Random Blowing/Revving Sound When Idle
Discussion in '4th Gen. Tacomas (2024+)' started by MonkeyTaco12, Apr 25, 2025 at 2:46 PM.
  1. Apr 25, 2025 at 2:46 PM
    MonkeyTaco12
    MonkeyTaco12 [OP] Member
    2024 Tacoma TRD Off Toad Premium
    EDIT: Solved. Definitely either the radiator fan, climate control related fans, or both. I tested this by turning off all climate control settings and letting it sit and idle in park and it was dead silent. Surprisingly very quiet idle (maybe not since only 4 cylinder?). Regardless, thanks for everyone that replied. Glad to know its normal and not an issue.
    I have a 2024 Tacoma TRD Off-Road automatic. Just broke 2500 miles. Overall love the truck and I have no major issues or complaints.
    However since I bought it, I've noticed this loud blowing/revving sounds from the engine that only occurs when parked. Never in drive at any speed/RPM. I can't find anything similar to this online and nothing matches this description in the manual. See video links.
    Any help or insight is appreciated!
    https://youtube.com/shorts/02CBNPdSHNA?feature=share
    https://youtube.com/shorts/difoP7Lrqmk?feature=share
  2. Apr 25, 2025 at 2:58 PM
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    It's the radiator fan. They all do that. Not sure why. I assume it's got something to do with the fancy cooling system the engine has.
  3. Apr 25, 2025 at 3:01 PM
    avi8or_co
    avi8or_co Well-Known Member
    2019 Cavalry Blue TRD Sport, 2023 Lexus IS500
    Heard the gen 4s don’t have a mechanical fan bolted to the crank like a 3rd gen…it has an electric fan attached to the radiator itself. Thats not a bad thing necessarily as its one less thing to deal with if you need to work on the front of the motor like changing a belt, idler, ect.
    Thats probably what you’re hearing. Maybe pop the hood and have a look?
  4. Apr 25, 2025 at 5:28 PM
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    The puddle of water on the ground indicates the AC is running. Compressor kicking on and rev to match. Also radiator fan.
  5. Apr 25, 2025 at 5:54 PM
    balong48
    balong48 Well-Known Member
    2011 Silver 4Runner Limited
    100% the radiator fans. My wife’s RAV4 and every rental Camry with an A25A (somewhat sister engine to the T24) does it when not moving with the AC or defroster on.
    baron55 likes this.
  6. Apr 25, 2025 at 7:32 PM
    jay_zed
    jay_zed Well-Known Member
    16 TRD Sport 6MT, 24 TRD Offroad 6MT
    If you turn off AC and make sure you are not in Auto or Defrost mode, the cycling fan will stop. It is annoying, but this is how Toyota calibrates the electric fan on all of their vehicles now to periodically move a bit of air over the AC condenser.
  7. Apr 25, 2025 at 8:41 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Are you sure you don’t have a diesel engine that thing makes more noise than a 2GR-FKS.
  8. Apr 26, 2025 at 7:07 AM
    MonkeyTaco12
    I think you're right. Thank you
  9. Apr 26, 2025 at 7:08 AM
    MonkeyTaco12
    Yeah i think its a combination of the radiator and AC fan. The second video was with the hood open.
  10. Apr 26, 2025 at 7:09 AM
    MonkeyTaco12
    Yeah youre right because i tested it with all climate control settings off and it was silent.
  11. Apr 26, 2025 at 7:09 AM
    MonkeyTaco12
    No none of the 4th gen tacomas are diesel engines.
    t0p_d0g[QUOTED] likes this.
  12. Apr 26, 2025 at 7:12 AM
    MonkeyTaco12
    I think youre right minus the puddle. That puddle was there when I parked as I took this video immediately after parking and it was already there from a previous vehicle.
  13. Apr 26, 2025 at 7:14 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    I know they don’t have diesel engines I was just saying it seems very noisy to me. I have heard other members comment that the gen 4 sounds like a tractor. I was joking about the diesel engine.
  14. Apr 26, 2025 at 7:16 AM
    MonkeyTaco12
    Ah gotcha my bad. But yeah once i turned the climate control off it was a very silent idle.
  15. Apr 26, 2025 at 7:24 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    You have a nice truck and I’m thinking seriously about trading my 23 for a 25.
  16. Apr 26, 2025 at 12:07 PM
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    When I don’t have the AC on but my climate control is on auto, I still get puddles of water being discharged by a white tube under the body of the truck. Is this normal?
  17. Apr 26, 2025 at 2:43 PM
    baron55
    In auto, the climate control runs the AC. It is set to run the AC in Auto mode by default
  18. Apr 26, 2025 at 5:05 PM
    Taco Ji
    New Jersey
    Interesting. So even though I don’t turn on the A/C button, as long as the auto is set my ac is running.
  19. Apr 26, 2025 at 5:12 PM
    baron55
    When its needed to meet the temperature setting you have. Auto means Auto heat and AC. So, it either runs the heat or AC to meet the temp you set.
  20. Apr 26, 2025 at 5:23 PM
    Taco Ji
    New Jersey
    Ohh i need to read the manual more closely. Thanks!
