Ramps or jack stands?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rnish, Oct 8, 2016.
  1. Oct 8, 2016 at 4:48 AM
    rnish
    rnish [OP] Well-Known Member
    Tacoma 2nd gen
    Time for a upgrade. Ramps or jack stands?
    I'm about to pull the CCard out on a set of 4 ton jack stands. Reg $55, $25 off; $31 and change out the door @Sears.
    I have always used jack stands. Any reasons to consider "ramps"?
    http://www.sears.com/search=jack stand
  2. Oct 8, 2016 at 5:00 AM
    zonian
    zonian Well-Known Member
    Paul
    Knee Deep in the Hoopla.
    2012 TRD Sport 4X4 - Pyrite Mica
    Raptor 4" Black Oval Nerf Bars, Hard-Wired Uniden RD9XL Radar Detector, Anytime Fog Light Mod, 12V Power outlet in Bed, Tailgate Anti-theft Mod, Distinct Offroad lightbar, 2 Hella Micro FF Driving Lights, 2 Hella Micro FF Fog Lights, Rear Slider Window Opener
    Nope.
    cmartinez95 likes this.
  3. Oct 8, 2016 at 5:06 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    ^X2
  4. Oct 8, 2016 at 5:17 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    why not ramps?
  5. Oct 8, 2016 at 5:24 AM
    zonian
    Paul
    1. Can't use ramps for wheel/brake/suspension/etc work.
    2. Your truck is likely high enough to do most other work without ramps.
  6. Oct 8, 2016 at 5:30 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    You won't be able to take the wheels off with ramps so anything involving that is out.
    Otherwise they are fine
  7. Oct 8, 2016 at 5:35 AM
    DrFunker
    DrFunker Well-Known Member
    Used my ramps quite a bit, pre-lift. Haven't used them since.
    Use my jack stands a lot.
  8. Oct 8, 2016 at 6:51 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Ramps are quicker and easier great for oil changes
  9. Oct 8, 2016 at 6:56 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'd get some 6 ton jack stands. 4 tons aren't high enough, at least on my truck.
    medic2230 likes this.
  10. Oct 8, 2016 at 6:57 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I use neither for oil changes by using a Fumoto valve.
    Kyitty and moe2o4 like this.
  11. Oct 8, 2016 at 7:01 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I dont even raise my truck for oil changes. I roll under there with my creeper and change oil and lube the u joints.
    Climberclimb, Larzzzz and medic2230 like this.
  12. Oct 8, 2016 at 7:30 AM
    rnish
    Tacoma 2nd gen
    OK I'll bite. 4 tons = 8000 lbs , My Tacoma is ~ 4,500 lbs (now). What are you driving?
    The industry standard for jack stand load rating is to rate jack stands in pairs. According to ANSI standards, a single jack stand from a pair must support one and one half times the total rated load for the pair. That means a single jack stand for a pair rated at 4000 pounds must support 6000 pounds.
  13. Oct 8, 2016 at 7:34 AM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Height bro
  14. Oct 8, 2016 at 7:35 AM
    medic2230
    Murph
    Bama! Roll Tide
    Jack stands when you need them. Never needed to lift a tacoma for an oil change.
    Ramps if you want to see what getting in your truck with a 12" lift feels like.
  15. Oct 8, 2016 at 7:36 AM
    medic2230
    Murph
    Bama! Roll Tide
    *lift problems.
  16. Oct 8, 2016 at 7:40 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Like others have said, get jack stands, and make sure they're tall enough to work. On my Tacoma with a 3" lift the 4 ton jack stands were maxed out with my tires still touching the ground. Had to return them and get 6 tons.
  17. Oct 8, 2016 at 7:40 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I just mean they're not tall enough. The 4 ton can clearly support my truck, but because it's lifted 3" on 33s, they're not tall enough.
  18. Oct 8, 2016 at 7:48 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I had to look this up. Seems like a handy little trinket.
    Anyone else use one?
  19. Oct 8, 2016 at 7:59 AM
    scocar
    scocar hypotenoper
    Ramps are useless. Even on a unlifted 2nd Tacoma, I can reach under to access the drain plug.
    At least one pair of 6 tons to reach the frame rails, and a pair of 3 tons for the rear axle will get you through most any task on a lightly modified Tacoma. Including rotating your tires.
  20. Oct 8, 2016 at 8:43 AM
    zonian
    Paul
    +1 for Fumoto valve...working great over 23 oil changes so far!!!
    moe2o4 likes this.
