Radio (or aux) shuts off on it's own?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by slick_711, Feb 6, 2011.
  1. Feb 6, 2011 at 7:11 PM
    slick_711
    slick_711 [OP] Well-Known Member
    DFW, TX
    '09 TRD Off Road
    Avid light bar w/2x Hella 4000C, Bilstein 5100s, Demello sliders
    A number of times over the past year that my radio has either kicked from my iPod (via auxiliary input, not USB) back to the radio if it was slightly jarred. I ignored this figuring it was the cheap $10 cable. However, a few of those times the head unit actually turned itself off. I decided to ask about this because it did so twice last night on my short drive home. I don't care about the iPod connection, but when the radio randomly turns itself off 2-3 times a month without any major bump I wonder what's wrong.
    Is it possible one of the wiring connections for the head unit either worked loose, or was loose all along? Is removing the head unit to check the connections simple enough I can do it alone? I'm fairly handy but have never messed with car audio at all.
  2. Feb 6, 2011 at 7:18 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I have to ask because 99 percent of the time it's the driver causing it. Do you have the steering wheel controls? If not, then you can obviously ignore my question.
  3. Feb 6, 2011 at 8:46 PM
    slick_711
    DFW, TX
    '09 TRD Off Road
    I do, but I am pretty "aware" of my hands for lack of a better word. But that very well could be the cause for it occasionally bumping from iPod to FM. I'll have to check tomorrow morning and see if FM is the next thing the mode button on the steering wheel would make it cycle to. Can you turn it off via the steering wheel though? If holding down a button turns it off I guess that's possible as well. I've never used the steering wheel buttons much, but I don't think I have been bumping them.
    I will experiment a little bit and watch my hand placement though, maybe you're right and I'm just clumsy with my left hand. Thanks for the input!
  4. Feb 7, 2011 at 8:12 AM
    05Moose
    Jim
    The reason I asked was because over on TN we had a long-time member that had this same problem. He replaced his previous Gen 2 Taco with a newer model, and we all assumed he knew what all the buttons did. We went through all these problems he was having with the radio before finally realizing he'd never had steering wheel controls on the previous Taco. He and his wife were both causing all the changes in the radio and turning it off accidentally with the steering wheel controls.
  5. Feb 7, 2011 at 8:14 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i belive there were problems with alot of stock steros on here turning them selfs on and off.....
    try searching a lil more mabye you can find something
  6. Feb 7, 2011 at 8:17 AM
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
  7. Feb 7, 2011 at 9:01 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    ^^ This, I'm pretty sure I have seen a few threads on this too. I think most had to go back to the dealer and get it replaced. There is no power button on the steering wheel controls. Just volume control preset ch changing and mode, which takes you through fm/am.
  8. Feb 7, 2011 at 9:11 AM
    05Moose
    Jim
    Yes, the radios have problems (which is why there was at least a 3 month backlog at one point). But it's good to first make sure it's not happening from user error. IIRC, you can turn the radio off using the steering wheel controls by holding one of the buttons (can't remember which one as it was in our prior vehicle). Owner's manual should have the info though.
  9. Feb 7, 2011 at 9:21 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    I had the same issue with my stereo. The dealer replaced the stereo twice and the jack once. It has been working great for about 6 months now.
  10. Feb 7, 2011 at 1:16 PM
    slick_711
    DFW, TX
    '09 TRD Off Road
    I did search once but I guess used the wrong terms, I'll look again more thorougly. :eek:
    I experimented today on the way to work, it is definitely not me. To turn it off you have to hold the mode button down for a few seconds, and it makes an audible beep @ shut off. If I were hitting something on accident it'd be the volume up button, I'm pretty consistent with hand placement, and would definitely have noticed the beep.
    I'm not too worried about the iPod thing, but the stereo turning itself off seems weird. I'll search again and swing by a dealership. Thanks for the info guys.
  11. Feb 19, 2011 at 4:20 PM
    Reepur
    Reepur Well-Known Member
    Brevard, NC
    '10 RC Black 4x4 2.7L
    265/75/16 BFG KM2 's on XD Hoss's 2.5" lift/4xBillies, OME 885's, Firestone Ride-Rites Desert Specialties UCA Volant CAI Grillcraft Grill Kobalt Slim Line Box Weathertech mats and Ventvisors. DTRL mod. 4 Lo -Trac Mod. Int. Wiper Mod. rcbs204 4x4 LEDS URD Short Shifter Plate Front bumper with Smittybilt XRC8000 winch Body Armor rear bumper with swing out tire carrier. ATO Front Skid Ultragauge BHLM
    My HU will turn on by itself when I go out and warm the truck up in the mornings.
    No big deal, I am going to replace it any way, but there is an issue with them
  12. Jul 5, 2012 at 9:07 AM
    Fredclem
    Fredclem New Member
    Fred
    Allen, Texas
    2010 Prerunner
    I own a 2010 taco.. and I am having the same issue with the on/off knob. Radio will go on and off at will...volume will not change...display goes blank ... it does seem like there is a wire loose..is there a fix other than a dealer change-out?
  13. Jul 5, 2012 at 3:44 PM
    ShaneG
    ShaneG Well-Known Member
    Shane
    Jacksonville, FL
    11 Prerunner SR5
    Common issue, and one Toyota is aware of. My 2011 was doing the same thing from day one. Took it in to the dealership and had a diagnostic performed. It spit out an error code and they swapped it out, free of charge.
  14. Jul 5, 2012 at 6:37 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    Wow! I thought I was the only one. Is a 2010 still under regular warrantee?
  15. Jul 5, 2012 at 6:53 PM
    bishtacova
    bishtacova Don't buy a Ford
    2009 DC PreRunner V6
    4 leaf TSB, reflash ECM, Eurostyle antenna, thule roof rack, bed extender
    I've had my stock radio and iPod jack replaced. Get them both replaced at the same time if you're still under warranty. The service mgr. didn't blink when I told them about the issue, just ordered another radio.
  16. Jul 5, 2012 at 8:21 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    My truck got its third radio at 36k miles. It had all the classic symptoms - it would be playing a CD, screen would go blank for a few seconds, and then shut off, or the best one, have it off for a while and BOOM it's back on. At least it's better than the problem Toyota logged in the service record for the factory radio with the previous owner - it stuck itself at max volume and refused to turn off. Yeah, that would be WONDERFUL. If these things can't say "Made in China", their quality isn't good enough for even that.
    Mine's just a base truck so no steering wheel controls either.
    Rule of thumb, have Toyota give you a new shiny POS when you're under warranty, and once you're out, save up for your favorite aftermarket unit.
    I wonder if the 2012s come with manure-brand radios too. It may influence whether I keep this truck, as I like a stock dash, but at the same time a $150 Pioneer is a lot cheaper than a trade-in.
