Raptor light wiring/switch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dmwood1984, Feb 10, 2021.
  1. Feb 10, 2021 at 7:34 AM
    Dmwood1984
    Dmwood1984 [OP] Well-Known Member
    New Jersey
    2018 Cement TRD Off-Road Double Cab Long Bed Premium Package with Options
    Can someone point me in the right direction. I’m looking to wire my raptor lights on a switch instead of with the drl. Is there a how to for this somewhere? Wiring harness available? Is there somewhere to order a pen fitting switch labeled something like “raptor lights” or “grille lights”
    TacOCD likes this.
  2. Feb 10, 2021 at 7:52 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I’m guessing you have to wire the raptor lights to a relay and have the switch coming from the relay just like any other lighting accessory but that’s my guess. You can make a wire harness with a relay and fuse or you can buy one already made and wire up the raptor lights.
    TacOCD likes this.
  3. Feb 10, 2021 at 8:17 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Nilight - NI -WA 06 LED Light Bar Wiring Harness Kit - 2 Leads 12V On Off Switch Power Relay Blade Fuse for Off Road Lights LED Work Light, 2 Years Warranty https://www.amazon.com/dp/B071ZPX32...abc_S8NS4CHSQ6QDBJPATM4X?_encoding=UTF8&psc=1
    you could use a relay harness like this or just use a switch on the positive side or negative side as the raptor lights don’t draw shit for amps.
    TacOCD likes this.
  4. Oct 25, 2022 at 1:47 PM
    CoTacoTy
    CoTacoTy Well-Known Member
    White 2017 sr5
    TacOCD likes this.
