Radio for overland and off roading.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Thedoobster, Jun 2, 2021.
  1. Jun 2, 2021 at 1:54 PM
    Thedoobster
    Thedoobster [OP] Well-Known Member
    Brandon
    California
    1999 Tacoma SR5 3.4L 4x4
    3" Lift, 1.5" Wheel Spacers, 285/75r16 Tires
    I've recently received a CB radio for free so of course I'm gonna mount that but I've also been looking at other forms of radio and I'm trying to find the one that best suits my needs. I've been leaning more towards HAM or GSMR but can really make up my mind. I know CB is very common and cheap so for large groups and just in general most will have that but the quality isn't that great and the range severely lacks. Mainly what I need is something with a high range that can get me out of a hairy situation if I'm stuck in a remote place but also doesn't break the bank.
  2. Jun 2, 2021 at 2:40 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Why don't you use what your groups or friends run?
    That's a question you should ask them versus us.
    If I needed a radio because I'm in a hairy situation, then I failed to do the most basic things. Those being giving loved ones a drop-dead time and location of where I'm traveling. Also having the proper recovery equipment, and knowledge on how to use it
    skeezix, Wyoming09 and Black DOG Lila like this.
  3. Jun 2, 2021 at 4:09 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  4. Jun 2, 2021 at 4:16 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
  5. Jun 2, 2021 at 4:35 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    As someone with a Ham license, and who uses a Ham radio reasonably extensively as part of getting out there, it's important to realize that a Ham radio is not a solution for a 'hairy situation.' Even with 50W of power, there are plenty of times where the terrain will severly limit ham communications. In a lot of other situations, there may not be a repeater nearby.
    For a hairy situation, you also don't really want a sat phone, IMO. A better option is something like a Garmin InReach Mini and the basic plan. That allows you to send an unlimited number of "I'm OK" or "I need help" texts (which you pre-program) to your friends/family, but also provides the SOS capability that actually gets SAR on their way to you in a 'hairy situation.' It's better than a sat phone in that once you press the button, it runs unattended until it can communicate with the constellation, you're found, and without the airtime limitations of a sat phone.
    Personally, I use CB (b/c that's what the people I go out with use), Ham (mostly for APRS for my family, but also for slightly longer comms with people on the trail when we're in the canyons), and a Garmin InReach Mini with the basic plan.
    Also, @Kwikvette's statement about telling peole where you'll be and when they should call in the cavalry if you aren't back - that's good advice.
    Wyoming09 and JJ04TACO like this.
  6. Jun 2, 2021 at 5:01 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Yes to ^^. Don't forget cost. Not just for you, but for the people you want to reach. The more costly/complex (ham) the more the average Joe will not want to mess with it. I switched to GMRS for clarity, and with a small mobile unit you can get far better range than with a CB generally speaking. But if they have a handheld and are in a vehicle, they will likely hear you, but you won't hear them. Lots to consider...
  7. Jun 2, 2021 at 9:06 PM
    Which Way Out
    Which Way Out Well-Known Member
    Bill
    Santa Barbara
    2002 Tacoma 4 Door Prerunner
    Passing the Ham Tech exam is the easy part. Learning how to use one is a whole other kettle of fish.
  8. Jun 2, 2021 at 9:10 PM
    Which Way Out
    Bill
    Santa Barbara
    Don't go to deep into spending a ton of money on a Ham radio unless you really want to pursue another hobby. A Yeasu 1900 R will only set you back around $250 with an antenna. And if I told you its a 2 meter radio, well what the hells that mean right?, same thing happen to me.
    Had a 1900 in my Jeep, we used to off road all over the desert out past Indio Ca.
    Its a great little radio that has lots of features. You can monitor Police and Fire, of course you can't talk to them because the radio has a lock out for that's built in. There's a lot to learn just to use it, but well worth it. And if you learn to use it well, many other opportunity's will show up.
    I won't bore you with it. But lets say with the more expensive radios ( I have the Yeasu FTM-400 ) you can not only talk, you can send text and email messages to a cell phone or computer and a bunch of other stuff. I've had to communicate that way when we've had no Cell service. One other great feature the FTM-400 has and many others as well, Is APRS. google it. As an Overlander you might find that very useful.
    If you have any other questions just let me know.
    Best of luck and be safe
  9. Jun 2, 2021 at 9:12 PM
    Which Way Out
    Bill
    Santa Barbara
    DITTO
