Radiator Replacement Cost
Discussion in '1st Gen. Tacomas (1995-2004)' started by TeeYoda, Aug 19, 2022.
  1. Aug 19, 2022 at 10:14 AM
    TeeYoda
    TeeYoda [OP] Well-Known Member
    PNW
    2003/2025 Tacoma sr5 4x4
    So after 320,000 plus miles of service, my radiator has finally decided to start leaking. It seems like a pretty easy job to replace, but I don't have the time or space to do the work myself right now. So what am I looking at, cost wise, if I go to a garage to have this done? Has anyone else had a radiator replace recently?
  2. Aug 19, 2022 at 11:48 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Perhaps post in your regional forum.
    Labor rates very so much across the country.
    Some shops charge extra to install customer supplied parts.
    Do you plan on including new coolant and new hoses as well ??
  3. Aug 19, 2022 at 11:58 AM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    So easy do it yourself. It always costs more than they say. Do it in the Walmart parking lot.
  4. Aug 19, 2022 at 6:10 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    $150-200 New aftermarket radiator. Try to buy local so you can trade in your old one for credit. Price will vary depending on brand.
    $50 Toyota Long Life Coolant (red or pink in color). Pre-diluted is easiest. 3RZ takes about 8.8 quarts according to the manual. I would buy 2 gallons because it won't all empty out from the engine. If you have green coolant you need to stick with it or do a complete flush with distilled water before adding red.
    $70 New upper and lower radiator hoses. May not be required, but this is a good time to do it. Squeeze the hoses and see if they're soft and inspect for cracks. Reuse factory clamps or buy new from Toyota.
    It's a good DIY, just watch a YouTube video.
    $10 new radiator cap. Many new radiators don't come with this important piece.
