Rancho RS9000xl, SPC UCA and 285's
Discussion in 'Suspension' started by FishaRnekEd, Dec 24, 2022.
  1. Dec 24, 2022 at 5:41 AM
    FishaRnekEd
    FishaRnekEd [OP] Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    I'm just documenting, so that others can see.
    (Pics and videos below)
    https://youtu.be/V8JvcfBnfGw
    Rancho used to be "the shit" back in the 90's. They don't seem to be so popular today on tacomas. I have a few friends with 2500 trucks and these shocks have gone over 100k miles for them.
    I'm on a bit of a budget, and the old taco was really in need of a complete suspension overhaul (squeaking, clunking, etc), so here is what i went with
    I just finished installing this
    Rancho Suspension QuickLIFT Loaded Strut and Shock Kit For Toyota Tacoma 4WD 2005-12 - Includes Rancho Front Loaded Struts & Rear RS9000XL Shocks https://www.amazon.com/dp/B00P02S5XW
    I already had these on
    Spidertrax WHS007 Blue Wheel Spacer Kit https://www.amazon.com/dp/B00BGRDMOM
    I got the new forged UCA
    Specialty Products Company Tacoma UCA's (Pair) 25470 https://a.co/d/5V6MAx8
    I used these bolts
    TORCH 8.5" Square Extended U Bolts Extra Long 2.5" wide 9/16" Ubolt w Hardware https://www.amazon.com/dp/B099P38M5M
    These blocks
    Supreme Suspensions - 1" Rear Lift Blocks for Toyota Tacoma/Tundra/IFS Pickup/IFS T100 2WD/4WD - High-Strength Steel Rear Lift Blocks 9/16th Pin - Can Cooler Included with Purchase https://www.amazon.com/dp/B07YYG3R3P
    I had these leafs on for over a decade of pretending that my taco is a 2500... They weren't sagging, but i decided to replace them since i was doing everything else
    https://www.generalspringkc.com/200...ner-heavy-duty-rear-leaf-spring-4-3-1-leaves/
    I rebuilt the LCA's with these and Moog bushings and balls
    Moog K100128 Caster/Camber Adjusting Kit https://www.amazon.com/dp/B00HCQ5NYS
    I got these tires and had them delivered to Firestone
    https://simpletire.com/brands/multi-mile-tires/trail-guide-all-terrain#Trail-Guide-All-Terrain__4
    I have factory 16" wheels
    DavesTaco68 likes this.
  2. Dec 24, 2022 at 5:54 AM
    FishaRnekEd
    New Orleans, LA
    The old bushing sleeves on the LCA's wouldn't press out. The rubber was done, and pushed right out in the press, leaving the steel outer sleve fused to the control arm... That was fkin fun to remove.
    I removed the mud flaps and set the UCA's to position D. I used my calibrated eye to get the alignment good enough for the drive to the shop.
    The alignment shop was able to get everything straight without a hastle (fortunately, when i called, one Lady there had a lifted truck and knew what to do with the upper balls)
    The old truck rides great now and tracks straight, so far.
    I've got to drive for a few days and then get back underneath and check the torque on everything.
    There is no rubbing on flat ground at full lock.
    Looks like i might get some rubbing while turning over large bumps, but not on flat ground
    i will go take some pictures if it warms up in a little while.
    I drove around on some shitty roads, with the valves set to "1" which was waaaaay too soft. So, i set them to "9" on the way back. That was obviously a bit stiff, so i put the valves on setting "5" in all four corners.
    I'll probably screw with the settings and see if it rides better having the front/rear on different adjustments.
  3. Dec 24, 2022 at 6:25 AM
    FishaRnekEd
    New Orleans, LA
  4. Dec 24, 2022 at 6:27 AM
    FishaRnekEd
    New Orleans, LA
  5. Dec 24, 2022 at 8:02 AM
    FishaRnekEd
    New Orleans, LA
  6. Dec 24, 2022 at 8:06 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    The Rancho get good reviews, like any shock there will be some owners that had a bad experience. My Bilstein 5100 rear shocks puked oil with pretty easy usage.
    https://expeditionportal.com/field-testedrancho-rs9000xl/
  7. Dec 24, 2022 at 3:58 PM
    FishaRnekEd
    New Orleans, LA
    I had the Bilstein aswell. They were ok. But they weren't worth all the hype.
    DavesTaco68[QUOTED] likes this.
  8. Dec 25, 2022 at 8:17 AM
    CLT_Rick
    CLT_Rick Well-Known Member
    Nevada
    2021 TRDOR / 2016 TRDOR
    I ran Rancho 9000's on my JK and they were great....actually liked them better than my Fox 2.0's.
    FishaRnekEd[OP] likes this.
  9. Dec 28, 2022 at 7:56 PM
    BackOff
    BackOff Well-Known Member
    Derek
    The corner of Idiocracy and the Twilight Zone
    2004 SR5 4Runner V6 4x4
    Noise mods/Weight Mods
    I have had 9000xl on 2 different 4runners and they work just fine.
    I think the coolest thing about them is the "My Ride" system.
    Hooks a mini air compressor and remote to change the 1-9 setting on the fly.
  10. Dec 29, 2022 at 3:46 AM
    FishaRnekEd
    New Orleans, LA
    I saw that option, but went with the hand turn setting. I didn't want to complicate things.
  11. Jan 4, 2023 at 5:52 AM
    FishaRnekEd
    New Orleans, LA
    Update-
    I've been driving around on this setup for a few weeks now.
    The 6 speed really likes the 285's. I am adjusting my shifting and getting used to it. At 45mph, the rpms allow me to stay in 5th gear instead of teetering between 5th and 6th (on flat roads holding steady). at 65mph, in 6th gear, the engine is running about 400 rpms lower.
    The 4.0 handles the 285's just fine, with the stock gearing.
    i will update again after a few tanks of gas. I was averaging 15mpg combined before. I suspect that won't change. I'm probably eating more gas to accelerate, but possibly using less gas while holding steady (if traffic allows me to use cruise control)
  12. Jan 13, 2023 at 1:02 PM
    FishaRnekEd
    New Orleans, LA
    So far, the Multi-mile Trailguides seem like pretty good tires.
    Not too noisy
    Displace water and mud fairly well
    One complaint, they pick up and hold onto 1/4 to 1/2" gravel until maybe 50mph and then fling it.
    I'm shopping for a good material to make flaps out of, so i don't crack anybody's windshield.
  13. Jun 14, 2024 at 6:29 AM
    FishaRnekEd
    New Orleans, LA
    It has been a few thousand miles
    This set up has been exactly what i needed.
    it is a bit of a stiff ride, but i do like it stiff.
    I can haul about (40) 8"x4"x16" solid blocks in the bed and this setup handles it well.
  14. Jun 14, 2024 at 6:34 AM
    FishaRnekEd
    New Orleans, LA
