RAM mount options - First Gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kwe1982, Feb 16, 2020.
  1. Feb 16, 2020 at 10:04 AM
    Kwe1982
    Kwe1982 [OP] Well-Known Member
    Wisconsin
    Gone - Just a couple Tundras and a Sequoia
    Looking to see what everyone is using,
    I searched the site and got a lot of old posts, not sure if there is any new options out there.
    I’m looking at supporting a iPad mini, and really didn’t want to drill into the dash.
    Since it’s in such good shape.
    I had the hondo mount on my 3rd gen, I liked it a lot.
    thanks
    Ken
  2. Feb 16, 2020 at 11:12 AM
    dankthetank
    dankthetank Well-Known Member
    So Cal
    01 3.4L 5-spd 4x4
    This is what I use for either my iPhone or inReach. I don’t know how much more an iPad mini weighs but it may work here as well. I chose this spot because I didn’t want to drill into the dash either and I don’t have a driver’s side grab handle to use.
    Colchicine and Taco critter like this.
  3. Feb 16, 2020 at 11:45 AM
    Kwe1982
    Wisconsin
    Dankthetank,
    I like that, did not really see that spot.
    Might go that route.
  4. Feb 16, 2020 at 12:12 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  5. Feb 16, 2020 at 12:47 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I'm using a couple RAM mounts for my stuff. Details mostly in these posts:
    Adding a Ram Mount to the #%@#$@! A-pillar.
    Where are you? Adding APRS to the Ham Radio Comms
    Mod Wars - USB charger blocking Ham Radio Communication (photo at the end of the post)
    Essentially, for the A-pillar mount, it was:
    And for the center-dash mount, I used:
    With all that, I ended up with this as my cockpit...
    arkmm, Wulf, Colchicine and 3 others like this.
  6. Feb 16, 2020 at 9:27 PM
    tony2018
    tony2018 Well-Known Member
    love the setup.
  7. Sep 7, 2024 at 6:45 AM
    Jamin Loewen
    Jamin Loewen Member
    If you’re still looking for better options, I’m making a Ram mount clip that goes in where the airbag indicator would be. Of course this doesn’t work for all models but for any that just have the cover clipped in that spot. It just snaps right in. If you want one, I can make one for you. Shoot me a text at 563-203-0952. Also I designed this myself so I can make other versions of it if you want.
  8. Nov 14, 2024 at 11:32 AM
    Kimp
    Kimp Well-Known Member
    Jeff
    Northern Illinois
    Supercharged ‘02 Double Cab
    still open to making more of these? If so, how much are you charging?
  9. Nov 17, 2024 at 6:47 AM
    Jamin Loewen
    Jamin Loewen Member
    Yes, I’m still making them. I’ve been charging $8 a piece for them- free shipping. I can print in most any of the standard colors.
    cruiserguy and Nevin like this.
  10. Nov 17, 2024 at 8:09 AM
    Kimp
    Jeff
    Northern Illinois
    DMd you
  11. Nov 21, 2024 at 11:02 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    CA-Taco likes this.
  12. Nov 21, 2024 at 5:13 PM
    CA-Taco
    CA-Taco Well-Known Member
    Bay Area
    1999 PreRunner TRD
    1999 PreRunner TRD 5VZ 3.4 V6 AutoTrans 4x4 Swap ADS Coilovers w/adjusters New OEM Bushing UCA and LCA @210k Mi Stock LCA, SPC UCA DuroBump Front Bump Stop Alcan Springs +800 lbs +2" ADS w/adjusters Rear Shocks U-Bolt Flip-Durobump DuroBump 4.25” Bump Stops Custom Shock Relocation 4.88 Yukon Gears Eaton Front Locker SCS Ray10 16x8 Bronze 255/85R16 Cooper Discoverer S/T Maxx Dakota Digital SGI-100BT Speedometer Interface Stock Front Bumper with Custom Hidden Winch Warn M8 w/Synthetic Rope w/Factor55 Flatlink E Nguyen Works Bumper w/Dual Swing Outs (Greasable KP Off-road LCA Bolts for Swing Out Bearings) BAMF Sliders 4x Innovations Front and Transmission Skid Plates Dometic CFX 55im Fridge/Freezer Big 4 wiring Mod Singer 128.5MM Denso hairpin style (6 phase) 180 A (200 A Max, 150 A Idle) X2Power AGM Group 35 Battery Renogy Deep Cycle AGM 12 Volt 100Ah Battery Renogy 20A DC to DC Battery Charger Victron Energy SmartShunt 500 amp Battery Monitor BlueSea Bus Bar on Custom Engine Bay Mount Victron Energy SmartSolar MPPT 20 amp Solar Charge Controller Renogy 100 Watt Eclipse Foldable Solar Panel Osram Super Bright 100/90w 2900 lumen H4s Headlight Services Harness 13WL Brake Calipers Braided Steel Brake Lines Foseal WiFi OBD2 Scanner & OBD Fusion App Sony XAV-AX5000 w/Carplay Soundproofed Cab - Dynamat and Second Skin Wet Okole Seat Covers Rebuilt Engine when Head Gasket Failed (215k Mi) Hayden 699 Transmission Cooler (Replaced B&M 70264 Cooler) Magnetic Inline Transmission/Power Steering Filter 4 x 4 Conversion w/Yota1 Rebuilt AT, ECGS Rebuilt Front Diff, '99 Taco TC, Manual Hubs GFC Camper V2 LSPV Delete Custom Mud Flaps and Hangars (1/4” Conveyor Belt Material; 12” x 18”)
  13. Nov 21, 2024 at 7:13 PM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    20241006_224157.jpg 20241006_224311.jpg The panavice mount is kinda shakey, and it's pretty low. I'm using it for my switch panel.
