RCI slider installation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by k3ith99, Aug 18, 2023.
  1. Aug 18, 2023 at 4:06 PM
    k3ith99
    k3ith99 [OP] Well-Known Member
    2017 Tacoma TRD
    So I am supposedly getting my sliders delivered on Monday. I am leaving on a trip early Thursday and need to get them installed before I go. It will be just me dealing with the installation.
    My questions are, for those of you that have done it by yourselves, how hard was it? How long did it take? And if you had to do it over again, would you have it done at a shop instead?
    Also, any tips/advice would also be appreciated in advance. Thank you.
  2. Aug 18, 2023 at 5:36 PM
    Bertlow
    Bertlow Well-Known Member
    Alberto
    Tocoma
    It's esey if you have a couple of floor jacks leave bolt loos till you like the fitting of them then tork them down
    I think I put a jack on the bottom with a load on them to make Sure it was tight to the trucks Frame
    71tattooguy, tcjacado and k3ith99[OP] like this.
  3. Aug 18, 2023 at 5:39 PM
    tacomadome
    tacomadome Well-Known Member
    I did it on a lift and still managed to bend some washers overtightening some bolts. I also ended up cutting one in half for the rear drivers side since otherwise it didn't sit flush against the frame. Otherwise wasn't too much harder than expected. In some ways it might've been easier with floor jacks than on the 4 post lift.
    k3ith99[OP] and Bertlow like this.
  4. Aug 18, 2023 at 5:49 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Inventory your hardware as soon as you get them. They forgot the brackets in my order. Still able to install them, but not much support up front.
    I installed them myself in 2 hours with two Jack stands and a couple milk crates. You can prep the truck beforehand to make the install go faster. I washed the frame very well and coated it with metal protector to keep the rust potential to a minimum.
    Split_pea and k3ith99[OP] like this.
  5. Aug 18, 2023 at 5:56 PM
    tacomadome
    Should add I also sprayed the frame and sliders with Fluid Film as I installed, particularly the areas where they'd meet.
    k3ith99[OP] likes this.
  6. Aug 18, 2023 at 5:59 PM
    Pnciv66
    Pnciv66 Well-Known Member
    Louisiana
    When I installed mine by myself I used a long 2x4 under the slider on a floor jack to stabilize it. Lined up/got started an easy accessible end bolt then lined up the next bolt with the jack on the opposite end. The harder part for me was getting those front bolts in due the location inside the box portion of the frame.
    tcjacado, Chew and k3ith99[OP] like this.
  7. Aug 18, 2023 at 6:47 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    All the suggestions above are good allow at least 1 hour per side since you will be taking a couple things off before installing. Also if you don’t have a normal sized hand and wrist find some help with a real skinny hand and wrist. Since on both sides you need to bolt up a couple of places where you have to slide your arm almost up to your elbow in the frame. 2-4 floor jacks and some wood are a must before starting saves you a bunch of pain. Fluid filming or whatever you decide to use is a good idea before you slide the metal together.
    71tattooguy, Chew and k3ith99[OP] like this.
  8. Aug 18, 2023 at 8:25 PM
    Road Bull
    Road Bull Well-Known Member
    WA
    2022 Tacoma TRD OR; 2002 4Runner
    Do the drivers side first. Hope you have small hands and arms. The most forward mounting hardware is a bitch. (Box frame area) It’s all doable. It just takes patience.
    I would suggest looking at where the rear brake lines and mounting hardware overlap. All the post I’ve read just said to bend them out of the way. I would suggest to mount the bolt the opposite direction so the threads are not a friction point for the brake lines. I did that and put a little piece of rubber material between the bolt head and the brake lines.
    Mounting these is not that difficult overall. There should be a few moments that you might need to get creative trying to get washers, bolts, and nuts in place. If you have some tape handy, you can tape the stubborn bolts in place to make it easier to get the rest of the hardware in place.
    You got this and youIMG_0085.jpg IMG_0084.jpg IMG_0084.jpg IMG_0087.jpg will build some confidence doing it yourself.
    hinmo24t, k3ith99[OP] and r2pinter like this.
  9. Aug 19, 2023 at 6:59 AM
    k3ith99
    2017 Tacoma TRD
    Thanks for all the replies. A lot of good suggestions that I'll be putting to use. Hopefully it all goes well and on schedule.
    MadKatt likes this.
  10. Aug 19, 2023 at 12:02 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I’d look for another set of hands, that’ll make it less aggravating. Grab some beer and order a pizza, make it more fun than not.
  11. Aug 19, 2023 at 1:28 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    Your timeline is too tight to risk futzing around without help. Bolt-fittings follow Murphy's Law too often.
    Another person would be both a extra pair of hands AND someone to calm you down when one bolt is troublesome and can help remind you that you have already installed 18 of the 24 bolts. Pizza and beer is a small price to pay for that perspective.
    k3ith99[OP] and Chew like this.
  12. Aug 19, 2023 at 2:33 PM
    k3ith99
    2017 Tacoma TRD
    Monday afternoon makes it kind of hard for friends to commit - work interferes too often. :) But I will try them again Monday morning. :fingerscrossed:
    At least today I did a little of the prep - I was able to get all of the bolts I need to get to loosened. No impact wrench needed.
    Chew[QUOTED] likes this.
  13. Aug 19, 2023 at 2:53 PM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    It took two of us 4 hours. How can I say it . . . it's all straight forward it's just a giant PITA getting everything lined up and getting in hard to reach places.
    Definitely a couple of jack stands and something to rest the sliders on is helpful. But having someone hold them in place while you are getting the first few bolts in. Yeah, really I don't think I would attempt it by myself.
  14. Aug 19, 2023 at 3:05 PM
    k3ith99
    2017 Tacoma TRD
    If I had a larger time window it'd be much easier to get the installation arranged. As of now though, it looks like I'm going to be flying solo.
  15. Aug 19, 2023 at 3:12 PM
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    I would have taken it to a shop but was quoted $200 to install which seemed steep but they would of course put it up on a lift and have a couple of helpers and could probably knock it out in an hour.
    I would just wait until you get back and get help. Or maybe find a shop that won't rip you off - I don't know say $100 certainly not more.
    k3ith99[QUOTED][OP] likes this.
  16. Aug 19, 2023 at 3:33 PM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    I will add to use BLUE locktite on the bolts when you tighten them down. I didn't do that and after a fun day 4-wheeling I happened to push against a slider and it moved. I got under there and several of the nuts had backed off a bit, luckily didn't lose any. So I re-torqued them and added blue to all of them. Haven't had a problem since.
  17. Aug 19, 2023 at 3:50 PM
    k3ith99
    2017 Tacoma TRD
    I was thinking of doing just that. Thanks for the reminder.
  18. Aug 19, 2023 at 4:36 PM
    CM52375
    CM52375 Well-Known Member
    Cody
    Tennessee
    2024 Smoked Mesquite Limited Tundra
    You should have no issues getting these installed in a few hours. I installed mine by myself with no Jack stands or floor Jack. I used a bin that almost matched the height of the frame perfectly and allowed me to slide the slider in place and only had to lift up a little to bolt the first bolt in. It’s really not that hard of an install. Hardest part is wedging your arm in the frame to mount the forward most bolt. I will agree with other posters make sure to inventory all your hardware. They forgot to supply me with the hardware that sits in the cross member to mount the forward frame supports and took them a few days to arrive after contacting them. But other than that they have been solid. Good luck with the install!
  19. Aug 19, 2023 at 5:06 PM
    k3ith99
    2017 Tacoma TRD
    Hopefully my install goes as well as yours sounds like it did. And from what I've been reading, the front most bolt does seem to raise the blood pressure the most.
  20. Aug 19, 2023 at 6:07 PM
    TacoTrigger16
    TacoTrigger16 Well-Known Member
    Central Valley California
    2022 TRD OR 4x4 DCSB Super White
    Armor: RCI Plated 20 Degree Sliders RCI Full Skid Plates Steel RCI Fuel Skid RCI Rear Diff Skid SNS Designs ABS Guards Front Bumper: C4 Overlander with Full Hoops C4 Front Bumper Frame Support Brackets Bed: Total Chaos Bed Stiffeners Cali Raised Bed Light Kit Toyota Bed Mat Alu-Cab Contour Canopy Blue Sea 5025ST Fuse Block Blue Sea 4363 Switch Panel Victory 4x4 Front Bed Molle Panel Mountain Hatch Tailgate Table 3.0 Fire Extinguisher Shovel Axe Lighting and Electrical: PowerTrays Essentially BantamX Spod Bantam X w/ Touchscreen Baja Designs 30” S8 Light Bar Driving Combo Baja Design Squadron Sport Diving Combo Baja Design Squadron SAE Fleece all Lights On Engine: K&N Drop In Air Filter Mishimoto Intake Hose Toyota Air Accelerator Toyota TRD Oil Cap Toyota TRD Radiator Cap ECGS Bushing SDHQ Terminal Kit Fumoto Engine Oil Drain Valve AC Drain Mod Exterior: De-Badged Black Tacoma Tailgate Letters Heritage Badge In Black/Grey/White AVS Rain Guards AVS Aeroskin Hood Protector Lftd Customs Taco Sauce Gas Cap Holder Tacoma License Plate Frame Black Sylvania License Plate LED Lights R4T Bumper Caps Meso Customs Headlight Trim Plate Meso Customs V5 Ultimate Turn Signals SDHQ Ditch Light Mount Rago Fab Antenna Mount Interior: K&N In Cabin Air Filter Matte Black Steering Wheel Emblem Meso Customs Red Push To Start Meso Customs Vent Rings SW Meso Customs Climate Control Rings SW Meso Customs Interior Chrome Delete SW Meso Custom Minimalist Key Fob V2 SW Meso Customs Extended Fuse Cover AJT Designs Door Handle Covers Z Precisions Cup Holder Midland MXT275VP4 Yodaverse Interior LED Kit Yodaverse Center Console Organizer TacoMods Radio Knobs w/ Backlighting Headrest Paracord Grab Handles SOG Rapid Rescue Dongar Technology Mirror Adapter Garmin Dash Cam Mini 2 Baby Toyoda Square Center Console Insert WeatherTech FloorLiner HP Grey Expedition Essentials 3TPAM Ram Mount Accessories GoGettaGrip Shifter Knob Magnetic Mic Patches Suspension Lift: DuroBumps Front Bump Stops Icon Billet UCA’s Delta Joint All-Pro Sway Bar End Links Marlin Crawler HD LCA Frame Brace Bison Offroad Cam Stop Kit Total Chaos Cam Tab Gussets Total Chaos Cab Mount Chop Plates Total Chaos Spindle Gussets W/ Sway Bar Accutune Fox 2.5 DSC Front Shocks Accutune Fox Tundra 2.5 DSC Rear Shocks Accutune 2.5” Bump Stop & U Bolt Flip Deavers U402 Stage 1 Yota Mafia Rear Extended Brake Lines 24” ARB Carrier Bearing Drop Kit FK29 Archive Garage Hammer Hangers Archive Garage 3.6 Shackles Archive Garage High Clearance Cross Tube Wheels and Tires: SCS F5 16x8 -25 Offset 3.5 BS Gunmetal Mickey Thompson Baja Boss M/T 285/75R16 Gorilla M12x1.5 Lug Nuts ET Liftd Customs Leashed Valve Stem Caps Winch: Warn VR Evo 10-S Warn Wireless Hub Factor 55 1” Fairlead Factor 55 Rope Guard Factor 55 UltraHook Gray Tandem Offroad Control Box Mount LambTek Innovation Switch Bracket Kit Blue Sea Switch Recovery: Factory 55 HitchLink 2.0 Warn Epic Shackle x2 ARB Tree Saver 16’ Special Thanks to: Sibi Built for the lift installation. Tiny Rig Co for the Alu-Cab and installation. Accutune for the Fox Shocks with Adventure Tune. Baja Designs for lighting. C4 Fab for the front bumper. RCI for sliders and skids.
    I’ve done it twice now on 2 2022 OR. The bolt on the driver side electric box is tricky. I used jack stands and a jack. I got them to height with the jack and slide the stands to get them in place. Had a buddy help. It went pretty smoothly. I trimmed the frame caps with a Dremel. Mine are 20 degrees on a short bed for reference.
