Realistic Towing Capacity....
Discussion in 'Towing' started by SmittyTruck, Mar 17, 2018.
  1. Mar 17, 2018 at 7:33 AM
    SmittyTruck
    SmittyTruck [OP] Member
    2012 Tacoma TRD
    So many confusing strings....all good information but I'm looking for specific information on whether my 2012 Tacoma (4dr, 4wd) TRD will tow this trailer. Going on a 2 week vacation across country this summer and many more!!
    Trailer is Apex 245BHS:
    UVW 4546[​IMG]
    Hitch Weight 578
    Carrying Capacity 2003
    GVWR 6500
    Ext Length 27'6"
    Fresh Water, Grey Water and Waste Water all 30 gallon tanks
    Getting a Blue Ox Swing Pro on it.
    Is this trailer too big and heavy to haul?
    djgynee likes this.
  2. Mar 17, 2018 at 7:54 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Yes. Too much. My buddy actually tows the same trailer. He used to have a F150 (could do something like 8K#), which did fine...now has a 250 (16K#)...
    Tacoma is something like 6400# capacity. I dont think its safe to max it out and cross country, but I bet you some will say its ok, and "I've towed 7500# here", or "Ive done blah blah internet"
    edit: here you go.. all the stories: https://www.tacomaworld.com/threads/2013-toyota-tacoma-4x4-v6-6-400-lbs-towing-capacity.259281/
    SmittyTruck[OP] likes this.
  3. Mar 17, 2018 at 7:56 AM
    awdvkd115
    awdvkd115 Well-Known Member
    Bud
    2017 Tacoma TRD OR
    Toytec lift, White Knuckle sliders, RCI Armour, ECGS (Nitro Gears), Victory 4x4 Striker Front bumper, Smittybilt X20 10K winch, Dobinson snorkel, Spidertrax 1.25 spacers and 255 R80 16 BF Goodrich KM2s.
    No, read your owners manual!
  4. Mar 17, 2018 at 8:07 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    If just pulling the trailer close to empty, but once you start adding stuff you will be at max capacity.
  5. Mar 17, 2018 at 9:19 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Either get a smaller lighter trailer or get a different truck. If you tow that trailer with your Taco you will regret it.
    tbird95 and SmittyTruck[OP] like this.
  6. Mar 17, 2018 at 2:55 PM
    airsavage
    airsavage Well-Known Member
    Butch
    2020 Tundra Sport 4x4 MGM, 2000 Prerunner
    Welcome aboard:hattip:. That is a bit big for a taco. Can you rent something in your area just to give you an idea of what the truck can do? Mine is right at 2 tons loaded ready to go.
    Tocamo and SmittyTruck[OP] like this.
  7. Mar 17, 2018 at 2:59 PM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Yup. Thats to the nuts and then some. Keep it around 4000 IMO.
  8. Mar 17, 2018 at 3:03 PM
    tcjacado
    tcjacado Well-Known Member
    Don't tow that trailer with your truck!
  9. Mar 17, 2018 at 3:21 PM
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    I will chime in on this one. I tow this...its also 25' sportsman, dry - 4575lbs, hitch - 480lbs, GVW - 6200. I have towed this camper everywhere. The trick is to keep it as light as possible when towing it. I towed this with my taco stock and it sucked bad. I felt very unsafe, so I upgraded my suspension and added airbags, break up grade, larger trans cooler. now the truck towes the camper like a dream. I never tow with any of my tanks full. After packing the camper for a week long trip from Rhode Island to Canada, weighing in at 5700lbs. the truck towed it well, it did struggle a little up hill in NY but I would down shift to 3rd and the truck pulled it up hill with no problem. I tow a lot of things for a living, so I feel comfortable towing this kind of weight and I know what to do if it gets away from me. the question you need to ask yourself is do you feel comfortable towing that kind of weight with your family in the truck. It can be done, but your truck needs to be set up properly to tow that kind of weight with our trucks. Hope this info helps...good luck and happy campingDSCN1807.jpg
    tbird95, stealthmode, Tocamo and 2 others like this.
  10. Mar 18, 2018 at 6:04 AM
    SmittyTruck
    2012 Tacoma TRD
    Glad I came across Tacoma World. This is the BEST and most straight forward information/advice I have gotten. Thanks to all of you for commenting. My work van is a 2012 Chevy Express 2500 Van (V8) and I will pull the trailer with that this year.....then I'm going to buy a new Toyota truck! Thanks again!
  11. Mar 18, 2018 at 6:25 AM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    To pull the TT? The new Tacoma has a smaller motor, so a Tundra may be in order.
  12. Mar 18, 2018 at 10:55 PM
    kybluejeep
    kybluejeep Well-Known Member
    Bryan
    2016 TRD OFFROAD 6SPD Manual
    I tow a X-lite 261 BHXL dry weight is close to 4900. I have towed through the mountains hear on the east coast in N Carolina, VA, TN, and Eastern KY. I can average 11-13 mpg when I am by myself but when I travel with my parents I average 9 or so, they have a Duramax and 5th wheel. I haven't had any issue with doing the speed limit but I do have manual.
  13. Sep 4, 2019 at 7:23 PM
    djgynee
    djgynee Well-Known Member
    Southern California
    2018 Magnetic Grey Metallic Tacoma DCLB TRD Sport
    Nice trailer BUT.. my 2018 DBLB is rated at 6600lbs. I couldn’t see risking as much as my truck cost plus a trailer like that PLUS if you got into an accident , your fault or not the FIRST thing that will be looked at is the guy with the trailer and was he over weight? Even if some jackass t-bones you... defense attorneys can be shady like that and somehow Shift some blame your way.
  14. Sep 4, 2019 at 9:10 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    It's not the weight of the trailer that's the problem, it the payload the truck can carry. Tacomas have a payload around 1,100lbs, add a 600lbs of tongue weight (6500lb trailer), that only leaves 500lbs for the rest of the cargo which includes people, pets and gear. I pull a a trailer with a dry weight of 4100 and loaded around 5200. With me, the wife, the dog and a 100lb generator I'm only 50lbs below my max payload.
  15. Sep 4, 2019 at 9:17 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I'm sure he's gone off and bought an f250 by now. A lot of time has passed since March 2018.
  16. Sep 4, 2019 at 9:40 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Wow, didn't even notice that.
