Rav-4 wheels on 2005+ 5-Lug Tacoma ?
Discussion in 'Wheels & Tires' started by epa4wd, Mar 17, 2009.
  1. Mar 17, 2009 at 12:57 PM
    epa4wd
    epa4wd [OP] Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    Hi, I recently bought a 2009 2wd regular cab 5-Lug 15x6 (offset unkown) wheel Tacoma. So far in this forum and in the web I've been able to find the bolt pattern, and hub center (5-4.5 & 60.1) specs. I also know that for newer Rav-4 the wheel pattern and hub center is the same, but the offset is +45mm in a 18 x 7.5 wheel. My question is, I know that it should fit, but with the offset being +45mm would the wheels sit to much towards the inside???? I've read that for the 6-lug Tacoma and X-Runner (18x8) the offset is 30mm but they both have fender flares. I was thinking that since I don't have fender flares maybe they would look okay even tough they have a bit more offset.
    Let me know what your opinion is.
  2. Apr 6, 2009 at 10:29 PM
    chrismax
    chrismax Chris
    hawaii
    08 tacoma 4 cylinder auto.
    I didn't have the patience to do all the research.
    What I did do, is buy a set of factory alloys with tires off of an '02 Highlander and put them on my '08 Tacoma.
    They look great, filled up a lot of that empty space and got me a couple inches lift as well.
    I don't know what Toyota's marketing plan is by selling these trucks with such puny tires and wheels, the difference is pretty dramatic.
    If I have this truck long enough to wear the tires out I'll put an even higher profile replacement tire on these wheels.
    There's plenty of room for bigger.
    The added benifit besides the appearance is that the ride is softened up,
    quite a bit, being on a bigger cusion of air.
    Alamobrady likes this.
  3. Apr 7, 2009 at 2:48 PM
    TIM GAINOUS
    TIM GAINOUS Well-Known Member
    tallahassee fl
    o7 base desert sand
    tints,venvisors,low pro toolbox, readylift sst ,afe pro dry,dynomax muffler,sec air filter removed. jvc aresenal, with rear jvc 6x9's front blaupunkts.
    Where are pics chris? Sounds awesome man
  4. Apr 7, 2009 at 7:50 PM
    chrismax
    chrismax Chris
    hawaii
    The pictures don't really give you the full value of the difference between the two tire and wheel sets.
    If you can locate a good set of takeoffs from a Highlander I would go for it.
    As I said earlier it made a big difference in the ride as well as the
    appearance.
    I found mine on "Craig"s List".
    If you do find some and make the purchase you will also need to buy (20) lug nuts.
    Alloys and steel wheels fasten down differently.
    Check with a local auto parts store and they can tell you what they have or don't have that will work.
    I bought mine online, with shipping etc. it came to about $60.00.
    I'll get back to you with the name etc.
    If you go with the O.E.M. from Toyota you'll spend about $6.00 ea..
    Get um.
  5. Apr 7, 2009 at 8:09 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Those look pretty good
  6. Apr 8, 2009 at 4:43 AM
    TIM GAINOUS
    tallahassee fl
    o7 base desert sand
    Looks great. What size tire on the highlander? The wheels look like they shoulda from the factory.way to go
  7. Apr 8, 2009 at 4:07 PM
    chrismax
    chrismax Chris
    hawaii
    The tires that were on the alloys when I got them is P225/70R16
    My truck was delivered with P215/70R15.
    The difference in the height is 1.55", slightly more than 1 + 1/2"
    The difference in the added vehicle height above the pavement is half that, or .775", slightly more than 3/4"
    Go to Google and type into the search box "Skidmore Tire Sizing Charts"
    on the results page click on "Tire Sizing Charts"
    web address, www.skidmore.edu/~pdwyer/e/tire
    This website is devoted to Honda Element apparently.
    Disregard that, it's just the size charts you want to look at.
    This is where I got the info above.
    Not all the tire sizes listed are manufactured, checking any makers web site can probably tell you what's available.
    As to how wide you can go on that size alloy rim is info you would have to get from the tire store.
    It looks like the Highlander rims I got are 6.5" width, how wide a tire can go on these wheels is advice I would get from a tire store.
    The lug nuts I bought were from an E Bay seller.
    Search at E Bay "Highlander lug nuts", about 10 sellers will show.
    The ones I bought were from seller "massey 1946"
    The description at the add reads "Lexus Wheels Lug Nuts (20) for Highlander Good Length".
    These are long lug nuts and look better than the standards.
    I have read in the forum that some lug nuts, factory or others break revealing a smaller lug underneath.
    For this reason it seems wise to use a full depth socket and torqe wrench to fasten down the lug bolts.
    Also using anti-seize compound before putting on the lug nuts is good insurance so that you'll be able to get that flat tire changed in a hurry when eighteen wheelers are blowing past you on a dangerous highway.
    Good Luck, Chris
  8. May 24, 2009 at 11:01 PM
    JimKellyfan
    JimKellyfan Active Member
    da South
    09 Access Cab SR5 2.something
    ARE LSII Tonneau cover
    I am thinking to go with Cragar Rims and BFG T/A's on mine.
    255/60/15's ( slightly slower / larger )
    Kind of debating the warranty issues by size changing.
    Guess one would only have to worry if something bad happened, right ?
    Here's another link for size comparisons Also, Miata.net has one where it will show a Java picture during calculations.
    I like Chris' idea of the Highlander rims.
    Looks nice.
    I'm stuck on those Cragar's though.
    SS models or 2nd coice smoothies...
    SS
    http://www.cragar.com/ProductSearch.aspx?sc=submit&c=15&t=W&wRa=15&wRb=7&wBa=5&wBb=4.5&
    Did you find out the offset ?
  9. May 24, 2009 at 11:09 PM
    JimKellyfan
    da South
    Thinking about it, yet still uncertain...
    Wouldn't the lack of an offset ( 0 ) stick the wheels out further for a wider stance to handle better ?
    Here's a couple links to help you decide.
    This will really help you decide ( on offset choice ) here on Wikipedia
    http://en.wikipedia.org/wiki/Offset_(wheel)
    :cool:
  10. May 25, 2009 at 9:12 AM
    epa4wd
    Eduardo
    2019 SR
    JimKellyFan, I went with the X-Runner wheels they are 18x8 with 30-35mm Offset they sit flush with the fender, 0mm offset will stick them out of the fenders and this may cause problems.
  11. May 25, 2009 at 1:26 PM
    Tikabear
    Tikabear Member
    Memphis, TN
    2010 White V6 Double Cab Prerunner TRD Sport
    I just bought a set of 16x6.5 steel wheels from on '05 Highlander off Ebay. The steel ones may not be as attractive as alloy but they sure were cheap and the stock TPMS sensors should be transferable. Hope so. My goal was to get bigger tires so I'm hoping to go with a set of 245 70 16's or 245 65 16's when it's time. I'm just waiting on the stock ones to wear out.
  12. Feb 11, 2010 at 3:56 AM
    JimKellyfan
    da South
    Appreciate it.
    Sorry for the delay in reply, on the road a long time, but not anymore.
  13. Feb 11, 2010 at 4:15 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I have an 07 Rav4 sport with the 5 spoke 18s. I like those rims and think they'd look really cool on your truck...if the offset issue isn't an issue. If you are anywhere near Houston,TX you could drop by and do a test fit...
  14. Feb 11, 2010 at 4:59 AM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    What about X-runner wheels on a Rav 4 :)
    So I knowTacoma wheels fit on the older rav4
  15. Feb 11, 2010 at 7:08 AM
    epa4wd
    Eduardo
    2019 SR
    I went with X-Runner wheels but just the other day I found a Tacoma with Rav-4 wheels, here is the picture in case someone else is wondering:
    T@co_Pr3runn3r likes this.
  16. Nov 20, 2010 at 6:03 PM
    Headcase
    Headcase Active Member
    Mitchell
    Medina
    '10 Access Cab Manual-5 2.7L
    245 70 R 17's on Aluminum stuffed into the wheel wells
  17. Nov 20, 2010 at 6:11 PM
    m_yota
    m_yota Well-Known Member
    Paradise
    08 4x4 dbl cab
    K&N airfilter, HID conversion for headlights/fogs. Wet Okole Seat covers, Kove Aphex processor Kenwood comp 6.5" and 6.5"coaxial 5100 billy shocks 2.5", 1.5" fabtech AAL,Epicenter and MTX Sub, debadged, tinted, kenwood dnx812, black mesh grill, led ext/int.
    looks good.:)
  18. Sep 14, 2011 at 5:58 AM
    72Vette
    72Vette Member
    Andover, MA
    11 4Cyl 2WD
    Does anyone know if the offsets on the rav 4 wheels and the stock 15" tacoma wheels are the same?
  19. Sep 14, 2011 at 6:03 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Never saw this until now. Looks great! Thanks for bumping the thread to make it show up top in my subbed threads. Curiosity satisfied.......
  20. Sep 14, 2011 at 6:10 AM
    72Vette
    72Vette Member
    Andover, MA
    11 4Cyl 2WD
    I saw on street dreams website that they list wheels for the 2011 Tacomas at 34-42 mm. 3mm (to 45mm) is not a big difference.
