Ratchet strap in lieu of a winch?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Volt, Dec 12, 2018.
  1. Dec 12, 2018 at 5:22 PM
    Volt
    Volt [OP] Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    Has anyone here had experience in using a heavy duty ratchet strap as a light duty alternative to a winch? There are heavy duty ratchet straps with two inch straps that sell for as low as $10. They don't weigh much and could store behind the seat. It appears that a large big rig ratchet strap might be useful in getting a Tacoma pulled up out of many less severe stucks in mud or sand.
    Anyone have experience with this?
  2. Dec 12, 2018 at 5:24 PM
    pop.tremuloides
    pop.tremuloides Well-Known Member
    Colorado
    2019 TRD OR DCSB
    DBACK HD, Armor, SP9100, lights...etc
    What is your intended use for it?
  3. Dec 12, 2018 at 5:24 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Your truck weighs double that just sitting. Imagine the weight when its stuck. Probably not a good idea to use a ratchet strap as a winch..
    Just watching out for your safety bud
    113tac and tinker_troy like this.
  4. Dec 12, 2018 at 5:24 PM
    MTSN
    MTSN Well-Known Member
    Denver
    17 Tacoma TRD Off Road
  5. Dec 12, 2018 at 5:29 PM
    pop.tremuloides
    Colorado
    2019 TRD OR DCSB
    If you are concerned about price...then look at something like a "Come along".....they are great in a pinch. I have one and have also used my Hi Lift to work when not wheeling with others.
    I would only trust a $10 strap to tie down things in the vehicle OR MAYBE get me a little, and I stress LITTLE, bit to get you to the point where you can drive out. DO NOT rely on them!
    TACOVRD, hiPSI and na8rboy like this.
  6. Dec 12, 2018 at 5:31 PM
    Georgia Native
    Georgia Native Well-Known Member
    4x4 DCLB 2017 SR5, 2019 4runner Offroad, 2021 SR Access Cab
    Hi lift and some chains.
    ddettamanti likes this.
  7. Dec 12, 2018 at 5:33 PM
    Georgia Native
  8. Dec 12, 2018 at 5:49 PM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    I have used a ratchet strap to get out more than once. I have also used one to strap two logs together an make a flip flop winch, and the other as the actual winch line.
    Volt[OP] likes this.
  9. Dec 12, 2018 at 5:52 PM
    pop.tremuloides
    Colorado
    2019 TRD OR DCSB
    NICE! But...the times that the Hi Lift will work have to do with PATIENCE and PRACTICE! Been there done that! Hi Lifts are GREAT! But you have to know how to use them properly AND practice with them. Don't be "that person" that attempts this on your first go around.
    Awesome video! I have watched it many times and it shows just how versatile the Hi Lift is....HOWEVER do not be fooled....it takes a LONG time to get a vehicle that is stuck hard out....it also takes TONS of repositioning and placing items (rocks, logs, etc) to prevent you rolling back. It is NOT easy but will work!
    Truck norris likes this.
  10. Dec 12, 2018 at 5:53 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I can't get stuck at Forever21
  11. Dec 12, 2018 at 5:55 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    What you need is a hub that bolts or locks on to the right rear wheel, it would look like a riding lawnmower wheel with out the tire on it. Then take a really long rope, put one end on your hook on your truck, then wrap around a tree and back to the hub on the rear wheel. Give one or two wraps on the hub then get in and floor it. The rear wheel spinning hub will wind the rope around the hub pulling you out. Easy peasy now to build my idea.
    smiles2 likes this.
  12. Dec 12, 2018 at 5:59 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    You're strapping something down with those right?
  13. Dec 12, 2018 at 6:03 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Problem isnt strength fundamentally, its mechanical advantage. Ratchet straps have a mechanical advantage of about 5 to 1.
    Come along has more like 10 to 1, 20 to 1 with snatch block.
    End result is it's hard to generate much more than 500 lb with a ratchet strap, even a big one. Come along will be able to get 2000 lb with similar handle force.
    The secondary issue is that there isnt much spool amount (to pull up out of a hole) with a ratchet strap. At least 10 times more with a come along or similar.
    Volt[OP] and tonered like this.
  14. Dec 12, 2018 at 6:09 PM
    Georgia Native
  15. Dec 12, 2018 at 6:20 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    https://youtu.be/trrEKbc6uqE
    SigBoy likes this.
  16. Dec 12, 2018 at 6:29 PM
    pop.tremuloides
    Colorado
    2019 TRD OR DCSB
  17. Dec 12, 2018 at 6:30 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Come-Along. I have had one for many.years and it can take the place of a winch to a point. Ratchet straps are to tie things down, not lif or pull.
    JoeCOVA and tonered like this.
  18. Dec 12, 2018 at 6:32 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Kind of expensive but the more power puller works awesome. Up to 12000 lbs of pulling power.
  19. Dec 12, 2018 at 6:33 PM
    Georgia Native
    Who knows. Pretty entertaining though.
  20. Dec 12, 2018 at 6:33 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Ratchet straps are handy for recoveries if you need to reseat a tire on a wheel, that's about it. I'd get a come along winch or a real winch (+ bumper)
