Rattle noise in overhead map lights....
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bubbleheaddiver, Oct 13, 2018.
  1. Oct 13, 2018 at 4:32 PM
    Bubbleheaddiver
    Bubbleheaddiver [OP] Active Member
    BEN
    2017 SR5 4x4 double cab
    Seems like a rattle in there.
    How do I remove that piece and plan to put some padding or tighten up the wiring in there.
    Does it just pop off?
    2017 Taco
  2. Oct 13, 2018 at 4:41 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Pull hard with your hands from the front edge first, then the back. The entire console snaps out, but be careful not to jerk it when it lets go. Push to snap back in.
    musicisevil and tcjacado like this.
  3. Oct 13, 2018 at 5:12 PM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    Virginia
    2019 Magnetic Gray TRD Off-Road 6 Speed MT
    Sounds like the only cure is to upgrade to MesoJDM’s map lights to fix it :D
  4. Oct 13, 2018 at 9:18 PM
    tJc
    tJc Well-Known Member
    Greater Appalachia
    Serious question... Do you keep sunglasses up there? I had a rattle and it turned out to be my sunglasses bouncing around if they weren't positioned "just right".
  5. Oct 13, 2018 at 9:34 PM
    Bubbleheaddiver
    BEN
    i honestly thought it was the same thing, but turns out it isnt
    tJc[QUOTED] likes this.
  6. Oct 14, 2018 at 12:09 AM
    jdmstuff
    jdmstuff Well-Known Member
    Derrick
    Torrance, CA and Las Vegas, NV
    '18 TRD OR DCSB AT, '08 TRD Sport DCSB AT, '03 TRD 3.4l 4x4 MT Supercharged
    I think I have the same problem. Do you know what is exactly causing this?
  7. Oct 14, 2018 at 6:07 AM
    Bubbleheaddiver
    BEN
    If I knew the answer I wouldn't ask how to questions.........
  8. Oct 14, 2018 at 6:22 AM
    StayinStock
    StayinStock She Shed owner since 1992
    Bob
    Missouri
    2018 OR 6AT
    Some
    Mine rattled some. I put a small, folded piece of business card on the edge until my next dealer visit.
  9. Oct 14, 2018 at 7:31 AM
    UAL777jet
    UAL777jet Well-Known Member
    Bill
    Norwalk, IA
    2019 Tacoma TRD Pro Voodoo Blue
    TRD Performance Air Intake
    I was going to diagnose mine, took it to dealer and they just replaced the whole unit. No problems for last 2 plus years.
  10. Oct 14, 2018 at 7:34 AM
    OnHartung'sRoad
    Bunch of this will fix it, no roof sounds either!:bananadance:
    https://www.amazon.com/GREAT-STUFF-Filler-Insulating-Sealant/dp/B0002YW0W0
    Actually, Toyota used a type of hot glue to stick wires onto the back of the headliner, if you can find the noisey cables, maybe a small line or dab of hot glue or silicone sealant put over the loose part of the wire bundle to just hold it down may help. I used craft hot glue to hold down a power line up there, works great.
  11. Oct 16, 2018 at 2:33 PM
    Bubbleheaddiver
    BEN
    Fixed rattle in overhead light, also rattle in dash which turned out to be the cover for the cabin air filter in the glovebox. Truck is quiet as a cucumber now!
    OnHartung'sRoad likes this.
  12. Oct 16, 2018 at 3:15 PM
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2017 TRD OFF-ROAD DCSB
    I can't figure out if mine is from the map lights or the rear view mirror.
  13. Oct 16, 2018 at 9:55 PM
    sdfuller88
    sdfuller88 Well-Known Member
    Reno, NV
    its probably a rattlesnake bro
    musicisevil and Jose_Dirte like this.
  14. Jan 12, 2019 at 9:14 PM
    codelemur
    codelemur Member
    Rob
    Huntsville, AL
    2018 TRD Sport
    Stock ... for now
    Did any of y'all ever get a solution to this? My new 2018 is doing it. Seems to be coming from the forward right side of the overhead console. If I wedge my finger (or something else) between the plastic of the console and the headliner, it seems to stop. Was going to have it checked on at my 5K service in a couple months, but curious if it was something easy.
  15. Mar 25, 2019 at 6:23 PM
    Sweetleu417
    Sweetleu417 Member
    2019 TRD OFF ROAD 6speed manual
    What was the fix for the overhead map lights?
  16. Mar 28, 2019 at 2:34 PM
    DESportTRD
    DESportTRD Well-Known Member
    2017 Blazing Blue Pearl DCSB Sport 4x4, MT
    I found my rattle noise yesterday after 2 years of driving. Pulled down the roof console that houses the sunglasses and houses the front dome lights. Found a metal retainer that goes around both sides and the front towards the windshield. On the passenger side the original “adhesive” from the factory was undone. Took a tube of E 6000 Transparent Glue (from Michaels Crafts, Home Depot, Lowe’s). Applied to metal braket., used spring clamps to hold in place against the headliner. I let it dry...set-up for two hours. Drove my truck around and over some rough roads.....noise was gone! Reinstalled the roof console. NO MORE NOISE of a rattle.
    Boyitz and Sweetleu417 like this.
  17. Apr 5, 2022 at 8:36 AM
    sfr4dr
    sfr4dr Well-Known Member
    Truckee/Tahoe CA
    Currently trying to pick my next Toyota!
    What did you do to resolve this? I have the same issue.
