LSD, it still lubricates the gears. And has additive for proper mechanical clutch function.
    According to Amsoil website, if you accidentally put LSD oil in something that doesn't call for it, it's fine.
    Only obvious downside is probably the cost. LSD oil usually costs more than regular.
  10. Feb 1, 2024 at 4:34 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Nothing.
    TnShooter[QUOTED] likes this.
  11. Feb 1, 2024 at 4:39 PM
    ToyotaMan2015
    Nathan
    Somerset KY
    32in Tire
    Again, I can attest, I used redline full synthetic with lsd additive in mine, works perfectly. All of theirs has the lsd additive. If your worried about it, go to your local parts store and get you Mobil 1 75w90. I believe it has the lsd additive. Roughly $20 a quart depending on the parts store. Dump it in their and call it good
    Skunny likes this.
  12. Feb 2, 2024 at 6:05 AM
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
    I run Lucas 85W140 in my TRD OR. Simply due to this article from ECGS, its a good read.
    https://eastcoastgearsupply.com/ft-2536-ecgs-gear-oil-recommendation.html
    winkel likes this.
  13. Feb 2, 2024 at 1:56 PM
    TnShooter
    Deogee
    STOCK
