Rear Brake Shoe Wear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Norilsk, May 9, 2021.
  1. May 9, 2021 at 10:49 AM
    Norilsk
    Norilsk [OP] Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    So I did changed my brake shoes, both cylinders and drums about 8,000 miles ago. Checked today on the driver side and I am seeing this wear, passenger side doesn’t have this kind of wear.
    I have 35s, and separate e-brake handles (for sharper turns), but do I rarely use e-brake unless on trails.
    Bad wheel bearing or something else going on? Adjusted few times in the 8000 mile of driving but it keeps wearing down on the front shoe of the driver side only. Thoughts?
    7B4AF5DA-57C6-44DF-8F82-1370D52BCAD8.jpg A36653C6-0960-48CE-BA2B-50B924257ED6.jpg 4C189E65-4685-42E0-8593-39A10FB3E627.jpg
  2. May 9, 2021 at 11:11 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    I had an Oldsmobile years ago that had a similar issue and it turned out to be that I had installed a spring incorrectly and hooked it over the wrong groove on one of the shoes causing one to push out against the drum every so slightly. It wasn't enough to even notice when driving or spinning the wheel by hand on the jack and the brakes worked fine otherwise. No idea if that is your issue or even possible on these brakes but throughout it might be worth throwing out there.
    Bleep100 likes this.
  3. May 9, 2021 at 11:23 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Check the moving parts.
    cruxofthebisquit likes this.
  4. May 9, 2021 at 11:35 AM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Also check the brake cylinder and that the pistons are returning completely. If one is hung up partly out that shoe will be partially engaged. Might be easy to measure piston depth and compare the left and right side brakes.
  5. May 9, 2021 at 11:36 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Looks like the shoe needs to hang a little higher so it's centered in drum better. How? I don't know, count me as one of the ones wondering why Toyo still uses drums.
  6. Aug 9, 2021 at 8:35 PM
    HappyValleyView
    HappyValleyView Active Member
    2007TacomaBase4CylAuto
    NONE
    " . . . the shoe needs to (be) centered in drum. . . "
    What he said! The shoes should be concentric with the drum. Get another set of shoes and replace these so that the shoes are centered in/concentric with the Drum. Not sure just what - but something was not replaced properly.
  7. Aug 10, 2021 at 12:18 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Back when dinosaurs roamed the earth and I was wrenching, most brake jobs I did were drums and sometimes we would get a shoe that wasn’t concentric. We had a machine that we could put the shoe in that had a sanding drum on it to true up the brake material to make it concentric, if it was too bad like yours, we replaced the shoe. I’d replace the shoe and monitor it every few thousand miles it see it it looks okay.
  8. Aug 10, 2021 at 4:02 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    Back when I was a lad, I saw a lot of trailing brake shoes that wore more quickly than the leading one. I'd say yours's is normal, based upon my experiences.
  9. Aug 10, 2021 at 4:29 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    Well the first thing I would do is check the wheel cylinder moving both sides of the piston at the same rate. Watch the wheel cylinder pistons while someone moves the brake pedal down [SLOWLY AND NOT ALL THE WAY. [BOTH SIDES SHOULD MOVE TOGETHER] Also put some lithium grease on the backing plate where the shoes are resting. A loose wheel bearing would cause this to some degree. Just lift up and down on the axle shaft while the drum is removed and check for any lateral movement. I would suspect if this were the problem you would have gear oil leaking out. Good luck..
  10. Aug 10, 2021 at 4:32 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    I will answer that question for you, Toyota uses drum brakes in rear because they are less prone for problems where climates are bad in the winter time where salt is used. [TRUE STORY>> PARKING BRAKE ISSUES]
