Radiator support tie bar too weak to support grill guard
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2017 Inferno SR5, Oct 7, 2019.
  1. Oct 7, 2019 at 5:58 AM
    2017 Inferno SR5
    2017 Inferno SR5 [OP] Member
    Todd
    2017 Inferno SR5 V6 Auto 4X4 DCab 6ftbed Tow Pack
    Do you have a grill guard? Is it making any raddle or squeaking noise? I ask because about a year ago I installed a Westin Grill Guard. A few months ago I hear it raddling so I tightened it up, then a few weeks ago it needed tightened up again. It has again started raddling so I decide to investigate it closer. The bolts were still tight. I found that the “radiator support tie bar” that runs from side to side in front of the lower part of the radiator (not the support above the radiator) was cracked and pieces had broken out around the fastening bolt slot. The upper support of the grill guard fastens into “radiator support tie bar”, while the lower support of the grill guard fastens on to the frame. Anyone else had a problem like this?
  2. Oct 7, 2019 at 6:03 AM
    81shark
    81shark Well-Known Member
    Those guards will only protect you from a full wallet
    dubktrd, Skydvrr, AntMan408 and 16 others like this.
  3. Oct 7, 2019 at 6:14 AM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    I wouldn't trust mounting anything heavy or expected to take an impact to anything but the frame and that includes secondary supports. The front of a modern vehicle is designed to do two things: (1) support the OEM configuration, and (2) crumple in an accident. They're not built out of heavy steel like they used to be, they're designed to be less likely to kill a pedestrian.
    But as was said and will be repeated ad nauseam, those things are going to make any frontal accident 100x worse for you than hitting something directly. The impact point has huge leverage over the frame mount and if you're lucky, the bull bar will bend to save the frame and only take out your entire front end. If not, well I've seen several times where a deer hit around the headlight turned into frame damage and a completely new front end because of a bull bar.
    GreyBaldTaco likes this.
  4. Oct 7, 2019 at 6:32 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Email Westin yet?
  5. Oct 7, 2019 at 6:35 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    This is a great example of why those things are trash
    DJB1, Minny Taco, AntMan408 and 9 others like this.
  6. Oct 7, 2019 at 7:33 AM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    No impact protection should be tied into the core support. You are just asking for trouble in a light impact where aside from the front fascia damage, you could end up pushing the radiator into the fan and collapsing the core and fender supports. Now a little damage becomes a lot. You might consider getting a bumper replacement that adds some impact protection and mounts to the frame.
  7. Oct 7, 2019 at 7:37 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Grill guards do nothing too protect your truck,and they do more damage with one, than without in an accident.
    LivinOnEdge and GreyBaldTaco like this.
  8. Oct 7, 2019 at 8:45 AM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    hmmm, i dont remember any grille guard ever mounting to the raditor supports. i always thought they tied into the same location as the tie down (you remove the tie down) or the frame unless someone did a hack job.
    personally i use to like them but i se way to many doing more damage than saving. i would rather spend the extra money for a full bumper replacement if i could afford one.
    Big tall dave likes this.
  9. Oct 7, 2019 at 11:19 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    No. (Also no and no by default).
    Damage multipliers just doing damage.
    How could mounting that thing to the radiator support thought to be ok in the first place?
    vicali, JS760 and GreyBaldTaco like this.
  10. Oct 7, 2019 at 11:32 AM
    Skymaster
    Skymaster Well-Known Member
    Atwater CA
    TRD OR, White DCSB
    ROFL!!! Get what money you can by selling that thing and get a real bumper or a Slim Line series. Wait till you actually hit something like a shopping cart to tweak your frame
  11. Oct 7, 2019 at 11:36 AM
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    What did the manufacturer say? I'd be pissed.. you'd assume things are relatively stress tested, not just tied into wherever a bolt may lie.
  12. Oct 7, 2019 at 11:37 AM
    J_Anthony_
    J_Anthony_ Well-Known Member
    RangerIsTheBestTruck.Duh.
    Naomi, Lana
    Yea what the fuck is that thing ....
    I swear people like this... do zero research before slapping some shit they saw on eBay on their trucks because it looks “Offroad”
    This does nothing to protect the truck. Like previously stated^^^^
    Sell it and then...Put this part of your life into a little box and never revisit it.
    127.0.0.1 likes this.
  13. Oct 7, 2019 at 11:41 AM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    You're suprised????
    Let's be real. Look at the size of that thing. You expect any vehicle to support it properly with where it mounts? What did you expect to protect on your truck with that thing? Please tell me your mindset was purely ascetic
  14. Oct 7, 2019 at 11:41 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    if you want tough truck nose, then get a proper roobar that attaches to the frame (or armored bumper/roobar combo) and not need to attach to non structural parts like the radiator support
    as others are saying, the item you show in the pic is 100% cheese and 100% useless and can only cause problems not fix any
  15. Oct 7, 2019 at 11:41 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I would bring that up with Westin. It's their design that caused the problem. I doubt they'll make it right, but it doesn't hurt to ask.
  16. Oct 7, 2019 at 11:42 AM
    Comato$e
    Comato$e Well-Known Member
    Joshua
    Chicago,Il
    18' MGM OR DCSB
    who Installed it ? Looks like a Mickey Mouse install
    DAS Taco likes this.
  17. Oct 7, 2019 at 11:57 AM
    salmonmigration
    salmonmigration Well-Known Member
    2018 TRD Sport 6MT
    Christ on a cracker it literally mounts to the radiator support. Can't make this shit up.
    OP get an estimate from a body shop and demand Westin pays a refund plus the repair bill.
    Paul631 and GreyBaldTaco like this.
  18. Oct 7, 2019 at 2:06 PM
    JS760
    JS760 Well-Known Member
    San Diego
    2017 DC Sport
    I’m going to need to see some install Instructions
  19. Oct 7, 2019 at 3:58 PM
    81shark
    Bottom bolts to the frame. Top mounts to something in the radiator area.
  20. Oct 7, 2019 at 4:02 PM
    VirusCage
    VirusCage Well in the secondary immune response
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 1995 Landcruiser 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    something? well not now....oh my
