Raptor lights on 2nd Gen OEM Grill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flyingcowboyy, Feb 2, 2025.
  1. Feb 2, 2025 at 8:14 AM
    flyingcowboyy
    flyingcowboyy [OP] Member
    2013 Gray Tacoma SR5 4.0 L 4X4
    1.25” spacers 2” lift 285/75R16 Toyo AT3 tires
    I’m wondering if it’s possible to install raptor lights on an oem grill.
    Is there an adaptor out there I can buy?
    Can I make one myself ?
    Thanks!
    TXpro4X4 likes this.
  2. Feb 2, 2025 at 10:39 AM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    I think you'd need to make your own bracket. I'd recommend using a 1/8" sheet of ABS plastic.
  3. Feb 2, 2025 at 9:43 PM
    AnotherDude
    AnotherDude Well-Known Member
    Great truck. Plenty of kits for 20-30 on Amazon.
  4. Feb 2, 2025 at 10:16 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Welcome to Tacoma world
    This^
  5. Feb 3, 2025 at 7:10 AM
    SigSense
    SigSense Well-Known Member
    13 TRD Sport DCLB 4X4
    Don't know if you consider these "Raptor" in the OEM grill, but this is what I did....
  6. Feb 3, 2025 at 7:48 AM
    flyingcowboyy
    Do you mind linking me one
  7. Feb 3, 2025 at 7:49 AM
    flyingcowboyy
    Sick, is that diy ?
  8. Feb 3, 2025 at 8:09 AM
    SigSense
    Yep, DIY. Took the grill off and spent a weekend plotting/planning and wiring.
  9. Feb 3, 2025 at 1:53 PM
    AnotherDude
  10. Feb 4, 2025 at 7:45 AM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, 16" TRD baja wheels, 265/75r16 BFG K02, 1.25" wheel spacers, TRD skid plate, N-Fab spare tire box mount.
    hoffengineering likes this.
  11. Feb 4, 2025 at 11:01 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    I used the same ones (I just bought directly from Oznium though). If you do go this route, get them through the Oznium site, they are cheaper than Amazon, even with shipping: https://www.oznium.com/led-bolts-prewired-leds/premium-side-view-led-bolt
    I don't have the OEM grill, but the process should be about the same. The Oznium lights are great because you can barely tell that they are there when off.
    I fab'd up a bracket that I attached to the inside surface of the grill with adhesive that holds the lights. The bracket was just a piece of galvanized 18-20 ga. flat bar (maybe 2 inches wide) that I drilled holes into to put the lights in the exact position I wanted. There wasn't enough space to get the holes where I wanted them on the grill itself (at least for my faux-pro grill). I painted the holes and any other cuts I made to prevent rust, as those surfaces are no longer galvanized.
    Been on the truck 4+ years, no issues. Here's my post from when I originally put them on:
    Saskabush[QUOTED] likes this.
  12. Feb 4, 2025 at 11:22 AM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Use side view LED bolts
