Rear Bilstein 5125 vs B110 Q's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Griffin13, Jul 7, 2019.
  1. Jul 7, 2019 at 7:30 AM
    Griffin13
    Griffin13 [OP] Well-Known Member
    2013 Tacoma SR5 DCSB Texas Edition
    OME 884 Coils. GeneralSpringKC 90-297HD Leafs. Bilstein 5100's all around, front set at 0. Toytec 1/4" top plate on driver's side. Leer 100XR Camper Shell. OEM Bed Mat.
    Looking to swap my 5100s out back for an upgraded shock that will allow me more travel. Ihave an uncommon choice of the GeneralSpringKC hd leafs that gave me about 2.5" of lift over stock.
    The 5125s are supposed to be for a 2-3.5" lift which is where I fall but would there be any advantage in going for the b110's? They provide more travel but are suggested only for 4-6" lifts. Wouldthey be too long for my mild lift in the rear?
  2. Jul 7, 2019 at 7:32 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Which 5125s are you looking at? I ran b110s with my deaver springs and could flex them out that was about 3" lift.
    Dampahee likes this.
  3. Jul 7, 2019 at 7:35 AM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    I’ve got about 3” of lift and replaced my 5100s w/ the B110s.
    My advice- unbolt the rear shocks and cycle the rear suspension up and down. Take compressed and extended measurements. And go from there.
  4. Jul 7, 2019 at 7:58 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    This.
    OP. even though the general springs might give you some lift, they are likely not much thicker of a leaf pack than stock, meaning your compressed shock lengths are not going to be longer than stock. You ABSOLUTELY DO NOT want the shock to bottom out before you compress bumpstop.
    Personally i have always hated how they advertise "for x amount of lift" as thats no way to properly place a shock.
    I can pretty much guarantee that the B110's are going to be too long. The 5125 pn=33-230337 are 15.02 in collapsed, 1 inch longer than stock. Which might be too long still if the general spring pack isnt much thicker than stock.
  5. Jul 7, 2019 at 10:35 AM
    Griffin13
    The leaf packs measure right at or maybe a hair over 2" thick. Not sure what the OE ones were.
    How would I go about cycling the suspension so that I can measure? How would you all suggest I compress and extend it to get these measurements?
  6. Jul 7, 2019 at 10:39 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That’s way too much work.
    Slap on the b110 and some extended brake lines.
    Then bolt a hockey puck onto each side where the bump stop hits. This limits up travel by exactly 1” and is all you need to keep from bottoming out shocks.
    Or use it as an opportunity to get aftermarket bumps like wheelers or timbren because this also limits uptravel a little bit over stock.
    ovrlndkull likes this.
  7. Jul 7, 2019 at 10:41 AM
    Griffin13
    That was my plan, just trying to get second opinions before I fork over the cash.
  8. Jul 7, 2019 at 10:43 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It’s well worth it. I had the b110 and +4” brake lines and I was thoroughly impressed with the articulation over stock.
    This is with Dakar leaf springs.
    https://www.instagram.com/p/Bnb1b6-Hk63/?igshid=1kgsrnuuwdsai
    JSlamson and crackils like this.
  9. Jul 7, 2019 at 10:53 AM
    nd4spdbh
    SoCal
    OE ones are probably a smidge under 2in, so similar in thickness.
    Go find a stump or something to lift a tire up, take a measuring tape Measure from eye of shock to the bottom washer, take down measurement. Note if bumpstop is hitting the frame (sometimes it can be hard to get full compression), if its not hitting the frame, measure the gap between bumpstop and frame. Subtract it from first measurement. There is your absolute max compressed shock length NOT accounting for bumpstop compression (subtract at least a half inch from the max compressed shock length for bumpstop compression, more if you have non OEM ones). You could do this on level ground as well, but you will get more accurate measurements by articulating the truck as best as possible (due to how the shocks mount at angles and how the axle swings a lil during articulation).
    DO NOT DO THIS.... eat sleep tacos has leaf packs that are easily 1.5in thicker than the generalspring / stock springs.
    OP measure twice cut once....
    steveo27 likes this.
  10. Jul 7, 2019 at 10:54 AM
    Griffin13
    I got the idea by looking at some of @singletrack_ftw 's posts. I believe he has the medium Dakar packs. Not sure what lift this gave him but the b110s, he credits, for giving him much greater travel.
    Extended brake lines and bumpstops are already on my short list in preparing for a shock upgrade.
  11. Jul 7, 2019 at 10:59 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Good luck cycling a full leaf pack completely with a stump or something. The normal way is to strip the pack down to the main leaf only then use a block or shims to get the rest of the height of the pack. Plus when you cycle it on a stump or rock it isn't as accurate as cycling as I described since you also articulate the chassis when you have a full spring pack to contend with.
    What Randy is saying is you can bump the up travel and limit it. Stack one hockey puck or 3. Or you can order longer bumps from toyota bumps, space the stock ones, buy some HD daystar ones, etc. there are many options. A Dakar pack isn't that thick even with all the AALs you can add.
  12. Jul 7, 2019 at 11:00 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    You'll be good he wheels the shit out of his truck too!
  13. Jul 7, 2019 at 11:03 AM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    OME standard duty dakars yield about 2.75” rear lift without significant added weight and they flex like crazy. They’re a no-brainer rear leaf pack IMO. If you’re loading down with a ton of weight then get the heavy Dakar pack instead. But the standard duty pack is economical, super flexy & a great pack. I have better flex with my humble Dakar pack, b110, superbumps & brake lines than most guys spending a TON of money on fancy shocks and just AAL or even just fancy shocks that are too short. I made a thread to show you how SHORT basically all shocks are in comparison to the b110.
  14. Jul 7, 2019 at 11:03 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I just went and put a tape measure on mine, and they’re right at 2.5” thick, sooooo.
    I had to limit uptravel by maybe 1/3” but I did 1” to be safe. OP will be just fine following my advice.
    ovrlndkull and singletrack_ftw like this.
  15. Jul 7, 2019 at 11:04 AM
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
  16. Jul 7, 2019 at 11:06 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    My fancy shocks though are bigger than your b110s :boink::anonymous:
  17. Jul 7, 2019 at 11:17 AM
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    B110's all day, just do it. I had the same question, said F'it and threw them on. poor mans extended travel rear suspension.
    Griffin13[OP] and ovrlndkull like this.
  18. Jul 7, 2019 at 11:34 AM
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    Your fancy shocks ARENT OE DIRECT REPLACEMENT BOLT IN and require SIGNIFICANT fab work and other supporting modifications and purchases. :)
    ovrlndkull[QUOTED] likes this.
  19. Jul 7, 2019 at 11:37 AM
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    Your fancy shocks also aren’t $190/pair :D
    EatSleepTacos likes this.
  20. Jul 7, 2019 at 11:39 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Multiply that by 4.5 :rofl:
    But but but :(
