Rear air bags, how much lift?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thumpertx, Feb 25, 2019.
  1. Feb 25, 2019 at 4:14 PM
    thumpertx
    thumpertx [OP] Well-Known Member
    2003 silver TRD4X4, 2017 quicksand TRD 4X4
    I put Air Lift brand air bags on my old Gen one long ago and when the bags are inflated to the minimum pressure that they recommend you keep them at [5-7lb] , it raised the rear of the truck [empty] almost an inch. For those who have added air bags to 2016+ Taco's, did the minimum pressure lift the rear of your truck?
  2. Feb 25, 2019 at 4:37 PM
    sdfuller88
    sdfuller88 Well-Known Member
    Reno, NV
    Using air bags in the rear will be taking the load off of the springs. You should only be putting air to them when your hauling loads unless you don't mind the lift and stiffer ride. Depending on the airbag diameter, I could see 5-7 psi lifting the rear an inch or so.
  3. Feb 25, 2019 at 5:09 PM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    Air Lift requires a minimum of 5 PSI, regardless of current load
    eurowner likes this.
  4. Feb 25, 2019 at 10:35 PM
    sdfuller88
    Reno, NV
    So the air bags don't bottom out or something? I guess that makes sense. At the same time I would think that your bump stops would hit before the air bags bottomed out though.
  5. Feb 26, 2019 at 10:13 AM
    thumpertx
    With the firestone air bags, you cut the bump stops off because that is where the air bags go. Bothe brands require that you keep some air pressure in the bag.
  6. Feb 26, 2019 at 10:55 AM
    Mikeybuck
    Mikeybuck Well-Known Member
    SW WA
    2018, 2010, Tacoma
    I have firestone bags on my double cab short bed Tacoma. In the bed I have a headache rack, a tool box with less than 100 lbs of gear and the Toyota bed mat. 4-5 psi, maybe a 1/4 inch "lift".
  7. Feb 26, 2019 at 11:45 AM
    BountyOR_VF2
    BountyOR_VF2 "If in doubt, flat out!"
    NorCal Bay Area
    2017 WHITE TRD TCSB OR
    How much are they? I'm interested to get this!
  8. Feb 26, 2019 at 11:56 AM
    eurowner
    eurowner Duke Sky
    Scoty
  9. Feb 26, 2019 at 3:56 PM
    BountyOR_VF2
    NorCal Bay Area
  10. Feb 26, 2019 at 4:31 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Nope. I have each bag on its own line and fill valve with a pump.
  11. Feb 26, 2019 at 4:38 PM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    If you run the Daystar cradles and run 5 psi (minimum) I could see the bag not even hitting the cradle, thus not lifting rear at all.
    Might be an option for ya.
    The traditional airbag setup limits shock travel by 20% and can make for a stiff ride when traveling with an unloaded bed.
  12. Mar 15, 2019 at 12:37 PM
    bigbear1612
    bigbear1612 Well-Known Member
    Gary
    2018 Toyota Tacoma TRD 4X4 silver sky metallic
    Ride Rite airbags with onboard compressor, Trail Ridge towing mirrors, 28,000 gwv external transmission cooler, Roll n Lock bed cover.
    Daystar cradles will void the lifetime warranty on the Firestone Ride Rites.
  13. Mar 15, 2019 at 1:16 PM
    Nevin
    Washington
    So what. Comfort over 300 bucks man.
    Waxifari likes this.
  14. Mar 15, 2019 at 2:59 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    :goingcrazy:
    With Daystars, you will love the extra flex Firestones provide not being tied top to bottom to the axle. The lifetime warranty is not as big a deal, as long as someone is careful when installing them and checks them whenever the car is put on a hoist to be sure cradle alignment is good, they should never have issues with them.
  15. Mar 15, 2019 at 3:06 PM
    OnHartung'sRoad
    I run mine like this too- but also get a short piece of airhose and attach a quick release female air hose end to both sides to make a auto pressure leveling tool for whenever you refill or deflate the airbags- it levels them perfectly without needing a pressure guage. It works great!
    See post #100137 for pics and details:
    https://www.tacomaworld.com/threads...-3rd-gen-today.399305/page-5007#post-18610063
    Skydvrr likes this.
  16. Mar 25, 2019 at 11:41 AM
    bcopley1116
    bcopley1116 Member
    Blake
    WV
    2018 Tacoma TRD Offroad
    I have a decked box and will soon have a camper shell so I'll have a little sag in the rear. I'm trying to decide on an aal or the ride rite bags, my truck is stock suspension and I don't tow anything, but I have 350 pound or so in the bed at all times. Also can a small 1/2" front plate spacer be installed to level out the front with the airbags?
