Raptor liner roller
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rachelsdaddy, Feb 19, 2023.
  1. Feb 19, 2023 at 5:07 AM
    Rachelsdaddy
    Rachelsdaddy [OP] Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    I decided to Raptor lind my truck, tinted emerald jade mica. I don't want to spray it because I'd have to cover everything in my shop, can't have overspray on the machines plus I'm gonna do it as time permits. Nose, cab then bed. What did you use for a roller cover and how well did it lay down? I will do the jams later or maybe not at all. Did it go well? Thank you
  2. Feb 19, 2023 at 5:13 AM
    Clearwater Bill
    Billy
    Largo Florida
    Visit www.monstaliner.com
    They have colors, product and hardware. As well as instructions and techniques.
    I know a couple folks who've used this and been very pleased with the durability.
  3. Feb 20, 2023 at 3:35 PM
    Rachelsdaddy
    Southern NH
    Do you know if it's tintable? Never mind Ill look into it..
  4. Feb 20, 2023 at 3:38 PM
    Clearwater Bill
    Billy
    Largo Florida
    I don't know. But it shouldn't be hard to find out.
  5. Feb 20, 2023 at 3:39 PM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    The roller that comes with raptor liner kits leaves very sharp peaks.
    treyus30 likes this.
  6. Feb 20, 2023 at 4:00 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Would highly recommend spraying if you want a controlled finish
    The overspray isn't quite as bad as atomized paint. I did mine in the driveway and most of the little droplets are on the floor within 2 feet of the truck, but I would still cover what you can ofc. Primer might be a different story.
  7. Feb 20, 2023 at 4:15 PM
    Brex69
    Brex69 Well-Known Member
    2023 Lunar Rock DC LB Off Road
    I just Raptor lined my ARE DCU camper shell. I used the Raptor sprayer and over spray was minimal. The texture came out awesome but I got a lot of streaks so I’m probably going to have a buddy of mine hit it with satin black paint, not sure if rollers would be less streaky.
    Check out Custom Coat at TCP Global they have a ton of different colors for bed liner. Be aware the the coverage sucks with this stuff, it took 3 quarts to paint my shell.
    Here are the rollers you need
    Custom Shop 4" x 1/4" Textured Bed Liner Roller Covers (Pack of 3) - for Roll-On Custom Coat Truck Bedliner Coating Application - Create Texture Effect with Paint and Non-Skid Protective Coatings https://www.amazon.com/dp/B09W41LD51
    Rachelsdaddy[OP] likes this.
  8. Feb 20, 2023 at 6:21 PM
    UncleStan
    UncleStan Well-Known Member
    02 Double cab Tacoma
    My buddy did his rocker panels about 3 years ago and it came out great. Sprayed it, still looks good today.
