Rate my audio before I buy
Discussion in 'Audio & Video' started by venezian, May 11, 2022.
  1. May 11, 2022 at 10:47 PM
    venezian
    venezian [OP] Well-Known Member
    Los Angeles
    2022 7545E
    I originally wanted no part in cutting into the OE harness, but thanks to @DirtyGovnuh linking this, I can make my own T harness.
    I was also going to go the OEM Audio+ route for the simplest and most convenient route, but it feels like $600 for speakers and $1,000 for a PnP harness.
    I’ll soon have a 22 non JBL “premium”. I want to keep the stock HU and have no desire to add a sub.
    I am a novice when it comes to types of speakers, but comfortable with splicing, pulling panels apart, etc. I will be adding some sound deadening to the area of the door behind the speakers and speaker mounting area.
    All advice is welcome. If you think there are better speaker sets I should go with, let me know. A different amp? go for it. Am I missing any parts? I'm ok with spending up to $700.
    Amp - Kicker 47Key200.4
    Front Sp - Kicker 46CSS694 Component Sys (I'm sus the tweeters won't fit...)
    Rear Sp - Kicker 43DSC6704
    Amp wiring T Harness - Red Wolf Harness
    Tweeter Adapters - Red Wolf tweeter adapters
    Wiring Kit - 12g kit
    Speaker wires - 9-wire speaker cables 20ft
    Wire connectors - crimp + shrink butt connectors
    Sound deadening - Killmat 80mil
    MGMDesertTaco likes this.
  2. May 11, 2022 at 11:24 PM
    MGMDesertTaco
    The tweeters will work with the included metra adapters that Crutchfield provides with the 6x9 components, but you'll have to cut holes in the metra brackets. You might match the rear 6 3/4 with the csc fronts instead of those dsc's, but I don't think there's much difference.
    Funny those same kickers 6x9 components were recommended to me by one of their reps as I'm using the 200.4 key as well with a similar budget plan (or so I thought, closer to 1k now with soundskins deadening:annoyed:) They said that set provided the most bass at the price point. For a $700 budget with the key amp your speaker options are limited. Buy the best components you can afford that will pair well with the key. That's the bulk of your sound.
    I've heard the OEM Audio sets are nice, but your paying extra for plug and play. I looked at the JL JD400/4 amp for 279, but figured the dsp on the kicker would help the most with the factory head unit.
    I've chosen...
    Soundskins pro 2mm deadening
    Metra brackets/adapters/ Crutchfield 9 wire 20ft
    Kicker Key 200.4
    Focal RCX-165 rear doors
    CDT 4D widebands/ unity 8.0 for the front doors and dash.
    https://www.cdtaudio.com/main_series/wideband/wb_systems/wideband4d.php
    Reason for mixed brands is I originally planned on doing Focal flax, but didn't want to pay that much. Also, I ordered the front CDT's with the plan of BI-AMPing them, but decided to do the rear doors last minute anyway. Focal's were slightly cheaper than CDT's cl-6ex for the rear doors. Plus, Crutchfield included the adapters and brackets and the Focal's were rated at 60 rms vs CDT's 90 rms.
    https://www.cdtaudio.com/coaxials/cl6ex.php (get the 4ohm version if using key amp)
    Hopefully the key pumps enough juice for the front CDT widebands. :fingerscrossed::rockband:
    venezian[OP] likes this.
  3. May 12, 2022 at 3:24 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Those kicker CS are not my ideal choice so make sure you’ve listened to them before buying them. The titanium dome tweeter is HARSH. Legitimately gives me a headache, even at low volumes
    soundman98 and venezian[OP] like this.
  4. May 12, 2022 at 9:37 AM
    RDW59565
    RDW59565 Well-Known Member
    Utah
    2022 TRD Pro M/T Mag Grey
    ^^^Good recommendation here^^^
    Listen before you buy. The materials used in the tweeter cone have a big impact on the sound. One isn't necessarily better or worse...it is a preference thing. I prefer silk tweeters which are available in the Kicker KS series.
    soundman98 likes this.
  5. May 14, 2022 at 2:23 PM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    If I remember correctly Killmat has issues with heat tolerance. Might be better off with something like Noico - lots of folks here like it.
