Radio fuse
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004Taco, May 27, 2010.
  1. May 27, 2010 at 2:24 PM
    2004Taco
    2004Taco [OP] Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    Where is the fuse for the radio? I can find it.
  2. May 27, 2010 at 2:38 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    it should be in the fuse box on the lower drivers side left labeled Radio 7.5A at least that's where mines at ;)
  3. May 27, 2010 at 2:45 PM
    2004Taco
    Lou
    California
    Mine doesn't say radio anything.
  4. May 27, 2010 at 2:48 PM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    Thanks for the info i'll file it away in case I need it some day
  5. May 27, 2010 at 3:16 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Pull out a 7.5A and see if its blown :rolleyes:
  6. May 27, 2010 at 3:20 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Is there one that says cigarette? usually that one is connected to the radio as well...I think its a 10A...
  7. May 27, 2010 at 4:15 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    I am pretty sure my radio fuse (2003) was in the engine bay fuse holder (not too far from the battery). The box has a legend on it to tell you what each fuse does.
  8. May 27, 2010 at 5:10 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    does your cover have a legend on it?
  9. May 27, 2010 at 6:44 PM
    2004Taco
    Lou
    California
    Yea it does but doesn't say anything fr the radio. My buddy says it's the done light fuse. I'll have to try that out. I'll keep you posted
  10. May 28, 2010 at 4:25 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    read post #6
  11. May 28, 2010 at 4:28 PM
    2004Taco
    Lou
    California
    I pulled out the dome light fuse. It shut off the dome light, radio, door chime and automatic door looks.
  12. May 28, 2010 at 5:03 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The 2004 OEM radio / player receives power via 2 fuses: 15A Dome and 15A ACC (accessory).
  13. Jul 26, 2013 at 11:45 AM
    Pk2
    Pk2 New Member
    On my Tacoma, the 15A dome fuse is located in the 2nd (of two) fuse boxes. Others were saying it was in the one on the lower left drivers side. Radio, auto lock, door chime, were not working. I changed this fuse and things are back.
    If you can't find it where the others suggested, I would go to the fuse box next to the battery. It's clearly labeled as #7 (Mtucker) described.
  14. Oct 17, 2014 at 9:29 AM
    Wildcat1991
    Wildcat1991 Member
    my radio wouldnt work either but this was right the dome fuse is the one!! thanks guys i can jam again lol
    jahsonferg likes this.
  15. Oct 17, 2014 at 12:52 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    crazyasu45 : Terrific advice :rolleyes: from a SECOND GEN owner.
    2004taco : I have a FIRST GEN also. The starter and ignition fuses are also 7.5A on my '99 model. The back side of that fuse cover has a label for each fuse. I can post a photo if you like, if yours is missing. Yours might be similar.
  16. Apr 16, 2015 at 5:39 AM
    Assforkr
    Assforkr Well-Known Member
    MA
    03 taco
    Just had to do this fix and there's a 15amp ACC mini fuse by your left knee fusebox in the cabin. If your dome lights work and the radio and/or the cig lighter and power plugs are out then that's the one to switch.
    Berchico likes this.
  17. Oct 31, 2016 at 5:21 AM
    Rvg514
    Rvg514 New Member
    03 Tacoma
    Hi, I have a 2003 Tacoma. I plugged my phone charger the other night and the radio and clock shut off. The security light on the radio is blinking but will not power up. It's not a factory unit. Didn't find any blown fuses. I pulled the radio out and checked the fuses on the wire hardest and they are fine. The hot wire is getting power. The cigarette lighter and accessory plugs aren't working either. Any ideas???
  18. Oct 31, 2016 at 8:38 AM
    tan4x4
    Rick
    Folsom, CA
    2 ideas:
    - Check the owners manual (if you have it) of the non-factory radio. It might explain what that blinking light means.
    - Check the fuse under the hood called "Pwr Outlet"
  19. Oct 31, 2016 at 1:14 PM
    Rvg514
    Rvg514 New Member
    03 Tacoma
    I tried the Pwr outlet. That works still having the same issues
  20. Dec 18, 2016 at 4:46 AM
    seanokie
    seanokie Member
    Anyone have a 2nd gen req the fuses pulled to have radio reset and come back on? Whatsbthe full fix?
