Rear air suspension
Discussion in '1st Gen. Tacomas (1995-2004)' started by El_Best_Hamon79, Aug 29, 2023.
  1. Aug 29, 2023 at 8:21 PM
    El_Best_Hamon79
    El_Best_Hamon79 [OP] Well-Known Member
    Abraham
    04’ Tacoma Prerunner
    Rear bed lights
    So my rear shocks are blown and I haul a lot for work so I wanted to go air ride. Any ideas of an easy install set up? I got a 2004 Tacoma prerunner double cab 5ft bed. I would like one where I can control it with a remote and has an air compressor in it and such. I haul on average about 400-600 pounds 3 days a week. It’s 260,000 miles on it so it’s definitely old.
    Edit: I should add that I have recently put fox 2.0 in the front and I have billsteins in the back from the previous owner, but I’m not sure how old they are.
  2. Aug 30, 2023 at 4:25 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I am sure with some research You can find something that will work.
    There is a huge difference between Air Ride Suspension and Air bags to supplement your leaf springs Air bags instead of extra Heavy Duty Springs or a Helper spring set up.
    If I understand you want a air ride suspension just scaled down to fit your Tacoma ?
    New Shocks set up to your air ride suspension would most likely be needed.
    Are you just looking for air bags to supplement your leaf springs ?
  3. Aug 30, 2023 at 6:06 AM
    El_Best_Hamon79
    Abraham
    Rear bed lights
    I was thinking of keeping the old leaf springs and just going with Icon shocks with air bags to help it when it sags. But I’m new to this so I want to make sure I buy the right stuff. Also, do you have any rear shock recommendations that don’t require leaf springs to go with it?
  4. Aug 30, 2023 at 6:14 AM
    Bivouac
    Very hard to know without the suspension travel information.
    Just how you need to locate and mount your shocks also effects things.
  5. Aug 30, 2023 at 6:20 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    I often carry around 700 lbs. OME Dakars with the extra leaf, nitro chargers and the Firestone airbags (with cradles not connected) fit the bill just perfectly for me. I just use a bike bump to pump the bags up when needed.
    cfpfour, Cushmaat and Bivouac like this.
  6. Aug 30, 2023 at 6:25 AM
    Bivouac
    1000 pounds never really bothered my heavy duty springs with my super springs .
    Xbeaus[QUOTED] likes this.
  7. Aug 30, 2023 at 6:33 AM
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    I have Ride Rite airbags. Install was relatively easy. I also use a bicycle pump to adjust pressure when needed.
    Fill valves next to license plate.
    Xbeaus likes this.
  8. Aug 30, 2023 at 6:35 AM
    Bivouac
    Just how much pressure do you need to raise the suspension with 1000 pounds of weight??
    How long does it take ?
  9. Aug 30, 2023 at 6:48 AM
    soggyBottom
    soggyBottom Well-Known Member
    I have air bags in my Tacoma. Originally, I used a bike pump but it got really old. Since you're doing this so often, a dedicated compressor would be really nice to have. Mine is mounted behind the driver's side rear seat. The gauge and switch are mounted under the arm rest.
    I bought this compressor somewhere else other than Amazon and saved quite a bit on it. Sorry I don't remember where I bought it.
    I rarely tow anything with mine. I primarily use it when I put my camper and roof top tent on. I have once towed a short distance with an 8000lb trailer. I was getting gravel, and they put way more than I asked for. The truck handled fine, I wasn't going very fast.
    airmaxxx Air Compressor & Black Air Gauge Kit For Over Load Tow Control or Train Horn https://www.amazon.com/dp/B074XMJ9ZY
    Cushmaat likes this.
  10. Aug 30, 2023 at 6:51 AM
    Cushmaat
    SE AZ
    Shit, I am not sure. I actually use them for towing my trailer with camping/hunting equipment on it.
    I roll unloaded with about 6.5 psi on them (5 is min. according to instructions).
    To get to over 15 (my gauge only goes to 15), I usually only need 10-ish strokes on the pump (giggity). It goes fast!
    I usually hook the trailer up, drag to a level spot, and pump-to-level. Never weighed my tongue weight, so I cannot say how much I have on there (but gotta be 500-600 lbs). I try to put most of my load (giggity) over the trailer axles, but make the tongue weight heavy enough that I cannot easily lift it alone. Tows fine.
    I have been known to stop roadside and adjust where I have things on the trailer if I feel sway or light steering. It's a balancing act to get it right. Too much tongue weight is better than too light for me.
    Bivouac likes this.
  11. Aug 30, 2023 at 6:53 AM
    Cushmaat
    SE AZ
    Agree...if changing pressures often, I would get a dedicated on-board air system.
  12. Aug 30, 2023 at 12:24 PM
    El_Best_Hamon79
    Abraham
    Rear bed lights
    How much did the set up run you?
  13. Aug 30, 2023 at 12:55 PM
    Xbeaus
    Beau
    I spent roughly $1500 on all of it. Got everything from toytec out of Denver, CO. Shipping wasn't even that bad. $100 for shipping of all of it. I had a few extras. Extended brake line, greasable shackles. Did all the work myself so that saved me about the same I bet. Also - I ordered one of those load proportioning valve extenders as the lift pushed it up some. About 3" of lift I would say or right under that. Chopped my exhaust off on the end as well as it interfered with the new leaf packs.
    Bivouac likes this.
