Radiator pin-hole leaks -
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2021SR5V64WD, Dec 28, 2022.
  1. Dec 28, 2022 at 12:25 PM
    2021SR5V64WD
    2021SR5V64WD [OP] Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Coming here to ask the pro's - ... -
    2003 Corolla - 148,000 miles - leaking coolant -
    Most likely radiator has pin-holes in it .... some steam coming out and about the
    radiator itself. Filled it yesterday ran fine on his way home but on subsequent trip
    to the house today advised it was running pretty hot.
    So 2 questions for you guys:
    1. How much to totally [ballpark] replace ( I got no wrenching skills )
    2. Is there some kind of 'goo' I can put in to 'plug the holes'... or is that useless
    Caveat: That thing is driven about 30 miles a week tops - usually parked off campus
    and only driven a bit to a grocery store or to our house down the road for laundry and
    dinner etc... so expending tons of money is stupid.
  2. Dec 28, 2022 at 12:26 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    It ran pretty hot..?
  3. Dec 28, 2022 at 12:34 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Don't use stop leak. It will cause more problems. Like clogging your heater core.
  4. Dec 28, 2022 at 12:37 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Get two estimates. Cost of repairs varies with location.
    2021SR5V64WD[OP] likes this.
  5. Dec 28, 2022 at 12:44 PM
    Matt Sierra
    Matt Sierra Well-Known Member
    NorCal
    2020 TRD Pro MT
    Maggy SC, C4 Overland front bumper
    Aftermarket radiator will cost ~$160, labor to replace will depend quite a bit based on your location. In California, I’d expect at least another $150 in labor.
    Don’t use stop leak unless you’re planning on scrapping the car soon and don’t mind trashing your heater core.
  6. Dec 28, 2022 at 12:44 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    This will cure what ails your radiator: https://www.amazon.com/AlumAseal-ASLC16-Radiator-Conditioner-Liquid/dp/B0027I4IPG?th=1
  7. Dec 28, 2022 at 12:46 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    So dropping in a raw egg would be out of the question then....:rofl:
    knayrb, hiPSI, JoeCOVA and 3 others like this.
  8. Dec 28, 2022 at 12:48 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I've used Bars in the past with good results. My radiator started leaking in the winter and I didn't want to replace it in the cold. Put in some Bars tablets and it held find until it warmed up and I could replace it in the summer. Drove it for years after that with no issues.
    Everyone claims it will clog up your heater core but doesn't show any proof of it. Most likely the people that actually had clogged cores/radiators had other issues and dumped stop leak in and blamed it.
  9. Dec 28, 2022 at 12:48 PM
    Borracho Loco
    DFW, Texas
    Hey, I was going to mention that. I watched the "Christmas Story Christmas" movie over the holidays and saw him do it, and I was like "is that a thing"? I Googled it and sure enough, it's a thing and that really does work. Best part is..it's organic!
    Edit: It's a 20yr old-fucking-Corrola with 150k miles on the clock. Who gives a shit what you shove down there? As long as it gets the job done and is cheap. Am I right!?
    ColoradoTJ[QUOTED] likes this.
  10. Dec 28, 2022 at 12:50 PM
    RX1cobra
    19 OR
    Mythbusters did it and it stopped the leak.
    hiPSI likes this.
  11. Dec 28, 2022 at 12:55 PM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    It is a possibility to learn and DIY? I didn't know anything beyond oil changes and have learned everything I know now, thanks you YouTube. Shit, I tore my Subaru's transmission apart to replace the center diff all thanks to watching YouTube video's.
    Matt Sierra likes this.
  12. Dec 28, 2022 at 1:06 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Stop leak would be a cheap "need fixed now" repair, but only if the radiator is leaking in the fins. If the plastic on the radiator is cracked, the radiator needs to be replaced.
    Also, if you do use stop leak, flush the coolant system in both directions, multiple times, to clean out that gunk before you install the new radiator. There are cheap kits you can buy that connect your garden hose directly to the coolant lines so you can flush the system. You can even fabricate the kit yourself for fairly cheap as well.
  13. Dec 28, 2022 at 3:38 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    A Denso radiator on Rockauto is $95 for an 03 Corolla, and is the same part # as for my daughter’s 07 Corolla. $75 for a TYC radiator, an aftermarket brand I can vouch for. The radiator is relatively easy to replace - drain coolant, remove radiator hoses, remove electric fan, remove radiator. I would also replace the hoses, belt and thermostat. My daughter’s Corolla is approaching 200K and, as preventive maintenance, I’ll be replacing all these cooling system parts, plus the water pump. With shipping, plus coolant, it all comes out to about $220. You may also find you also need a tensioner pulley bearing - I had to replace her’s at 130K.
    I, too, recommend against using a stop leak product.
    RustyGreen likes this.
  14. Dec 28, 2022 at 3:41 PM
    2021SR5V64WD
    Leaking for sure just can't see it - hoses look clean while running just now I didn't see any 'drops' hitting but it was wet down in the frame.
    Refilled and took it for a spin in the 'hood' punched it up to 45 mph watched temp move right on up to HOT -
    At the house opened up while engine running didn't spy anything fantastic - temp dropped to normal range pretty quick.
    I'm wondering if it's just the Thermostat myself...
  15. Dec 28, 2022 at 3:45 PM
    eurowner
    eurowner Duke Sky
    Scoty
    If you have an IR point and shoot thermometer, wave it over the radiator and I bet you will find most of it shows "colder" than the inlet. Seen that in many of my new-to-me used vehicles over the decades.
    Get a new rad, new t-stat with gasket, and at least 50/50 premix coolant or if you want to mix your own use distilled H2O!
  16. Dec 28, 2022 at 3:47 PM
    MGMDesertTaco
    Could be a thermostat sticking or a clog in the system. A flush with fresh hoses and a new radiator are probably around $300.
  17. Dec 28, 2022 at 3:57 PM
    2021SR5V64WD
    Noticed after engine ran 'hot' I turned on the heat full max and it was blowing cold - so I think it's stuck open - along with anything else...
    MGMDesertTaco[QUOTED] likes this.
  18. Dec 28, 2022 at 4:01 PM
    MGMDesertTaco
    Could be or a clog in the heater core too.
  19. Dec 28, 2022 at 4:01 PM
    na8rboy
    WI
    T- Stat or has a air pocket.
  20. Dec 28, 2022 at 4:08 PM
    Chuy
    Lakeside, CA
    Silver Taco
    The thermostat does not control the heater temps separately from the radiator, thus lack of hot air is a separate issue. That is, if your coolant is running hot, then the coolant in the heater core will also be running hot.
