Rear bumper sensor faded to white
Discussion in '3rd Gen. Tacomas (2016-2023)' started by marcamos, Mar 12, 2025.
  1. Mar 12, 2025 at 8:00 AM
    marcamos
    marcamos [OP] Well-Known Member
    Marc
    Beverly, Massachusetts
    2021 Off Road 6MT
    I realize this is fairly unimportant, but my truck is still 'mint' and I'd love to prolong that as long as possible. I'm a visual kind of person and seeing this irks me a little o_O.
    I'm guessing a black Sharpie type marker wouldn't hinder the sensor's functionality? Or, maybe it would? Has anybody tinkered with this?
    BraveRifles3 likes this.
  2. Mar 12, 2025 at 8:12 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    curious what guys say – mine have done the same
  3. Mar 12, 2025 at 8:15 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Ultrasonic sensors use sound waves to tell the distance between 2 objects.
    I doubt coloring it with a Sharpie would interfere.
  4. Mar 12, 2025 at 8:36 AM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer), Factory/TSB OEM rear leaf spring modification.
    Before using the sharpie, confirm the threshold for the alarm to trigger when backing toward something, and then apply a small round piece of black tape and repeat the test to see if it was affected. You could also try a very thin piece of clear tape and use the Sharpie to fill it in. This will allow you cleanly reverse everything if it affects the sensor.
  5. Mar 12, 2025 at 8:39 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I personally wouldn't use tape or paint or anything that has thickness to it, as that may block the frequency or give inaccurate readings.
  6. Mar 12, 2025 at 8:42 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    The internet has aftermarket replacement sensors for pretty cheap. No experience with them, but worth looking into if you want to keep things clean, else stocks are ~$100/ea :/
    I would imagine adding some black vinyl or a thin coat of paint over top wouldn't affect it much, but definitely worth testing with to see. Painted sensors aren't uncommon.
    marcamos[OP] likes this.
  7. Mar 12, 2025 at 9:47 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Aftermarket sensors are $12.99. OEM is a lot more expensive.
    https://www.amazon.com/Premium-Reve...ocphy=9032883&hvtargid=pla-2283222588405&th=1
    My sensors are still black after 9 years. Does your rear bumper get hit with lots of direct sunlight?
    marcamos[QUOTED][OP] likes this.
  8. Mar 12, 2025 at 10:41 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    We paint the sensors on collision jobs when they come primed. One or two coats of base and one of clear is just fine. If you put too much, Toyota/Lexus systems will give you a message saying the sensor is dirty.
    A sharpie shouldn’t hurt it.
  9. Mar 12, 2025 at 10:51 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I wasn't sure on the paint part.
    My 2016 doesn't have them but I use ultrasonic sensors at work for measuring distances of 0.024" and less. At those ranges a layer of dust can throw it off.
  10. Mar 12, 2025 at 11:06 AM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
  11. Mar 12, 2025 at 11:08 AM
    marcamos
    Marc
    2021 Off Road 6MT
    I appreciate the link! And, yes, it does get hit with direct sunlight — probably about 60% of its life.
  12. Mar 12, 2025 at 11:08 AM
    marcamos
    Marc
    2021 Off Road 6MT
    This is helpful to know, thank you!
  13. Mar 12, 2025 at 11:59 AM
    TA2016
    Oregon
    That is what I was thinking. My Tacoma is generally in my garage. Before I retired in my work parking space the front of my Tacoma always faced to the west.
  14. Apr 7, 2025 at 12:42 PM
    marcamos
    Marc
    2021 Off Road 6MT
    Just wanted to report almost a month later: I used basic Sharpie brand permanent markers. It looks fantastic and nothing has changed with regard to the back-up sensor's functionality.
  15. Apr 8, 2025 at 7:15 PM
    Gerrrr
    Gerrrr Well-Known Member
    Jeremy
    Ottawa, Canada
    2017 Blazing Blue Metallic (Limited 2013 Silver Streak DC Auto - Retired)
    Starting over.......
    I can also confirm the sharpie method - have done it for a couple years before trading my 2017
  16. Apr 9, 2025 at 3:28 AM
    099
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    I like the white.
  17. Apr 9, 2025 at 6:55 AM
    Williston
    New England
    A small sticker that fits and looks like an eyeball staring back at you would be a good fix for a faded sensor...
    (...especially if it had a tiny LED mounted just above it.)
    bmg88201 and Willy Lump Lump like this.
  18. Apr 9, 2025 at 7:09 AM
    boston23
    boston23 Well-Known Member
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    Dry erase marker
  19. Apr 9, 2025 at 8:11 AM
    bmg88201
    bmg88201 Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    I like the eye ball, it would give folks behind ya the creeps.
