Raptor lights add-a-fuse question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rockbfss, Apr 6, 2022.
  1. Apr 6, 2022 at 5:28 AM
    rockbfss
    rockbfss [OP] Well-Known Member
    Tom
    KY
    ‘22 Lunar Rock TRD Sport 4x4 DCSB
    My raptor lights add-a-fuse came with 5/10 amp fuses. I've watched videos with 10/10 or 15/10 setups. Should I remove the 5 for either a 10 or 15? Thoughts?
    Thanks all.
  2. Apr 6, 2022 at 5:45 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    What is the current draw on your lights? If they are LED, I don't see the need to go any higher than the 5 supplied. And make sure the fuse you are tapping is a 10 and not a 20 or something higher/lower. Always match the fuse you are tapping.
  3. Apr 6, 2022 at 6:20 AM
    rockbfss
    Tom
    KY
    They are LED. Honestly I don't know the draw because my truck is arriving later this month. I'm just prepping a few mods. But I've seen comments that some raptor lights draw less than 1 amp (not sure if I have the exact raptor lights though), but yet I see videos of people using 10 or 15 amps.
  4. Apr 6, 2022 at 6:32 AM
    airforceb2cc
    Don
    KCMO
    You don’t need the truck to know what the draw is. Hook an ammeter up in line with the lights and a car battery. But if the manufacturer of the lights sent a 5 amp fuse to use, use it.
    Kev250R likes this.
  5. Apr 6, 2022 at 7:31 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    10 - 15 amps too much. 2A should work.
