Radio turns on and off randomly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by knottyrope, Jan 2, 2019.
  1. Jan 2, 2019 at 9:46 AM
    knottyrope
    knottyrope [OP] Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    204k miles later and my radio seems to be possessed. Turns on with blank screen with radio playing and then turns off. Turns on by power button and then shuts off randomly.
    Not betting on a quick fix but maybe it's something simple someone else has seen.
  2. Jan 2, 2019 at 9:56 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    In for the responses. My radio will shut off sometimes after going over a bump.
  3. Jan 2, 2019 at 10:02 AM
    Muddinfun
    Muddinfun Well-Known Member
    Not related to the OPs problem, but I was surprised the 1st time I accidentally hit the mode button on the steering wheel and the radio turned on.
    OldManTacoFeels likes this.
  4. Jan 2, 2019 at 10:07 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    I would pull the unit and inspect the wiring harness. Repair if need be and reconnect. I've seen where a bad or loose battery cable/terminal can cause stuff to cut out also. Buddies Chevy had this issue and only his stereo would cut out.
    Torspd likes this.
  5. Jan 2, 2019 at 2:49 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Surprised it didn’t happen sooner. 2009 models were known for “possessed” radios way back when they were being sold off dealer lots. Mine was one of them. Replaced over 9 years ago, and lately its been acting up again. Time for an after market headunit.
    K Williams and Jimmyh like this.
  6. Jan 2, 2019 at 4:27 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    My 15s restarts randomly. Maybe once every 2 or 3 weeks.
  7. Jan 2, 2019 at 4:36 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This is a different issue. The Entune systems have a bug where the stereo may restart randomly when connected via bluetooth, there is a software update available at the dealer to resolve the issue.
    Alexely999[QUOTED] likes this.
  8. Jan 2, 2019 at 4:38 PM
    Tacoma Mike
    Southern Maine
    I went through 3 and just installed a pioneer.
    Time to swap it out.
    It’s an internal failure...
    K Williams, ~V~, Jimmyh and 1 other person like this.
  9. Jan 2, 2019 at 5:43 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Mine started to turn itself off randomly and it was getting more and more frequent. I pulled the fuse, cleaned the fuse blades, and put it back in. So far, ok, but I don't know if it's going to be a lasting fix. I did have to rest my stations.
  10. Jan 2, 2019 at 6:34 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    My volume control is acting funny. Usually, nothing happens when I try to raise/lower the volume, yet the volume buttons on the steering wheel function fine. And my wife re-activated satellite radio as a xmas gift, bless her heart, but the channel button (on radio and steering wheel) will occasionally freeze and not do anything until I restart the engine. One more hiccup and I may put a new radio on my birthday list for June. If I recall correctly, the adapter for JBL radios approaches $80.
  11. Jan 2, 2019 at 6:41 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Looks very nice. Which model is that? Does it have Apple Car Play? I have that in my new work car and love how it integrates with my iPhone.
  12. Jan 2, 2019 at 6:49 PM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    The stock radios in both of my Tundras (09 and 13) would often have unresponsive buttons and a blank screen, yet still play music. I didn’t keep the stock unit in the Taco long enough to see if it would do the same, I replaced it with a JVC.
  13. Jan 2, 2019 at 7:07 PM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    Had the same problem in my 2014 along with a few other issues. I was convinced the Entune system was toast. Long story short, it turned out that neither Toyota nor the dealer bothered to tell me about the Entune incremental firmware updates that had been released since I bought my truck. My truck was several versions out of date. They installed the updates and I haven't had a problem since...
  14. Jan 3, 2019 at 2:28 AM
    Tacoma Mike
    Southern Maine
    It’s Pioneer MVH-600BS
    No apple car play
    No cd as I play everything Bluetooth or usb.
    Has Sirius using add on module
    Pandora
    Spotify
    Bought it specifically for hands free phone as here in Maine we are no text and drive.
    Well suppose to be anyway lol.
    I did not buy the steering wheel control module yet.
    Does what I want.
    Cost me like $125
  15. Oct 20, 2019 at 10:49 AM
    Collin28ca
    Collin28ca New Member
    I had the issue where the radio kept turning off (along with screen and all), and it is 100% a bug associated to the vehicle starting up connected to a Bluetooth device. If you remover the device it works just fine. But for some reason if the vehicle is turned on with the device connected it turns off. I will bring into the dealership and have them replace the radio... will keep y’all updated.
    Armkb likes this.
  16. Oct 20, 2019 at 11:39 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    I had my Alpine INEz928hd kick the bucket a few weeks ago. Started with intermittently turning off / restarting when driving. I pulled the unit out and beeped the power at the terminal and I was getting ~12v so my guess is that it overheated internally and melted something important. I did observe that the fuse from the battery that holds the radio memory was melted but it wasnt popped so it mustve been pretty hot in there, but that z928 is a fat pig and takes up the entire opening. I didnt observe any damaged wires save a nick in the sleeve of one of the antenna leads IIRC. Bottomline, I'm due for a new radio now.
    :spending:
    -J
  17. Jul 5, 2021 at 12:28 AM
    OldManTacoFeels
    OldManTacoFeels The bells of tacos
    Billy Jr.
    2012 DCLB SR5
    Bilstein 5100s, AFE dry intake, Icon AAL pack, Bed stiffeners, and ideally some UCAs soon
    Why the fuck did this work???
  18. Apr 29, 2024 at 1:33 PM
    ~V~
    ~V~ New Member
    Virginia
    2005 Tacoma Pre-Runner 2wd
    Did you figure out what the internal problem was? I installed a pioneer stereo 2 years ago and it's been working fine until a few months ago. The stereo will turn on and off and the cigarette/ phone charging ports won't work at the same time the stereo is messing up especially on rough roads. Now it won't come on at all. I've pulled everything out and there is no lose wires, at least that I can see. I've never had this problem.
  19. Apr 29, 2024 at 1:51 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Gotta break it to you this way. Nobody has been on this thread for years. That’s not the problem. Just waiting for a solution is.
    :hattip: Big Welcome to TW.
    AllTacosFloat and knottyrope[OP] like this.
  20. Apr 29, 2024 at 1:53 PM
    knottyrope
    Knotty
    Bahstun
    Yes, my power relay had worn contacts and needed to be replaced
    Torspd, ~V~[QUOTED] and FastEddy59 like this.
