rear alignment
Discussion in 'Suspension' started by The_Hodge, Nov 19, 2008.
  1. Nov 19, 2008 at 11:31 AM
    The_Hodge
    The_Hodge [OP] Volunteer Moderator
    SC
    anyone heard of the rear being out of alignment on these trucks? the firestone place said my rear end was WAY outta wack. asked if i had been hit in the rear or taken a nasty smack to it. said i may need to see a frame shop or even the dealer. it drives and looks completely fine. i didnt take any hits to it this weekend and there's no places of even rubbing under there. i may wait until i get the front coilovers and the 3" rear leaf pack to have them do it again. just odd
  2. Nov 19, 2008 at 11:36 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I've heard that the rear can get out of alignment, but I've never heard of anyone having problems with their Tacomas. I think it is time for a second opinion.
  3. Nov 19, 2008 at 11:38 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The only vehicles I've ever known to get rear-end allignments are those with IRS (Independent Rear Suspension). Solid axles don't have anything to adjust in terms of toe/caster/camber.
    Unless they're looking at the relation of the axle to the frame being *square* or within spec. If your frame was tweaked, that would affect the axle placement (and/or bent axle tube would also).
    But highly unlikely if the vehicle hasnt' had any accidents.
    I'd definately get a second oppinion. Play like a stupid consumer....and take it to the Toyota Dealer and ask them to check the allignment under warrantee. Tell them - "This other shop told me my frame was bent"
  4. Nov 19, 2008 at 11:38 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Yeah i would get a second opinion, or like you said wait for that lift.
  5. Nov 19, 2008 at 11:43 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Since there is probably nothing to adjust, did they try to give you a quote on an alingment?
  6. Nov 19, 2008 at 11:43 AM
    MsTRD
    MsTRD hell yes i love my truck
    Samantha
    Rohnert Park, CA
    06 White Prerunner TRD Sport
    a week after i bought my truck i went in for an alignment and they told me the same thing. i knew it had been in an accident so they figured it got smashed pretty good. they said instead of the axle sitting straight it was diagonal, kinda hard to explain. but it needed a $300 part to fix before they could do the alignment. i called the dealer i bought it from and they got it fixed for me and now its driving fine.
  7. Nov 19, 2008 at 11:56 AM
    The_Hodge
    SC
    nope. i've got the lifetime alignment from them, so they're all free
    this one is an 09 thats only 3 months old, so definately not from an accident, but i can take it to the dealer and see whats up...and happy b-day, hotness...lol
  8. Nov 19, 2008 at 12:00 PM
    MsTRD
    Samantha
    Rohnert Park, CA
    oh yeah i guess i should have looked at what year your truck is. hopefully the dealer will take care of you! and thank you :)
  9. Nov 19, 2008 at 12:00 PM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    I have never head of a rear alignment problem. Not gonna lie that doesnt even make sense. IFS makes sense being not aligned but with a solid axel in the rear how could it be out of alignment?? :confused:
  10. Nov 19, 2008 at 4:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Bend the frame, bend the Leaf spring mounts, etc.....Anything that screws up the mounting of the axel can cause it to be out of alignment.
  11. Nov 19, 2008 at 4:15 PM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    Hell all you got to do is get the hot wrench and then beat it square, a good redneck should be able to do this. LMAO
    but the sound either fishy or the factory screwed it up.
  12. Nov 19, 2008 at 6:38 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    apparently, there were a few problems with the 06 i had, and the rear being out of alignment alot. and everytime i got an alignment at the stealership....they charged me for a 4 wheel alignment. i wasnt aware that you could align a solid axle...........other than it being off from you replacing the springs or being in a wreck.
  13. Nov 19, 2008 at 7:59 PM
    Janster
    Jandy
    Lancaster, PA
    What exactly was 'out of allignment' in the rear? Did they give you a spec sheet with data on it? They probably told you that they gave you a 4 wheel allignment but you only actually got 2wheel allignment.
    You really can't allign a rear solid axle. They can 'check' the overall placement of the axles in relation to the frame - but if something is *out of allignment* (as they call it) means there's something wrong with the frame, suspension, suspension mounts, or axle itself. There's nothing that can be adjusted for camber, caster, or toe.
    Changing springs in the rear doesn't change the allignment of the axle to the frame unless the springs are twisted or messed up to begin with.
  14. Nov 20, 2008 at 2:18 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah...i know. i was kinda being a smartass. they charged me for a 4 wheel alignment every time i got an alignment done there.
