RAS Active Suspension vs. Add-a-leaf kits
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DesertTaco21, May 17, 2023.
  1. May 17, 2023 at 8:36 AM
    DesertTaco21
    DesertTaco21 [OP] Well-Known Member
    Kyle
    2021 Bule Tacoma TRD Off-Road
    None yet
    I keep seeing ads for this RAS suspension kit. All their promotional info and everything I can find on their site sounds like it's just an easier to install add-a-leaf kit. Am I missing something? Is there some sort of electric component, if not why would they be comparing themselves to airbags which are easily fine tuned?
    https://activesuspension.com/collections
    D.A.S. Taco likes this.
  2. May 17, 2023 at 8:52 AM
    eurowner
    eurowner Duke Sky
    Scoty
    RAS is an excellent system and much easier to install than the others.
    RAS is adjustable. No electricity.
    Hoksamoen likes this.
  3. May 17, 2023 at 9:42 AM
    DesertTaco21
    Kyle
    None yet
    Like on the fly adjustment or what? And how do you adjust them?
  4. May 17, 2023 at 9:47 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    You can adjust the preload on the spring. There are a couple disks...basically feeler gauges...in the box to give you an idea of 25-40% added capacity.
  5. May 17, 2023 at 9:48 AM
    eurowner
    eurowner Duke Sky
    Scoty
  6. May 17, 2023 at 9:48 AM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    i get their ad all the time. very intriguing system
  7. May 17, 2023 at 10:37 AM
    DesertTaco21
    Kyle
    None yet
    So its just a low cost alternative to air bags but with a set and forget mentality over on the fly adjustment? Sounds like good bang for your buck considering price if that's the case.
  8. May 17, 2023 at 11:52 AM
    AvockAdoo
    AvockAdoo Well-Known Member
    Sam
    Denver, CO
    '21 DCLB TRDOR
    I run them, they are awesome. They are "automatic" in the way that the more load you have in the bed, the more weight they take off of the leaf springs. I have mine set to 25%, and they make the truck ride more smooth unloaded and loaded. When I have all of my camping gear + 2 bikes on my truck, it still sits at dang near stock height.
    Hoksamoen and DesertTaco21[OP] like this.
  9. May 17, 2023 at 12:24 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I also run the Roadmaster active suspension on my truck. The set and forgot was the selling point to me. I am a mechanic and installed alot of airbag kits and a few add a leafs. Air bags work well but the issues for me were that usually after a couple years they were guaranteed to leak, you had to maintain them with air and unless i'm at the shop I don't readily have air at my home, you have to have two separate circuits for each bag for them to do their job right or when you take a corner the air will just flow from one bag to the other negating the purpose of them plus, I find air bags ride rougher. I've been running the RoadMasters for over 100'000kms, the only claim of theirs I can honestly debunk is the axle wrap claim. I haven't noticed anything if much for help with axle wrap, only solution for that I can see would be a stiffer leaf pack
  10. May 17, 2023 at 1:01 PM
    05 4x4
    05 4x4 Well-Known Member
    hmm, on their site it is currently on sale: *Limited Time | $80 OFF All Tacoma Suspension With Code: tacomaras
    Hoksamoen and D.A.S. Taco like this.
  11. May 17, 2023 at 1:03 PM
    05 4x4
    How much did it lift the truck?
  12. May 17, 2023 at 1:04 PM
    joba27n
    Nolan
    Alberta
    I got 3/4" lift in the rear from installing them
    Hoksamoen and 05 4x4 like this.
  13. May 17, 2023 at 1:04 PM
    05 4x4
    at what % tension? Thanks!
    joba27n[QUOTED] likes this.
  14. May 17, 2023 at 1:08 PM
    joba27n
    Nolan
    Alberta
    40% extra (2mm spacer)
    Everything else on my truck was stock.
    Only suspension mod i've done aside from these is the bumpstops to durobumps... very pricey but with the Roadmasters I feel they blend together pretty good for a less jarring ride
  15. May 17, 2023 at 2:29 PM
    eurowner
    eurowner Duke Sky
    Scoty
    I have airbags and have found no need to have on-the-fly adjustment.
