Rear bumper compatibility
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Newfiebruh, Apr 22, 2020.
  1. Apr 22, 2020 at 9:36 AM
    Newfiebruh
    Newfiebruh [OP] Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    Hey guys. So my rear bumper is a rusty mess and I’m looking to swap it out. I seen this one on Amazon and I was just about to order it but I’m receiving really conflicting messages. Does anyone know if this bolts up to a Tacoma without the oem hitch ? I see some people say it does and others say it won’t. Really don’t wanna blow 600$ and it not work.
  2. Apr 22, 2020 at 10:08 AM
    ImMrCrash
    ImMrCrash Intermittent Error
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Bilstein 5100’s Dakar CS047R Supreme Suspension U-Bolt flip kit Sumo Springs Blue ADV Fiberglass Fenders 1st Gen Snorkel DV8 Apex Plate Bumper X-Bull 13k Winch KC HiLiTES 6x9 Trail-Gear Sliders 4x Innovations LCA Skids Spidertrax 1.25” Eagle Alloy 16x8 4” BS Fierce Attitude M/T 315/75R16 Bearcat 980SSB CB
    I am not familiar with how the bumper attaches without the hitch but I can hopefully throw some useful info at you.
    With tow package Tacoma’s, the bumper is mounted to the hitch which is then mounted to the frame:
    Red and green are one piece, I only did 2 colors for clarity. Blue indicates the mounting holes.
    TacoPandaTRD and Newfiebruh[OP] like this.
  3. Apr 22, 2020 at 10:11 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    I'm not sure if this helps you but my truck came without the OEM hitch and I bought one and put it on there. Didn't have to mess with the bumper at all in the process, just lined it up with the holes and bolted it on.
    So it seems to me that the bumper and hitch are independent of each other, but could be wrong.
    Edit: I have the 3500lb class III hitch, the class IV might be different.
    Newfiebruh[OP] likes this.
  4. Apr 22, 2020 at 10:12 AM
    Newfiebruh
    Tom
    so it looks like it will be mounted using 4 bolts instead of 6. Which probably isn’t an issue considering how my oem bumper must be only using 4 bolts without the hitch
  5. Apr 22, 2020 at 10:14 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Yikes i would never run that bumper if it only mounts to 2 locations on the hitch :eek:
  6. Apr 22, 2020 at 10:16 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Check out BAMF bumpers. $549.00 brand new and top quality product. Good luck.
    Slick Taco likes this.
  7. Apr 22, 2020 at 10:19 AM
    ImMrCrash
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    What? With the stock hitch it mounts identically to the stock bumper. 6 bolts.
  8. Apr 22, 2020 at 10:21 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No experience with a 2nd gen, but I'd advise one to steer clear from Amazon bumpers when there are so many aftermarket companies that support all Tacoma generations.
    I'm sure some of you remember this last one - https://www.tacomaworld.com/threads/aftermarket-vijay-front-bumper-trouble.659642/
    TacoPandaTRD and Mully like this.
  9. Apr 22, 2020 at 10:22 AM
    Mully
    CA
    This.
  10. Apr 22, 2020 at 10:22 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Looks like it mounts to the hitch that is mounted to the frame.... Only 2 bolts on each side to connect it to the hitch?
  11. Apr 22, 2020 at 10:25 AM
    Newfiebruh
    Tom
    My buddy was saying he bought some Jeep stuff off of Hooke road before. He hasn’t had any complaints. I’m just more so concerned about fitment. I put in the order just then, but if I hear something bad I’ll just cancel it
  12. Apr 22, 2020 at 10:25 AM
    Newfiebruh
    Tom
    Also keep in mind this is 500 in CAD not USD
    ImMrCrash likes this.
  13. Apr 22, 2020 at 10:30 AM
    ImMrCrash
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    2 bolts per side as well as the 2 in the middle that hold it to the hitch. Because yes, I would agree with you that in the case of a hitchless mount (if compatible) would only allow for 2 per side which I would be more worried. Are you thinking about force being applied if you slam it on rocks or pulling on the bumper in the event of a recovery or?
  14. Apr 22, 2020 at 10:33 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    100% or a crash that thing is gonna be a huge damage mutiplier. Bet the quality of the metal sucks too...
  15. Apr 22, 2020 at 10:41 AM
    ImMrCrash
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    By that logic the hitch is a damage multiplier, and because of physics, crumple zones, and all the other Toyota safety features. It works as intended to redirect force to protect the vehicles occupants.
    Yes, this bumpers weld quality is sub par. For durability I would put it somewhere right in the middle between a stock bumper and a quality bumper. It only weighs a little more than stock so it makes a great replacement, especially if you just want to get rid of an old rusty bumper.
