Rear Bearing Gear... Manual Transmission trouble
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Julian, Mar 12, 2020.
  1. Mar 12, 2020 at 9:34 PM
    Julian
    Julian [OP] 92yota
    Julian
    Inland Empire, CA
    1992 Toyota Pickup DLX V6 Manual 4WD
    |• 255/80/R17 Toyo R/T Tires on 2nd Gen Tacoma Sport wheels| |•Bilstein 4600 Series Shocks|
    Does anyone know where I can locate this part? I'm in the middle of rebuilding a r a60 2005 Tacoma Tacoma V6 Manual transmission. I believe it is called the rear bearing gear and I need this in order to complete the rebuild
  2. Mar 12, 2020 at 11:35 PM
    TacoTuesday1
    FL
    Why replace a gear? Gears are not usually wear items, as opposed to synchros, etc.
    Why not re-use the original one?
    Gears are usually expensive, at least with other cars, to the tune of around $200 per gear
    Hopefully Toyota has an OEM parts catalog that breaks down the transmission into pieces that show part numbers to order components individually
  3. Mar 13, 2020 at 2:37 PM
    Michaelo
    Michaelo Well-Known Member
    Michael
    PNW
    2014 Regular Cab 4x4 5 Speed
  4. Mar 13, 2020 at 3:31 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    What symptoms was this trans showing. I have a 2WD RA60, makes a noise in 6th gear.
  5. Mar 13, 2020 at 3:45 PM
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    That is multiple parts, not a gear assembly.
    33321. From that link of yours except "view other images" and choose image 3. My guess.
  6. Mar 13, 2020 at 6:45 PM
    gearcruncher
    Canadain bumper technician
    I believe that part has been superseded to a different gear assembly altogether and may be why the OP cant find that actual part number anymore . These transmissions have had many internal parts upgraded over the years .
    I believe the cone clutch for the synchronizer is also part of the gear assembly . If he had a harsh shift into 6th gear , the complete gear with those dog teeth ( cone clutch ) would need to be replaced
  7. Mar 13, 2020 at 7:10 PM
    Taco'09
    Taco'09 Well-Known Member
    OP, what you are showing is actually the output shaft and 5th gear along with an integrated syncro for 5th. It does not look like an output shaft because the threaded part with the notches engages in the transfer case drive differently than what you might expect to see on a 2WD that actually has a splined shaft.
    That whole thing is an assembly and can not be taken apart with the exception of the tapered roller bearing you show.
    Let me offer some advise to you about the bearing(s). That bearing on the output shaft rides in a race pressed in the rear case; there is then a second tapered roller bearing and race opposite it just below the crush sleeve. Together they serve to set the output shaft in a proper position but are set with a slight bearing pre-load near the end of assembly using the big nut to tighten against the crush sleeve (called the spacer) which in turn pushes against the second roller bearing.
    I replace both bearings because it has been my experience that that area in the rear of the RA60 collects junk and it has no where to go so those bearings take a beating.
    Make sure you get a couple of crush sleeves as they are a one-shot deal and can not be reused. An extra nut would not hurt either a you have to stake the thing and they can get a bit mangled.
    If you like send me your VIN and I will help with the correct part numbers. Also, do you have the FSM pages to follow?
    You may have to PM me as I do not check into the forum much and a PM should generate an email to me.
    gearcruncher likes this.
  8. Mar 19, 2020 at 4:19 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    As was said, it's the output shaft. The gear is actually the output reduction gear from the countershaft, and so the teeth only see forces in any gear except 5th. That said, 5th gear is simply when the input shaft is directly connected with the output shaft, and so the synchro and dog teeth on the output shaft are for 5th gear.
    Here are the part numbers:
    33302-35022 - Shaft, Output
    90366-50097 - Bearing, Output Shaft Front
    90366-50089 - Bearing, Output Shaft Rear
    90364-33012 - Bearing, Input Shaft to Output Shaft
    35469-35030 - Spacer, Output Shaft Bearings (Crush Sleeve for Bearing Preload)
    90179-48004 - Nut, Output Shaft Stake
    If you are looking for the 5th gear synchro/hub/sleeve bits and pieces:
    33369-35060 - Synchro, 5th/6th Gear (Qty: 1 ea)
    33364-35061 - Sleeve, 5th/6th Gear
    33393-35061 - Hub, 5th/6th Gear
    33371-53010 - Spring, Hub Key (Qty: 3)
    90360-05010 - Ball, Hub Key (Qty: 3)
    33366-35060 - Key, Hub (Qty: 3)
    90520-3302# - Snapring, Input Shaft Rear (#: 2=2.10mm, 3=2.15mm, 4=2.20mm, 5=2.25mm, 6=2.30mm, 7=2.35mm, 8=2.40mm)
    Jeff
  9. Oct 27, 2020 at 8:55 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Any updates on this? Since the worn bearing that rides in there also rides directly on the tail of the input shaft, the input shaft may need replacement, too. 2WD transmissions have a better oil supply into this area via a little oil receiver/paddle scoop that forces more oil into the center of the shaft. As more of these need rebuilding, we can surely produce some upgrades that will prevent failures like this.
