Radiator Support Splash Shield Replacements
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco1UU, Feb 15, 2021.
  1. Feb 15, 2021 at 2:21 PM
    Taco1UU
    Taco1UU [OP] Member
    Two Tacos: 1996 and 2002
    No mods yet on the '96...just trying to get her reliable again. Work completed: * Cleaned behind dash and replaced all dash bulbs. (There was only one working.) * Reconditioned front bumper. Replaced rear bumper. * Thoroughly corrosion-controlled underside, including spare tire hardware. * Replaced valve cover and engine oil pan gaskets. * Replaced clutch. * Replaced all driveline fluids. * Engine tuneup. * Reconditioned gas tank skid plate. * Reconditioned engine skid plates. * Replaced parking brake hardware. * Replaced all front suspension components except lower control arms. * Replaced front brakes. * Replaced CV joints. * New main driveshaft No mods on the 2002...she's all stock.
    Can anyone recommend an economical aftermarket replacement for Toyota parts 51405A and 51406A, the "Radiator Support Splash Shields" (what I'd call "Skid Plates")?
    The OEM parts are steep for what they are and a lot of the aftermarket ones I see are for Gen 2 and Gen 3 Tacos.
    I'm looking for a solution that can use the existing mounting holes.
    I have two (2) Gen 1 Tacos, one whose skid plates I was able to re-hab, the other that are too far gone to salvage. I'd buy two (2) sets though if it would get the price down.
  2. Feb 15, 2021 at 4:34 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Post your location
    Hell I'd give you mine for free if I got that set from another member he's got set aside for me.
