Rear brakes won't bleed
Discussion in '1st Gen. Tacomas (1995-2004)' started by derektaco, Mar 3, 2021.
  1. Mar 3, 2021 at 9:22 AM
    derektaco
    derektaco [OP] Well-Known Member
    1995 tac
    gotta 2.7l 4x4...1995...
    got the front brakes to bleed no problem, and when I go to the back, nothing coming through either bleeder valve. I gotta tube running out of the bleeder valve into a clear bottle of clean fluid. my pops is in the truck pumping brakes, and when I loosen valve, no air or fluid is coming out. of either wheels. why ideas??
    Black DOG Lila likes this.
  2. Mar 3, 2021 at 9:27 AM
    02hilux
    Planet: EARTH
    Use a pick or something small and poke into the bleeder screw. I'd seen it plug up so well that it wouldn't bleed before.
  3. Mar 3, 2021 at 9:27 AM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Portland, Oregon
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    Could be something with your brake load proportioning valve, do a search and you’ll get some more info.
    JudoJohn and jbrandt like this.
  4. Mar 3, 2021 at 9:37 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Do you know if your rear brakes have been working properly? Or are you bleeding them to troubleshoot why they aren't working?
    As said above, you may have an issue with the LSPV. It's this thing (stolen from another TW thread):
    Try bleeding that, too. If you aren't getting air/fluid out of that, your problem is likely farther forward. Maybe a clogged or pinched line from the ABS module/master cylinder.
    I wouldn't think that both rear bleeder valves would be simultaneously clogged, but that's possible, too.
    derektaco[OP] likes this.
  5. Mar 3, 2021 at 9:37 AM
    derektaco
    1995 tac
    my parking brake is applied...I wonder if that has anything to do with it...
  6. Mar 3, 2021 at 9:39 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I don't think it would or should, it's just a cable. Been a few years since I've bled my brakes though
  7. Mar 3, 2021 at 9:40 AM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    Why'd you start bleeding with the front brakes?
    derektaco[OP] and eon_blue like this.
  8. Mar 3, 2021 at 9:41 AM
    eon_blue
    Azusa, CA
    Good catch, always go from furthest away from the MC to the closest
  9. Mar 3, 2021 at 9:45 AM
    eon_blue
    Azusa, CA
    Hm interesting, I've always heard to start from furthest away from the master cylinder and work your way up. Anyway, I don't think it would result in your rears not bleeding though.
    derektaco[QUOTED][OP] likes this.
  10. Mar 3, 2021 at 9:46 AM
    derektaco
    1995 tac
    yeah, I misread the instruction and started bleeding from right front wheel. hmmm.... yikes. now what
  11. Mar 3, 2021 at 9:47 AM
    derektaco
    1995 tac
    cause I'm new at this... haha, and I misread the instruction.
  12. Mar 3, 2021 at 9:51 AM
    derektaco
    1995 tac
    I think I'm gonna take off parking break, try bleeding the lsp, and if all else fails try to clean out the rear bleeder valves. I don't see how starting from the front would cause this problem since they are dedicated lines...
  13. Mar 3, 2021 at 9:52 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    If your truck is lifted without LSBPV
    extension bracket the rear brakes get no fluid.
    AND
    The weight of the truck must be on the rear axle if wheels are off the ground by jack or stands.
    @derektaco
    Rastopher and derektaco[OP] like this.
  14. Mar 3, 2021 at 9:55 AM
    derektaco
    1995 tac
    truck is lifted...I bought this used. I'll have to check to see about that extension valve you are talking about black dog. there is plenty of weight in there bed at the moment... my old cylinder head and other shit I replaced, haha
  15. Mar 3, 2021 at 9:58 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Take the rear bleeder out completely while there is pressure on the brake pedal. If you get a bunch of fluid coming out and pedal goes to floor, you will know the bleeder is clogged. If not, work backwards to the distribution valve.
    regnos likes this.
  16. Mar 3, 2021 at 10:02 AM
    Black DOG Lila
    Virginia
    Bracket extension would be in center of rear differential where the BPV actuator rod ends.
    3" lift= 3" extension
    6" lift= 6" extension ( KIDS don't try this at home )
  17. Mar 3, 2021 at 10:08 AM
    derektaco
    1995 tac
    here is my setup. I am really unsure what the extension part is...
    it's a 3 inch body lift
  18. Mar 3, 2021 at 10:12 AM
    eon_blue
    Azusa, CA
    That's the LSPV, the bleeder valve is right there on the left with a little rubber cap on it like the others.
    The LSPV extension bracket is added when you lift the rear, so the LSPV isn't thrown out of whack. Helps retain normal rear braking ability from what I understand. They look like this and get added on the back of the rear axle. Be really easy to make one yourself, just lifts the arm up a bit.
    Black DOG Lila and derektaco[OP] like this.
  19. Mar 3, 2021 at 10:12 AM
    derektaco
    1995 tac
    another angle of differential
    appears mine weren't added...
  20. Mar 3, 2021 at 10:16 AM
    Black DOG Lila
    Virginia
