Radiator Support Bushing PNs and How to Replace them
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, Apr 14, 2025.
  1. Apr 14, 2025 at 5:06 PM
    skeezix
    skeezix [OP] Well-Known Member
    Colorado
    1998 Limited
    Has anyone posted a procedure on how to replace the radiator support bushings? I went through a lot of the results of a search on "radiator support bushing" but was not able to find anything that explains how to replace just those two bushings. Mine are about ready to give up the ghost, and I'm not sure about the bolt that goes through them 'cause I haven't taken anything apart yet.
    I also did not find a Toyota part number for the bushings. I went through ES's parts but did not find exactly what I'm looking for. Any help anybody can give me would be greatly appreciated.
    Black97v6MT likes this.
  2. Apr 14, 2025 at 5:25 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    You mean these?
  3. Apr 14, 2025 at 5:27 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    It’s the parts in the top left diagram
    Black97v6MT and Nevin like this.
  4. Apr 14, 2025 at 5:28 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    I did one side at a time, I used a jack and a piece of 4x4 wood to lift the radiator support enough to remove the old bushings. I was able to reuse my hardware. It’s easier with the bumper removed.
    b_r_o and ControlCar like this.
  5. Apr 14, 2025 at 9:16 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Agreed^^^^^^
  6. Apr 15, 2025 at 9:47 AM
    skeezix
    Colorado
    1998 Limited
    @Parkvisitor... Thanks for the illustration. Just to be sure... it's the parts shown here, right? And I would need PN 52201C and 52202B, right?
    I'd rather not remove the bumper. So here's my plan:
    1. Remove both vertical bolts.
    2. Put the jack and the 4x4 somewhere (but where?) to raise the body up from the frame (but how high?). Can I raise just the front left corner of the body enough to remove and replace the rubber cushions or do I have to remove the bolt on the other side first? How does that work???
    3. Don't I have to loosen the body mounts farther back on the frame? Seems like if I don't, something would bend or break.
    Am I missing anything here?
    Finally, where can I order just the 52201 and 52202 parts? My local Toyota dealer does not have them (as usual) and it will take a couple of weeks for them to get them.
  7. Apr 15, 2025 at 9:56 AM
    Blakeus Maximus
    Blakeus Maximus Well-Known Member
    Southwest
    2000 TACOMA TRD 4X4
    That front bumper comes off easily. That should give you alot more room to work with. You shouldnt have to remove any other mounts. Just lift it enough to get the bushing in there and drop in the bolt right?
    Parkvisitor likes this.
  8. Apr 15, 2025 at 10:41 AM
    Black97v6MT
    Black97v6MT 364k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    27+ years of livin' Gen1 TacoLife...
    Can you still get good access to the area from Only removing the plastic front valence trim?
  9. Apr 15, 2025 at 11:03 AM
    skeezix
    Colorado
    1998 Limited
    I had another look. This time from the top down with the hood open. On the driver's side I can see a bolt head that is recessed. There is an opening thru which one can access the bolt with a ratchet wrench but with very little turning room. I suppose that could be used to hold the bolt while another person removes the easily accessibly nut from the bottom. If one had an arm with three links, that is.
    I could not see any bolt head on the passenger's side. The windshield reservoir sits atop of where one should be able to access the bolt, but only after removing the reservoir. And I'm not sure that there is actually access without removing to check and see.
    Removing the bumper means at least disconnecting the turn signal housing. I'm not sure what else must be removed to take off the bumper, but I'm sure there must be something. There always is. :facepalm:
  10. Apr 15, 2025 at 11:23 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    If the front two body mounts are bad, chances are good that the front cab mount ones aren't far behind. Why not change all 6 sets? Use the ES body mount kit. I'm betting it'll be cheaper that sourcing bushings from Toyota.
  11. Apr 15, 2025 at 12:36 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    I put the pice of wood to the left of the driver and to the right of the passenger facing the truck under the radiator support. This way you have room to see. Pulling the bumper is very easy if it’s an OEM bumper. The OEM bumper has hanger brackets so it won’t fall when you take the bolts out.
    This online vendor has the parts. It’s where I ordered mine.
    https://www.toyotapartsdeal.com/
    LightsOff likes this.
  12. Apr 15, 2025 at 12:37 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    that’s more work than taking the bumper off
    Black97v6MT[QUOTED] likes this.
  13. Apr 15, 2025 at 12:38 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Correct on the parts, obviously you’ll need 2 each
  14. Apr 15, 2025 at 4:40 PM
    ControlCar
    Steven
    Sugar Land TX
    Skeezix
    Do yourself a flavor…..
    Start drenching top/bottom of bushes with BP blaster at least 3 days(or more the better) before the scheduled wrenching begins!
    For less of a Blood Pressure spike,
    Try to schedule the work in parts
    You will “Hulk It” if try to do all work at once.
    I don’t know your schedule if your DD
    But
    Day/evening 1:
    Remove bumper
    Tech Tip: tape off fenders below parking lamps….I scratched the crap out of my paint removing/installing/adjusting front bumper
    Day 2:
    try one side
    Do one side/bush at a time
    Don’t jump around
    Day3:
    Well u get the idea
    iMO
    One day/afternoon at least to adjust front bumper alone
    GL
  15. Apr 15, 2025 at 4:58 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Or drive it over here and I’ll do the wrenching for you
    Black97v6MT and ControlCar like this.
  16. Apr 16, 2025 at 4:25 AM
    Black97v6MT
    iMA0
    tacoLand USA
    do you have the ES body mount kit on your rig?
  17. Apr 16, 2025 at 8:21 AM
    skeezix
    Colorado
    1998 Limited
    @ControlCar...
    I thought that there might be a lot more than has been mentioned in the previous posts. Thank you for letting me know what's really involved in replacing the front cushions! My 27-year-old Tacoma has probably seen the last days of rough off-roading. And at my age and after 38 years of maintaining my 1987 and 1998 trucks it's becoming a strain to even think about pulling the dipstick to check the oil level! I don't think I'll bother trying to replace the front mounts afterall. Ima gonna ride 'em out!
    @Parkvisitor...
    Thank you for your posts and your help, I appreciate it!
    @Black97v6MT...
    You've been around this forum for many, many years. It's good to read your posts! (The only ES parts I have are the sway bar and end link bushings.)
    @To all the rest of you men here...
    I cannot express how much you've helped me keep my 1998 Tacoma on the roads. It's been a habit, going through this forum for an hour or so each day for the last 20-some years, and I enjoyed every single minute of it. There are just too many names for me to recall, but I want to thank each and every one of very much for the help you've given me and to the hundreds of others who visit this forum!!!
    :bananadance::burnrubber::oldglory:
  18. Apr 16, 2025 at 8:29 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
  19. Apr 16, 2025 at 9:41 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yes, added it last year.
  20. Apr 16, 2025 at 9:58 AM
    Black97v6MT
    iMA0
    tacoLand USA
    did those make any noticeable difference in the cab over the very small, very slow speed road imperfections and such on the hard roads and or washboard soft roads?
