Rattle coming from under hood...in time with engine speed.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vertrx7, Apr 12, 2019.
  1. Apr 12, 2019 at 5:50 PM
    vertrx7
    vertrx7 [OP] Well-Known Member
    Rolf
    Vehicle is a 2011 with the V6. Since last year, the vehicle has had a groaning sound when idling and accelerating. A mechanic at a shop i've used suggested it might be a bearing sound coming from the drive pulleys.
    Tonight, there is now a chattering sound coming from the front of the motor. It sounds like cards stuck into the spokes of a bicycle wheel that kids used to like to do. The sound is not just on acceleration like most of the posts I've searched. The sound increases with rpm. It is as clear on idle as it is under higher rpm's, its just faster.
    I'm wondering if there's an idler pulley or more that I should be looking at.
  2. Apr 12, 2019 at 9:15 PM
    junkyardyote
    junkyardyote Well-Known Member
    2010 4x4 sr5 4.0 crew cab/ 2023 TRD Offroad DCLB 3.5 auto
    I would def look at the pulleys. Spraw some wd on each and see if it goes away for a bit,dont go crazy though.
  3. Apr 12, 2019 at 9:20 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Pull the belt off and check the pulleys for binding or excessive play.
    whatstcp and Torspd like this.
  4. Apr 13, 2019 at 4:44 PM
    vertrx7
    Rolf
    Sounds like a plan! Thank you!
  5. Apr 14, 2019 at 12:17 PM
    vertrx7
    Rolf
    OK, so listening to it, its a clattering sound, coming from the driver side...I'm wondering if either alternator or AC compressor. When i turn AC on or off inside the cab, there is no change of sound. I'm not sure if the water pump makes that sound, but its almost really further left. Do alternators make a rattling sound like that? Would a stethoscope help in this regard?
    Pulleys make more of a squeeking sound from what I understand.
  6. Apr 14, 2019 at 12:24 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    You can use a mechanics stethoscope, or a piece of pipe to narrow it down.
    Thats how I narrowed down my bad alt.
    whatstcp likes this.
  7. Apr 14, 2019 at 12:48 PM
    vertrx7
    Rolf
    I'll get a stethoscope. Cheap enough at HF I guess. If it craps out, I'll use a long screwdriver. I did read that "turned out to be the top most #2 idler pulley was totally shot. It wobbled a bit on its axis and the bearings were completely toast. Sounds like a can of marbles." So, I guess it could still be a pulley. Off to HF.
  8. Apr 14, 2019 at 1:55 PM
    vertrx7
    Rolf
    Stethoscope gotten. Good advice all around. Put it on AC but it really wasn't making that chattering/marble sound. On alternator...bingo, marbles are making noise. Options are seeing about having this one rebuilt, getting a new/rebuilt one or buying a used one. I really don't want to let this one go so if they can be rebuilt, I'll go with that. I'm going to see about interchanges from another vehicle to see if I can get one from the local Pullapart...
    Rd62 and whatstcp like this.
  9. Apr 14, 2019 at 2:15 PM
    vertrx7
    Rolf
    Oh yeah! I'm going to replace the serpentine belt and the pulleys while I'm taking the time to do this along with alternator.
    wilcam47 likes this.
  10. Apr 14, 2019 at 2:26 PM
    avi8or_co
    avi8or_co Well-Known Member
    2019 Cavalry Blue TRD Sport, 2023 Lexus IS500
    Sounds ridiculous but check the hood prop rod....:anonymous:. Former car had a fkn rattling that I couldn’t find for the life of me and a mechanic buddy couldn’t either. Then once again I opened the hood to look and actually used the prop rod, rather than a 2x4 I have in the garage that I commonly use for the purpose. That’s when I found the plastic clip that holds it in place was broken....:frusty:
  11. Apr 14, 2019 at 2:31 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    sometimes its the pulley tensioner spring is weak and that will rattle or I think they have a timing chain/belt tensioner also its like a valve lifter that can also rattle. My 98 used to do that when I needed an oil change.
  12. Apr 16, 2019 at 5:06 PM
    vertrx7
    Rolf
    keeping this one updated for someone possibly doing a search later on. Took the alternator out. Had it tested at Advance. They spun it up, tested good, no sounds at all. Very quiet. So good news is I learned to take the alternator out and the alternator is good. Bad news is the alternator is out and needs to be reinstalled. Good news is I can get at the pulleys from below and above now! :)
  13. Jan 20, 2021 at 4:50 AM
    GP_spence
    GP_spence Well-Known Member
    AL
    2013 DCSB TRD Off-Road 4x4
    Did you ever figure out this issue?
